Synology vs OpenVPN via IOS - KEV_Negotiate_error
  • Paul.tjuh1986
  • Laatst online: 17-12-2025
Ik heb laatst mijn router geswapped naar een RT-AC1200G+ van Asus, en sindsdien werkt mijn VPN naar me Synology NAS niet meer via IOS
Windows werkt prima, maar wanneer ik dezelfde config van OpenVPN push naar mijn IOS device, krijg ik de error KEV_NEGOTIATE_ERROR.
Mijn succesfull connection via mijn Windows 10 device:
Sun Jun 02 11:25:11 2019 Flag 'def1' added to --redirect-gateway (iservice is in use)
Sun Jun 02 11:25:11 2019 OpenVPN 2.4.4 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Sep 26 2017
Sun Jun 02 11:25:11 2019 Windows version 6.2 (Windows 8 or greater) 64bit
Sun Jun 02 11:25:11 2019 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10
Enter Management Password:
Sun Jun 02 11:25:13 2019 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Jun 02 11:25:13 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]PUBLIC IP:1194
Sun Jun 02 11:25:13 2019 UDP link local (bound): [AF_INET][undef]:1194
Sun Jun 02 11:25:13 2019 UDP link remote: [AF_INET]PUBLIC IP:1194
Sun Jun 02 11:25:13 2019 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sun Jun 02 11:26:13 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sun Jun 02 11:26:13 2019 TLS Error: TLS handshake failed
Sun Jun 02 11:26:13 2019 SIGUSR1[soft,tls-error] received, process restarting
Sun Jun 02 11:26:18 2019 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun Jun 02 11:26:18 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]PUBLIC IP:1194
Sun Jun 02 11:26:18 2019 UDP link local (bound): [AF_INET][undef]:1194
Sun Jun 02 11:26:18 2019 UDP link remote: [AF_INET]PUBLIC IP:1194
Sun Jun 02 11:26:22 2019 [mynas.nl] Peer Connection Initiated with [AF_INET]LOCAL IP:1194
Sun Jun 02 11:26:23 2019 WARNING: INSECURE cipher with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC).
Sun Jun 02 11:26:23 2019 WARNING: cipher with small block size in use, reducing reneg-bytes to 64MB to mitigate SWEET32 attacks.
Sun Jun 02 11:26:23 2019 open_tun
Sun Jun 02 11:26:23 2019 TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{40C4A9B8-E6AD-433F-A215-90562E442A05}.tap
Sun Jun 02 11:26:23 2019 Notified TAP-Windows driver to set a DHCP IP/netmask of 192.168.5.6/255.255.255.252 on interface {40C4A9B8-E6AD-433F-A215-90562E442A05} [DHCP-serv: 192.168.5.5, lease-time: 31536000]
Sun Jun 02 11:26:23 2019 Successful ARP Flush on interface [8] {40C4A9B8-E6AD-433F-A215-90562E442A05}
Sun Jun 02 11:26:23 2019 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Sun Jun 02 11:26:28 2019 Initialization Sequence Completed
Mijn OpenVPN config:
dev tun
tls-client
remote PUBLIC IP 1194
# The "float" tells OpenVPN to accept authenticated packets from any address,
# not only the address which was specified in the --remote option.
# This is useful when you are connecting to a peer which holds a dynamic address
# such as a dial-in user or DHCP client.
# (Please refer to the manual of OpenVPN for more information.)
float
# If redirect-gateway is enabled, the client will redirect it's
# default network gateway through the VPN.
# It means the VPN connection will firstly connect to the VPN Server
# and then to the internet.
redirect-gateway
# dhcp-option DNS: To set primary domain name server address.
# Repeat this option to set secondary DNS server addresses.
dhcp-option DNS 192.168.1.1
mssfix 1100
pull
# If you want to connect by Server's IPv6 address, you should use
# "proto udp6" in UDP mode or "proto tcp6-client" in TCP mode
proto udp
script-security 2
comp-lzo
reneg-sec 0
cipher BF-CBC
auth SHA1
auth-user-pass
<ca>
-----BEGIN CERTIFICATE-----
</ca>
Stappen geprobeert
- port forward op Asus router
- Andere poorten (443 en 1194)
- Firewall uitgeschakeld op NAS en Asus Router
- Nieuwe exports van configs
- Certificaat vernieuws op NAS
Nogmaals, via mijn Windows 10 device werkt met VPN wel
