Hey,
Na de 1008 final maar de 1008/fxd gedownload, met als resultaat zoals beloofd een temp daling van jawel 10 graden!!!
Wel je pci master read caching op enable zetten!
Ow ja, ik heb revisie 1.01
Greetzz
hieronder een stuk uit de info:
Release Date: 07/26/2001
By DANIEL K. (dkbox2000@hotmail.com) - http://www.braziliantech.com
"ASUS A7V ACPI BIOS REVISION 1008/FXD" - Date: 07/26/2001
WARNING: THE AUTHOR OF THIS FIX TAKES NO RESPONSABILITY FOR ANY DAMAGES.
======= THIS FILE WAS CAREFULLY TESTED.
Unlike the WPCREDIT fix, this will NOT cause problems with your sound card, 'cause the
"Disconect Enable When STPGNT Detected", PCI Master Read Caching and Delayed Transaction
features are active prior to the "Initialize PNP Cards". This is just the official BIOS
fixed. Even with the fix, you will not get low temperatures as with 1003, because ASUS
added compensation of about 7°C.
>>> MAKE SURE TO ENABLE PCI MASTER READ CACHING IN BIOS SETUP
ADDITIONAL INFO:
- BIOS Date: 07/26/2001
- Checksum: E795 (Do NOT flash if checksum does not match)
- FXD Means: FIXED
RELEASE NOTES:
*07/26/2001*
- Based on Revision 1008 - Official Release
Greetzz
ADDITIONAL INFO:
- FXD Means: FIXED
RELEASE NOTES:
*07/26/2001*
