Problems with ipcamera on nvr
  • 303 views
First of all, I don't know if this is the right subreddit or not, so sorry if it isn't.
The problem:
I have trouble getting a live feed on my nvr. It is getting live feed on my app on the phone (yoosee). It's also getting live feed on my computer with cmsclient. But for some reason it is impossible to connect properly to the nvr. The ip does show up, i can select it but it isn't showing the live feed. I've also got a inside rotating cam without ethernetport connected via wifi which pics up fine on the nvr, but not on pc with cmsclient..
The setup/situation:
Huawei modem at the first floor, near the fuse box. Dhcp enabled 100-200. Own ip is 192.168.1.1
Dns alts are 8.8.8.8 and 8.8.4.4.
1 ethernetport is connected to the router upstairs to the lanport, setup as accesspoint (dhcp off). From a lanport on this runs a ethernetcable to the nvr itself. Here the inside wifi cam pics up fine.
On the modem, the other ethernet is plugged into a powerline adapter to the garage, which comes out of another powerline adapter there straight to another router, again setup as accesspoint (into lanport and dhcp disabled). From there a ethernetport in the lan is directly connected to the ipcamera. Wifi and internet from this router is very good (14 ping 100down 30up lan to laptop via ookla speedtest).
Ip adresses are:
Modem 192.168.1.1
Router upstairs 192.168.1.201
Router garage 192.168.1.202
Cam inside 192.168.1.105
Cam garage 192.168.1.101
Gateways on both routers is modem ip. Both got the 8.8.8.8 and 8.8.4.4 dns. both routers got dhcp disabled to function as AP.
Sorry for the long post.
Does anyone have a clue why this isn't working?
Thank you in advance.
Greetings, Ryan.
  • DukeBox
Om welke camera (model/type) en welke nvr (model/type) gaat het ?
Al geprobeerd met statische IP's direct op de nvr zonder routers er tussen ?
Normaal gesproken gebruik je routers alleen om te routeren tussen verschillende subnetten maar dat kom ik niet tegen in je netwerk omschrijving ?
[ Voor 42% gewijzigd door DukeBox op 07-07-2019 21:03 ]
  • The Eagle
  • Laatst online: 13:54
The Eagle
I wear my sunglasses at night
Wat gaf je het idee dat alles op ieder forum Reddit en Engels gebaseerd is?
De hele site is in het Nederlands, je aanmeldingsprocedure ook. Nofi, maar hoe denk je dat we tegenover je vraag staan?
@DukeBox
De camera is een Besder 920p ipcamera van Ali. De camera is een onvif capable Besder nvr, ook van ome Ali.
De routers heb ik zoals beschreven geconfigureerd als accespoint om zo juist verschillende subnetten te voorkomen (Dhcp uit en ethernet op de lanpoort).
Nvr zit nu in de muur van de garage dus 1 2 3 rechtstreeks aan de nvr koppelen is niet zo makkelijk.
Hoe zou ik een statische ip kunnen instellen op de camera? (Of deze uberhaupt kunnen veranderen).
@The Eagle
Beste Eagle.
Daarin moet ik je inderdaad gelijk geven.
Echter, deze zelfde tekst had ik ook op reddit gepost, en van daaruit gekopïeerd.
Helemaal omvertalen terwijl de technische termen daarbij niks veranderen had in mijn ogen niet direct veel zin.
In het vervolg zal ik inderdaad gewoon in het nederlands posten en logischerwijs ook reageren.
Bedankt heren.
  • DukeBox
Grote kans dat een van je 'routers' multicast niet forward voor SSDP.
[ Voor 7% gewijzigd door DukeBox op 07-07-2019 21:32 ]
@DukeBox
Oke, enig idee hoe ik dit kan controleren?
  • DukeBox
Verwijderd schreef op zondag 7 juli 2019 @ 21:44:
Ja, zie eerste post.
@DukeBox
Dus direct aan de nvr koppelen neem ik aan.
  • Microkid
  • Laatst online: 14:40
Microkid
Smile
@Verwijderd Als jij niet de moeite wilt nemen om een goede topicstart te maken zoals beschreven in de FAQ, zie ik geen reden waarom wij je zouden moeten helpen.
