Kan iemand me vertellen of het mogelijk is om in mijn router TP-Link Archer C7 een USB-opslagstick te doen, die ik vanaf een PC buiten het huis via internet met een wachtwoord kan benaderen?
Zoja hoe kan ik zoiets instellen en is dat veilig?
  • Cpt.Morgan
  • Laatst online: 23-11-2025
Dit staat beschreven in de handleiding, hoofdstuk 7, paragraaf 1.2 (https://www.tp-link.com/e...s-us-4.0#ug-sub-title-1):
1.2. Access the USB Device Remotely
You can access your USB disk outside the local area network. For example, you can:
  • •Share photos and other large files with your friends without logging in to (and paying for) a photo-sharing site or email system.
  • •Get a safe backup for the materials for a presentation.
  • •Remove the files on your camera’s memory card from time to time during the journey
Note: If your ISP assigns a private WAN IP address (such as 192.168.x.x or 10.x.x.x), you cannot use this feature because private addresses are not routed on the Internet.
Follow the steps below to configure remote access settings.
  1. Visit http://tplinkwifi.net, and log in with your TP-Link ID or the password you set for the router.
  2. Go to Advanced > USB Settings > Sharing Access page.
  3. Tick the FTP(via Internet) checkbox, and then click Save.
  4. Refer to the following table to access your USB disk remotely:
1 )Open the Windows Explorer (or go to Computer, only for Windows users) or open a web browser.
2 )Type the server address in the address bar:
Type in ftp://<WAN IP address of the router>:<port number> (such as ftp://59.40.2.243:21). If you have specified the domain name of the router, you can also type in ftp://<domain name>:<port number> (such as ftp://MyDomainName:21)
3 )Press Enter on the keyboard.
4 )Access with the username and password you set in To Set up Authentication for Data Security.
[ Voor 84% gewijzigd door Cpt.Morgan op 03-04-2019 10:00 ]
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Elders had je vragen over betrouwbaarheid. Houd er rekening mee dat dit veilig noch betrouwbaar is. Zeker als het zonder kennis van zaken gebeurt op een vanilla router.
  • rens-br
  • Laatst online: 21:40
rens-br
Admin IN & Moderator Mobile
@Verwijderd voor dit topic geldt precies hetzelfde als de andere twee. Je topic voldoet niet aan de wensen/eisen die we er aan stellen. Zo is het belangrijk om eerst wat eigen onderzoek te doen, voordat je een topic opent, zie ook: Het algemeen beleid #quickstart.
Ga dus even zelf op onderzoek uit en mocht je er daarna niet uitgekomen zijn, open dan gerust een nieuw topic.
