mITX with 2080
  • 271 views
  • netu5106
  • Laatst online: 05-05 20:09
Hi guys, what do you think about this build: https://nl.pcpartpicker.com/list/3qLs6s
My only concern now is if the super fat MSI GeForce RTX 2080 Super Ventus OC will fit properly. I know that the GPU's length should be fine (268mm) with a Corsair H100i PRO 75 CFM (27mm), but I am worried about if it will fit due to its width (50mm).
  • agittunc
  • Laatst online: 22-10 11:24
yeah that could a thing. is the H200 a done deal? i'd say get the H400 if ur not too attached to the size.
EDIT: it should work either way. witdh is the same as with h400/h500
[ Voor 25% gewijzigd door agittunc op 13-08-2019 16:30 ]
  • Uszka
  • Registratie: Maart 2018
  • Laatst online: 09:43
Externe lijstjes zijn niet toegestaan.
Waarom niet in het Nederlands op een NL techsite?
  • br00ky
  • Laatst online: 17:00
br00ky
Posting in English is fine as long as you stick to the rules, which you still don't. Please refer to DAA beleid.
