Imac gets stuck after software update and reinstallation
  • Jerom152
  • Registratie: Juni 2019
  • Laatst online: 23-10-2021
So i just bought a Imac from a friend, he reinstalled hes Mac with the disc ‘Mac OS X Snow Leopard version 10.6.3´. Everything seemed fine until i tried to watch a video or used Facebook, it would not load it. So i tried to do a software update, a new version was available, i needed to restart my Mac, i press restart and everything disappears and i’m stuck on my background. (Nothing happens)
I also got the other disc, the one he got when he bought the Mac, this is just a grey disc from 2006. I tried to install this disc, i put the disc in the Mac and tried to install, again i needed to restart my Mac again, this time a certain grey screen pops up saying i need to shut down my Mac, after shutting down i restart my Mac and the same screen pops up. Now i really don’t know what to do, the only thing my Mac tells me is to shut down. Can somebody help me with this problem? Thanks in advance for just reading this book :)
  • nelizmastr
  • Laatst online: 15-10 07:05
nelizmastr
Goed wies kapot
Your Mac’s software is too old to browse the modern web. Install a newer macOS (if it’s a 2009 model or newer, you can run 10.11-10.13 which is still quite usable.
If you don’t know how to do this, take it to an Apple store or Apple service provider and have them do it.
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Hoi Jerom152, welkom op GoT :)
Zoals je wellicht hebt gemerkt is dit een Nederlandstalig forum. Je mag je bericht dan ook gewoon in het Nederlands plaatsen. Mocht je de Nederlandse taal niet machtig zijn, dan mag je bij hoge uitzondering je berichten in het Engels plaatsen, maar dan verwachten we wel dat andere gebruikers in het Nederlands mogen reageren.
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
  • Jerom152
Daedalus, dankje voor mij welkom te heten, zal in het vervolg in het nederlands mijn vragen stellen, was hiervan niet op de hoogte.
  • Jerom152
Nelizmastr, wat jij bedoeld is dat ik een nieuwere versie van die CD moet hebben? Ik dacht dat ik met die CD het systeem erop kon zetten waarna ik via een software update ook die nieuwste software erop zet. Nu weet ik eigenlijk echt niet zo goed wat ik moet doen want mijn Mac zit dus letterlijk vast, de CD zit erin en wanneer ik nu mijn Mac aan zet, krijg ik na 30 seconden een scherm waarin 4 talen staat dat ik mij Mac moet afzetten door de uitknop enkele seconden in te houden. Ik vroeg mij af of iemand dit probleem ook al heeft gehad en mij hiermee kan helpen, want naar een Apple Store gaan kost dan ook al weer wat geld. Alvast bedankt
  • Jerom152
Zou dit soort probleem in een Apple Store gratis kunnen verholpen worden?
  • The Eagle
  • Laatst online: 22:32
The Eagle
I wear my sunglasses at night
Verholpen: ongetwijfeld. ratis: bel ze en vraag het ze :?
verder: als je de laatste bent die gereageerd hebt en je wilt iets toevoegen: geen nieuwe post maken maar je laatste post graag wijzigen. Link om dat te doen zit rechts boven aan je laatste post :)
Nu zien we het als onnodig kicken / aandacht vragen. En dat zal niet jouw bedoeling zijn, plus het werkt meestal averechts ;)
  • kaassouffle
  • Laatst online: 15-10 10:49
kaassouffle
Medewerker v/d Maand
Welk type Mac heb je? Dan kun je iig checken welk besturingssyteem hij aan kan.
Dan kun je ook kijken welke recovery/boot-modes hij aankan om hardware-diagnostics te draaien.
