Windows 10 BSOD probleem
Ik krijg steeds BSOD's maar ik kan niet echt goed vinden waar het door komt.
Bij "System errors" staat de boos doener.
INFO:
MiniToolBox by Farbar Version: 17-06-2016
Ran by Akasha (administrator) on 24-03-2019 at 22:58:26
Running from "C:\Users\Akasha\Desktop"
Microsoft Windows 10 Home (X64)
Model: MS-7B24 Manufacturer: Micro-Star International Co., Ltd.
Boot Mode: Normal
========================= Flush DNS: ===================================
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
"Reset IE Proxy Settings": IE Proxy Settings were reset.
========================= FF Proxy Settings: ==============================
"Reset FF Proxy Settings": Firefox Proxy settings were reset.
========================= Hosts content: =================================
========================= IP Configuration: ================================
Realtek PCIe GBE Family Controller = Ethernet (Connected)
VMware Virtual Ethernet Adapter for VMnet1 = VMware Network Adapter VMnet1 (Connected)
VMware Virtual Ethernet Adapter for VMnet8 = VMware Network Adapter VMnet8 (Connected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="Ethernet (kerneldebugger)" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="VMware Network Adapter VMnet1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="VMware Network Adapter VMnet8" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : DESKTOP-P1BCU5T
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : multi.box
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : multi.box
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 30-9C-23-B7-09-39
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::6069:ffd5:30a6:ec53%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.94(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : zondag 24 maart 2019 22:38:19
Lease Expires . . . . . . . . . . : woensdag 3 april 2019 22:38:18
Default Gateway . . . . . . . . . : 192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DHCPv6 IAID . . . . . . . . . . . : 103848995
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-24-6F-C1-30-9C-23-B7-09-39
DNS Servers . . . . . . . . . . . : 192.168.178.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
Link-local IPv6 Address . . . . . : fe80::3cf3:c9ff:e57f:6ca%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.109.1(Preferred)
Lease Expires . . . . . . . . . . : zondag 24 maart 2019 23:23:18
DHCP Server . . . . . . . . . . . : 192.168.109.254
DHCPv6 IAID . . . . . . . . . . . : 402673750
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::9193:775d:fcd5:b866%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.190.1(Preferred)
DHCP Server . . . . . . . . . . . : 192.168.190.254
DHCPv6 IAID . . . . . . . . . . . : 419450966
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Primary WINS Server . . . . . . . : 192.168.190.2
Server: multi.box
Address: 192.168.178.1
Addresses: 2a00:1450:4005:803::200e
216.58.213.206
Pinging google.com [216.58.213.206] with 32 bytes of data:
Reply from 216.58.213.206: bytes=32 time=27ms TTL=56
Reply from 216.58.213.206: bytes=32 time=26ms TTL=56
Ping statistics for 216.58.213.206:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 26ms, Maximum = 27ms, Average = 26ms
Server: multi.box
Addresses: 2001:4998:58:1836::11
2001:4998:58:1836::10
2001:4998:44:41d::4
2001:4998:c:1023::4
2001:4998:44:41d::3
2001:4998:c:1023::5
72.30.35.9
98.137.246.7
72.30.35.10
98.138.219.231
98.137.246.8
98.138.219.232
Pinging yahoo.com [72.30.35.9] with 32 bytes of data:
Reply from 72.30.35.9: bytes=32 time=122ms TTL=54
Ping statistics for 72.30.35.9:
Minimum = 122ms, Maximum = 122ms, Average = 122ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
16...30 9c 23 b7 09 39 ......Realtek PCIe GBE Family Controller
13...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
7...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.178.1 192.168.178.94 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
192.168.109.0 255.255.255.0 On-link 192.168.109.1 291
192.168.109.1 255.255.255.255 On-link 192.168.109.1 291
192.168.109.255 255.255.255.255 On-link 192.168.109.1 291
192.168.178.0 255.255.255.0 On-link 192.168.178.94 281
192.168.178.94 255.255.255.255 On-link 192.168.178.94 281
192.168.178.255 255.255.255.255 On-link 192.168.178.94 281
192.168.190.0 255.255.255.0 On-link 192.168.190.1 291
192.168.190.1 255.255.255.255 On-link 192.168.190.1 291
192.168.190.255 255.255.255.255 On-link 192.168.190.1 291
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.109.1 291
224.0.0.0 240.0.0.0 On-link 192.168.190.1 291
224.0.0.0 240.0.0.0 On-link 192.168.178.94 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.109.1 291
255.255.255.255 255.255.255.255 On-link 192.168.190.1 291
255.255.255.255 255.255.255.255 On-link 192.168.178.94 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 331 ::1/128 On-link
13 291 fe80::/64 On-link
7 291 fe80::/64 On-link
16 281 fe80::/64 On-link
13 291 fe80::3cf3:c9ff:e57f:6ca/128
On-link
16 281 fe80::6069:ffd5:30a6:ec53/128
On-link
7 291 fe80::9193:775d:fcd5:b866/128
On-link
1 331 ff00::/8 On-link
13 291 ff00::/8 On-link
7 291 ff00::/8 On-link
16 281 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\NLAapi.dll [70144] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 15 C:\WINDOWS\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
Catalog9 16 C:\WINDOWS\SysWOW64\vsocklib.dll [65016] (VMware, Inc.)
Catalog9 17 C:\WINDOWS\SysWOW64\vsocklib.dll [65016] (VMware, Inc.)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\NLAapi.dll [92160] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 15 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
x64-Catalog9 16 C:\Windows\System32\vsocklib.dll [69104] (VMware, Inc.)
x64-Catalog9 17 C:\Windows\System32\vsocklib.dll [69104] (VMware, Inc.)
========================= Event log errors: ===============================
Application errors:
Error: (03/23/2019 09:56:35 PM) (Source: Microsoft-Windows-Perflib) (User: NT AUTHORITY)
Description: Gebruiker "SYSTEM" heeft geen toegang gekregen tot prestatiegegevens (waarde van GetUserName() voor de uitgevoerde thread) zoals geprobeerd vanaf module "C:\Program Files (x86)\VMware\VMware Player\vmware-authd.exe" (waarde van GetModuleFileName() voor de binaire module die de query heeft verzonden).
Error: (03/23/2019 09:54:55 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: RuntimeBroker.exe, versie: 10.0.17763.1, tijdstempel: 0xd42c5158
Naam van module met fout: windows.storage.dll, versie: 10.0.17763.348, tijdstempel: 0x9d1c32d4
Uitzonderingscode: 0xc0000005
Foutmarge: 0x000000000004087c
Id van proces met fout: 0x328
Starttijd van toepassing met fout: 0xRuntimeBroker.exe0
Pad naar toepassing met fout: RuntimeBroker.exe1
Pad naar module met fout: RuntimeBroker.exe2
Rapport-id: RuntimeBroker.exe3
Volledige pakketnaam met fout: RuntimeBroker.exe4
Relatieve toepassings-id van pakket met fout: RuntimeBroker.exe5
Error: (03/23/2019 09:54:48 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: SearchUI.exe, versie: 10.0.17763.348, tijdstempel: 0x5c73b083
Naam van module met fout: combase.dll, versie: 10.0.17763.253, tijdstempel: 0x027b41b1
Foutmarge: 0x000000000008428e
Id van proces met fout: 0x17b4
Starttijd van toepassing met fout: 0xSearchUI.exe0
Pad naar toepassing met fout: SearchUI.exe1
Pad naar module met fout: SearchUI.exe2
Rapport-id: SearchUI.exe3
Volledige pakketnaam met fout: SearchUI.exe4
Relatieve toepassings-id van pakket met fout: SearchUI.exe5
Error: (03/23/2019 09:54:45 PM) (Source: Application Error) (User: )
Naam van module met fout: Windows.UI.Xaml.dll, versie: 10.0.17763.379, tijdstempel: 0x1dcf1d23
Foutmarge: 0x000000000014dfc0
Id van proces met fout: 0x2350
Error: (03/22/2019 05:04:46 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: svchost.exe_stisvc, versie: 10.0.17763.1, tijdstempel: 0xb900eeff
Naam van module met fout: unknown, versie: 0.0.0.0, tijdstempel: 0x00000000
Foutmarge: 0x0000000000000000
Id van proces met fout: 0x1e14
Starttijd van toepassing met fout: 0xsvchost.exe_stisvc0
Pad naar toepassing met fout: svchost.exe_stisvc1
Pad naar module met fout: svchost.exe_stisvc2
Rapport-id: svchost.exe_stisvc3
Volledige pakketnaam met fout: svchost.exe_stisvc4
Relatieve toepassings-id van pakket met fout: svchost.exe_stisvc5
Error: (03/21/2019 11:54:40 PM) (Source: Application Hang) (User: )
Description: Het programma Wow.exe, versie 8.1.5.29737 reageert niet meer op Windows en is afgesloten. Als u wilt zien of er meer informatie over het probleem beschikbaar is, raadpleegt u de probleemgeschiedenis in het onderdeel Beveiliging en onderhoud van het Configuratiescherm.
Proces-id: 1c40
Starttijd: 01d4e037d68c55ff
Eindtijd: 7
Toepassingspad: C:\Program Files (x86)\World of Warcraft\_retail_\Wow.exe
Rapport-id: afef854d-bc69-4057-867d-799bed8bd2f2
Type vastlopen: Wow.exe0
Error: (03/21/2019 11:45:49 PM) (Source: Application Hang) (User: )
Proces-id: 3a8
Starttijd: 01d4e037897773ee
Eindtijd: 4
Rapport-id: 953671e0-a848-4364-866b-0de6a8535d9d
System errors:
Error: (03/24/2019 10:40:20 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalStartenWindows.SecurityCenter.WscDataProtectionNiet beschikbaarNT AUTHORITYSYSTEMS-1-5-18LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Description: toepassingsspecifiekLokaalStartenWindows.SecurityCenter.SecurityAppBrokerNiet beschikbaarNT AUTHORITYSYSTEMS-1-5-18LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Description: toepassingsspecifiekLokaalStartenWindows.SecurityCenter.WscBrokerManagerNiet beschikbaarNT AUTHORITYSYSTEMS-1-5-18LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (03/24/2019 10:38:19 PM) (Source: BugCheck) (User: )
Description: 0x0000001a (0x0000000000061941, 0x000000000bbabf18, 0x000000000000000f, 0xfffff28dc6cc7a00)C:\WINDOWS\MEMORY.DMP907d120c-5bff-43a6-9937-870e5c30f1d7
Error: (03/24/2019 09:25:47 PM) (Source: DCOM) (User: DESKTOP-P1BCU5T)
Description: toepassingsspecifiekLokaalActiveren{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}{15C20B67-12E7-4BB6-92BB-7AFF07997402}DESKTOP-P1BCU5TAkashaS-1-5-21-1712757754-328422361-173595318-1001LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (03/24/2019 09:07:34 PM) (Source: DCOM) (User: DESKTOP-P1BCU5T)
Error: (03/24/2019 08:53:56 PM) (Source: DCOM) (User: DESKTOP-P1BCU5T)
Microsoft Office Sessions:
Error: (03/23/2019 09:56:35 PM) (Source: Microsoft-Windows-Perflib)(User: NT AUTHORITY)
Description: SYSTEMC:\Program Files (x86)\VMware\VMware Player\vmware-authd.exe
Error: (03/23/2019 09:54:55 PM) (Source: Application Error)(User: )
Description: RuntimeBroker.exe10.0.17763.1d42c5158windows.storage.dll10.0.17763.3489d1c32d4c0000005000000000004087c32801d4e1baab28d90cC:\Windows\System32\RuntimeBroker.exeC:\WINDOWS\System32\windows.storage.dllea0123ab-dae4-4904-af1c-616080e81183
Error: (03/23/2019 09:54:48 PM) (Source: Application Error)(User: )
Description: SearchUI.exe10.0.17763.3485c73b083combase.dll10.0.17763.253027b41b1c0000005000000000008428e17b401d4e1baa7071690C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exeC:\WINDOWS\System32\combase.dll388d74fd-122e-4aca-aab4-b4bceef72b07Microsoft.Windows.Cortana_1.11.5.17763_neutral_neutral_cw5n1h2txyewyCortanaUI
Error: (03/23/2019 09:54:45 PM) (Source: Application Error)(User: )
Description: SearchUI.exe10.0.17763.3485c73b083Windows.UI.Xaml.dll10.0.17763.3791dcf1d23c0000005000000000014dfc0235001d4e1baa5315b60C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exeC:\Windows\System32\Windows.UI.Xaml.dll02dcf126-041a-4020-b0ff-39b1112fe46bMicrosoft.Windows.Cortana_1.11.5.17763_neutral_neutral_cw5n1h2txyewyCortanaUI
Error: (03/22/2019 05:04:46 PM) (Source: Application Error)(User: )
Description: svchost.exe_stisvc10.0.17763.1b900eeffunknown0.0.0.000000000c000000500000000000000001e1401d4e0c8f5ef2bafC:\WINDOWS\system32\svchost.exeunknownec4fcdcf-4977-4576-a829-7a2e62ebe9a9
Error: (03/21/2019 11:54:40 PM) (Source: Application Hang)(User: )
Description: Wow.exe8.1.5.297371c4001d4e037d68c55ff7C:\Program Files (x86)\World of Warcraft\_retail_\Wow.exeafef854d-bc69-4057-867d-799bed8bd2f2Unknown
Error: (03/21/2019 11:45:49 PM) (Source: Application Hang)(User: )
Description: Wow.exe8.1.5.297373a801d4e037897773ee4C:\Program Files (x86)\World of Warcraft\_retail_\Wow.exe953671e0-a848-4364-866b-0de6a8535d9dUnknown
CodeIntegrity Errors:
Date: 2019-03-22 17:36:56.283
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume9\Windows\System32\D3DSCache.dll because the set of per-page image hashes could not be found on the system.
Date: 2019-03-22 17:36:56.276
=========================== Installed Programs ============================
7-Zip 18.05 (x64) (HKLM\...\7-Zip) (Version: 18.05 - Igor Pavlov)
AMD Settings (HKLM\...\WUCCCApp) (Version: 2019.0109.1525.27750 - Advanced Micro Devices, Inc.)
AMD Software (HKLM\...\AMD Catalyst Install Manager) (Version: 19.1.1 - Advanced Micro Devices, Inc.)
Battle.net (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
Canon MP Navigator EX 4.0 (HKLM-x32\...\MP Navigator EX 4.0) (Version: - )
CanoScan LiDE 110 Scanner Driver (HKLM\...\{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_CNQ2414) (Version: - Canon Inc.)
Catalyst Control Center Next Localization BR (HKLM\...\{A16E186C-58C4-3BDC-5CCE-714EFEF5F27F}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization CHS (HKLM\...\{E42911E5-48F8-8557-ED20-D72AD1907D25}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization CHT (HKLM\...\{B4C30EF4-B2C5-1395-B534-7B63BCB6E8E4}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization CS (HKLM\...\{62098A5F-E03B-31A3-5F9C-51A7F7D25744}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization DA (HKLM\...\{1757AD9B-0E3C-05F9-FE43-4343BED7DA85}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization DE (HKLM\...\{66B06F29-EE4F-9130-D96A-754826093FEA}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization EL (HKLM\...\{821D0A0E-F246-BE40-0D68-93883C14C410}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization ES (HKLM\...\{88BD74C4-23AB-4554-915C-6E1F0C81F6CD}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization FI (HKLM\...\{A48E2AB0-0866-7783-9657-E1709EB18D02}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization FR (HKLM\...\{E61CEF9A-BAC3-EAEE-F735-E257D2354DF2}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization HU (HKLM\...\{DA0326BB-657D-AAFC-752C-363E8FA33755}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization IT (HKLM\...\{B873A1FB-5EA0-EE5F-A861-1E38880AD08E}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization JA (HKLM\...\{EC9DF9FF-9D75-4CDD-1D58-A2E887B0A42E}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization KO (HKLM\...\{7ABACA7E-6E59-0EF9-8FA3-6B32E5F58127}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization NL (HKLM\...\{3E196AAF-F81C-B384-E2AB-28EE2398FE5F}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization NO (HKLM\...\{DAEFFE0C-CD05-1355-6AFC-7B3D4106A820}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization PL (HKLM\...\{E392A425-53A7-DF90-96A0-E287A75DD3B2}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization RU (HKLM\...\{D6F47BB4-700A-F612-0671-5F69EA311BB7}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization SV (HKLM\...\{01FD9A26-3F61-9236-B360-BE5D043D82C0}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization TH (HKLM\...\{64D4CCC3-63DF-252D-D29D-03491670225D}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Catalyst Control Center Next Localization TR (HKLM\...\{8DF90937-B869-9F76-5D45-5A8BDA0A33B6}) (Version: 2017.0922.1659.28737 - Advanced Micro Devices, Inc.) Hidden
Hearthstone (HKLM-x32\...\Hearthstone) (Version: - Blizzard Entertainment)
Hearthstone Deck Tracker (HKCU\...\HearthstoneDeckTracker) (Version: 1.8.3 - HearthSim)
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 1805.12.0.1097 - Intel Corporation)
Intel(R) Trusted Connect Service Client x86 (HKLM-x32\...\{C9552825-7BF2-4344-BA91-D3CD46F4C441}) (Version: 1.48.197.0 - Intel Corporation) Hidden
Intel(R) Trusted Connect Services Client (HKLM-x32\...\{66129f84-d3f0-4884-ac54-369ae6fc2cf6}) (Version: 1.48.197.0 - Intel Corporation) Hidden
Intel® Software Guard Extensions Platform Software (HKLM-x32\...\ARP_for_prd_SGX_1.9.100.41172) (Version: 1.9.100.41172 - Intel Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 19.033.0218.0009 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727 (HKLM-x32\...\{15134cb0-b767-4960-a911-f2d16ae54797}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727 (HKLM-x32\...\{22154f09-719a-4619-bb71-5b3356999fbf}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.14.26429 (HKLM-x32\...\{80586c77-db42-44bb-bfc8-7aebbb220c00}) (Version: 14.14.26429.4 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.14.26429 (HKLM-x32\...\{2019b6a0-8533-4a04-ac0e-b2c10bdb9841}) (Version: 14.14.26429.4 - Microsoft Corporation)
Mozilla Firefox 66.0.1 (x64 nl) (HKLM\...\Mozilla Firefox 66.0.1 (x64 nl)) (Version: 66.0.1 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 66.0.1 - Mozilla)
n52te Editor (HKLM-x32\...\{0AC8162B-5175-41D7-B963-8307A40BD456}) (Version: 5.01 - Razer USA Ltd.)
OpenOffice 4.1.5 (HKLM-x32\...\{6649DD88-354B-40C3-94D1-11178CF5CCB2}) (Version: 4.15.9789 - Apache Software Foundation)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.23.1003.2017 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8363 - Realtek Semiconductor Corp.)
Software voor Intel® Chipset-apparaten (HKLM-x32\...\{55d73ea7-6354-42db-8831-02d048ae57f8}) (Version: 10.1.17541.8066 - Intel(R) Corporation) Hidden
TITANWOLF GAUNTLET GAMING MOUSE (HKLM-x32\...\{F84C90F5-47CD-4354-8C4F-243CB74F3A7E}_is1) (Version: 1.0 - TITANWOLF)
Twitch (HKCU\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 8.0.0 - Twitch Interactive, Inc.)
Update for Windows 10 for x64-based Systems (KB4023057) (HKLM\...\{FBA3961B-D1DF-493C-BC1F-E67D3B832895}) (Version: 2.56.0.0 - Microsoft Corporation)
Update for Windows 10 for x64-based Systems (KB4480730) (HKLM\...\{344F3227-F502-4219-9DC4-1967E586FAFA}) (Version: 2.51.0.0 - Microsoft Corporation)
VLC media player (HKLM\...\VLC media player) (Version: 3.0.4 - VideoLAN)
VMware Player (HKLM\...\{B5D82DF0-AC2F-469F-8E97-599653947166}) (Version: 12.5.5 - VMware, Inc.)
Vulkan Run Time Libraries 1.0.39.1 (HKLM\...\VulkanRT1.0.39.1) (Version: 1.0.39.1 - LunarG, Inc.)
WinRAR archiver (HKLM-x32\...\WinRAR archiver) (Version: - )
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
========================= Devices: ================================
Name: Standaard PS/2-toetsenbord
Description: Standaard PS/2-toetsenbord
Class Guid: {4d36e96b-e325-11ce-bfc1-08002be10318}
Manufacturer: (standaardtoetsenbord)
Service: i8042prt
Device ID: ACPI\PNP0303\0
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Description: Microsoft-muis (PS/2)
Class Guid: {4d36e96f-e325-11ce-bfc1-08002be10318}
Manufacturer: Microsoft
Service: i8042prt
Device ID: ACPI\PNP0F03\0
========================= Memory info: ===================================
Percentage of memory in use: 40%
Total physical RAM: 8137.67 MB
Available physical RAM: 4874.05 MB
Total Virtual: 10057.67 MB
Available Virtual: 4707.12 MB
========================= Partitions: =====================================
1 Drive c: () (Fixed) (Total:465.16 GB) (Free:338.2 GB) NTFS
2 Drive d: () (Fixed) (Total:472.54 GB) (Free:375.95 GB) NTFS
3 Drive e: (G71-MID3028) (CDROM) (Total:6.66 GB) (Free:0 GB) CDFS
8 Drive j: (Data PC) (Fixed) (Total:458.37 GB) (Free:267.22 GB) NTFS
9 Drive n: () (Fixed) (Total:112.4 GB) (Free:19.87 GB) NTFS
========================= Users: ========================================
Gebruikersaccounts voor \\DESKTOP-P1BCU5T
Administrator Akasha DefaultAccount
Gast WDAGUtilityAccount
De opdracht is voltooid.
========================= Minidump Files ==================================
C:\WINDOWS\Minidump\032419-7015-01.dmp
C:\WINDOWS\Minidump\032419-7578-01.dmp
C:\WINDOWS\Minidump\032419-8171-01.dmp
C:\WINDOWS\Minidump\032419-8187-01.dmp
C:\WINDOWS\Minidump\032419-8359-01.dmp
========================= Restore Points ==================================
04-01-2019 22:29:19 Installatieprogramma voor Windows-modules
21-03-2019 22:27:56 Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501
22-03-2019 21:56:37 new
24-03-2019 19:04:20 Verwijderd Realtek High Definition Audio Driver
**** End of log ****
Beste antwoord (via Verwijderd op 05-08-2019 15:48)
  • ResuCigam
  • Laatst online: 26-10 15:34
ResuCigam
BOFH
Ik zou Memtest86+ op een usb stick zetten en die een nachtje laten draaien.
We do what we must because we can.
Even de BSOD opzoeken brengt je al een stuk verder.
https://www.startpage.com...01a&cat=web&pl=opensearch
Om "echt" te helpen mist veel info in je TS, om te beginnen
Mijn vraag
[ Voor 41% gewijzigd door Verwijderd op 25-03-2019 09:30 ]
Hallo Gero71,
Ja natuurlijk sorry.
BOSD meldingen die ik krijg zijn.
-Kernel security check failure
-Memory management
Motherboard : MSI B360M PRO-VDH
Geheugen : 8G DDR4-RAM
Videokaart : AMD RX 550
C schijf : Samsung Evo 970 plus 500G
Software : Windows 10 Home 64-bit
Programma's : Staat bij "installed programs"
Dingen die ik geprobeerd heb:
-SFC /scannow (als administrator met CMD) uitkomst: windows resource protection did not find any integrity violations.
-chkdsk /f /r (geen problemen)
-mdsched.exe (als administrator) geen problemen
Groet,
  • Beste antwoord ✓
  • ResuCigam
ResuCigam
BOFH
Kleine update.
Ik heb met BlueScreenView nog even gekeken en dit kwam naar voren.
Dump File : 032519-7750-01.dmp
Crash Time : 25-3-2019 14:08:12
Bug Check String : CRITICAL_PROCESS_DIED
Bug Check Code : 0x000000ef
Parameter 1 : ffff840f`dcd09080
Parameter 2 : 00000000`00000000
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1b35e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+1b35e0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\032519-7750-01.dmp
Processors Count : 6
Major Version : 15
Minor Version : 17763
Dump File Size : 549.444
Dump File Time : 25-3-2019 14:08:51
Vanavond draai ik een Memtest86+
Groet,
Hallo allemaal, bedankt voor jullie reactie.
De eind conclusie is dat het werkgeheugen van mijn net aangeschafte computer kapot was.
Omdat het niet duidelijk was welk programma of welke service verantwoordelijk was voor de crashes heeft een vriend van mij voorgesteld om het geheugen te vervangen.
Dit heeft het probleem opgelost.
Mijn problemen waren ( blauwscherm )
"ntfs.sys"
"system service exception"
"memory management error"
"Kernel security check failure"
Symptomen waren:
vorige Firefox tabbladen konden niet hersteld worden en Firefox crashte bij het opstarten.
"wattman settings error returned to default settings" (radeon videokaart programma)
Nogmaals bedankt voor de moeite !
Groet.
(aan de admin van deze site: dit topic mag verwijderd worden)
  • TheVMaster
  • Laatst online: 00:07
TheVMaster
Moderator WOS
Verwijderd schreef op Monday 5 August 2019 @ 15:45:
"ntfs.sys"
Symptomen waren:
Groet.
Misschien de volgende keer even wat meer onderzoek doen, dat scheelt het dumpen van een enorme log in een topic en dan hopen op hulp. We verwachten hier dat je ook zelf wat inzet toont en laat zien wat je allemaal hebt geprobeerd.
Mijn Apps: DiscVault - MealieShopper - SintMaarten
