MSG to VCF Conversion
  • 126 views
HI...
MyI want to change VCard format and I should convert it to MSG format to Vcard.
Any suggestion will be appreciated :)
Thanks
  • DukeBox
Wat heb je al geprobeerd en waarom lukte dat niet ? Het zijn beide open standaarden dus er moeten wel conversie tools voor zijn.
  • Microkid
  • Laatst online: 22:12
Microkid
Smile
Posting in English is fine, as long as you stick the rules. These dictate that you have to show what you have been looking for. Currently that part is fully lacking. You got some work to do ;). You can open a new topic, however we expect you to list the programs you found yourself and why those aren't helpful to you.
