Als ik een cd'tje wil burnen, maakt niet uit wat ik doe, multisession, no multisession.. finalize cd wel niet . alle mogelijkheden geprobeerd. Ik draai windows98SE en gebruik nero 5.5.2.4 ... verder heb ik alle cd'tjes geprobeerd maar die fi(U)kker burned maar niet. ook in win2k niet.
Scar
Scar
1507-0293-6950-6030-1526-8986
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 4/23/99 10:22:00 PM
Nero Version: 5.5.2.4
Recorder: <AOPEN CD-RW CRW1232PRO> Version: 1.30 - HA 0 TA 0 - 5.5.2.4
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
CD-ROM: <AOPEN CD-RW CRW1232PRO>Version: 1.30 - HA 0 TA 0 - 5.5.2.4
AOPEN CD-RW CRW1232PRO (Target 0, H:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
HP CD-Writer+ 8100 (Target 1, I:): Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261640kB)
Free physical memory: 90MB (92320kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
25.7.2001
11:23:03 PM#1 Text 0 File Reader.cpp, Line 133
Reader running
11:23:03 PM#2 Text 0 File Writer.cpp, Line 125
Writer CD-RW CRW1232PRO running
11:23:03 PM#3 ISO9660GEN -11 File geniso.cpp, Line 4210
First writeable address = 0 (0x00000000)
11:23:03 PM#4 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 357123 (357123) = #357123/79:21.48
relocatable, CD pos for caching/writing not required/required, no patch infos
11:23:18 PM#5 Text 0 File Burncd.cpp, Line 1509
Recorder: AOPEN CD-RW CRW1232PRO;
CDR code: 00 97 26 60; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 B0, 2: 61 1A 3C (LI 97:26.60), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
11:23:19 PM#6 Text 0 File ThreadedTransferInterface.cpp, Line 800
Prepare recorder CD-RW CRW1232PRO for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 731695104
11:23:19 PM#7 Text 0 File ThreadedTransferInterface.cpp, Line 828
Removed 2 run-out blocks from end of track 1.
11:23:19 PM#8 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 357121 blocks [CD-RW CRW1232PRO]
11:23:19 PM#9 Phase 24 File dlgbrnst.cpp, Line 1353
Caching of files started
11:23:19 PM#10 Phase 25 File dlgbrnst.cpp, Line 1353
Caching of files completed
11:23:19 PM#11 Phase 36 File dlgbrnst.cpp, Line 1353
Burn process started at 12x (1800 KB/s)
11:23:19 PM#12 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
11:23:19 PM#13 Text 0 File Mmc.cpp, Line 15186
Set BUFE: JustLink -> OFF
11:23:29 PM#14 SCSI -1152 File Cdrdrv.cpp, Line 1353
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x032D77C8
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x64
Sense Qual: 0xC0
CDB Data: 0xAA 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x64 0xC0
11:23:29 PM#15 mmc -1152 File Writer.cpp, Line 311
Medium speed error
11:23:29 PM#16 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
11:23:29 PM#17 Text 0 File ThreadedTransfer.cpp, Line 212
conversion idle, stopping reader
11:23:29 PM#18 CDR -201 File WriterStatus.cpp, Line 162
Invalid writestate
11:23:29 PM#19 TRANSFER -18 File WriterStatus.cpp, Line 162
Could not perform EndTrack
11:23:30 PM#20 Phase 38 File dlgbrnst.cpp, Line 1353
Burn process failed at 12x (1800 KB/s)
11:23:30 PM#21 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 16, size=33451 bytes, created 7/25/01 10:35:42 PM
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 4/23/99 10:22:00 PM
HEEELp
Scar
Scar
Windows 98 4.10
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry: 1
Wizard: Off
CD-ROM (ISO)
25.7.2001
Reader running
ATIP Data:
DAO infos:
MCN:
Tracks 1 to 1:
Sense Code: 0x64
Sense Qual: 0xC0
Medium speed error
Invalid writestate
Existing drivers:
HEEELp
