Nieuw met Domoticz: html webpagina laden
Mijn vraag
ik ben nieuw met Domoticz. Aangezien Domoticz een draait op een webserver wil ik graag aan jullie wat vragen. Ik heb een eigen radiostation. Die verzameld statistieken. Deze statistieken wil ik graag weer geven op mijn dashboard
Dit is de code:
Current song: <a href="http://92.222.xx.xx:2199/tunein/hardstylefm.pls" class="cc_streaminfo" data-type="song" data-username="hardstylefm">Loading ...</a><br />
Stream title: <span class="cc_streaminfo" data-type="title" data-username="hardstylefm"></span><br />
Bit rate: <span class="cc_streaminfo" data-type="bitrate" data-username="hardstylefm"></span><br />
Current listeners: <span class="cc_streaminfo" data-type="listeners" data-username="hardstylefm"></span><br />
Maximum listeners: <span class="cc_streaminfo" data-type="maxlisteners" data-username="hardstylefm"></span><br />
Server status: <span class="cc_streaminfo" data-type="server" data-username="hardstylefm"></span><br />
AutoDJ status: <span class="cc_streaminfo" data-type="autodj" data-username="hardstylefm"></span><br />
Source connected: <span class="cc_streaminfo" data-type="source" data-username="hardstylefm"></span><br />
Station time: <span class="cc_streaminfo" data-type="date" data-username="hardstylefm"></span> <span class="cc_streaminfo" data-type="time" data-username="hardstylefm"></span><br />
Current playlist: <span class="cc_streaminfo" data-type="trackplaylist" data-username="hardstylefm"></span><br />
Track details: <span class="cc_streaminfo" data-type="trackartist" data-username="hardstylefm"></span> - <span class="cc_streaminfo" data-type="tracktitle" data-username="hardstylefm"></span> - <span class="cc_streaminfo" data-type="trackalbum" data-username="hardstylefm"></span><br />
Raw metadata: <span class="cc_streaminfo" data-type="rawmeta" data-username="hardstylefm"></span><br />
Album image:<br /><img class="cc_streaminfo" data-type="trackimageurl" data-username="hardstylefm" /><br /><a href="#" class="cc_streaminfo" data-type="trackbuyurl" data-username="hardstylefm">Buy this album</a><br />
deze lijn moet voor </body> geplaatst worden
<script language="javascript" type="text/javascript" src="http://92.222.xx.xx:2199/system/streaminfo.js"></script>
Het is mogelijk om dit via json aan te roepen
http://92.222.xx.xx:2199/rpc/hardstylefm/streaminfo.get
Domoticz , pi3 , radioserver centova extern gehost, aurora theme gebruik ik
geprobeerd met http poller maar kom er niet uit
Wat ik graag wil zien:
op mijn dashboard de informatie van de code hierboven. Dus zoals de sensoren op mijn dashboard weergegeven worden wil ik graag deze informatie er aan toevoegen
mvg
willem
  • jobr
  • Laatst online: 26-07-2025
Verwijderd schreef op vrijdag 22 maart 2019 @ 23:12:
Mijn vraag
Dit is de code:
Current song: <a href="http://92.222.36.40:2199/tunein/hardstylefm.pls" class="cc_streaminfo" data-type="song" data-username="hardstylefm">Loading ...</a><br />
<script language="javascript" type="text/javascript" src="http://92.222.36.40:2199/system/streaminfo.js"></script>
http://92.222.36.40:2199/rpc/hardstylefm/streaminfo.get
mvg
willem
Je zou de json met een dzVents kunnen uitlezen en de waarde in een sensor kunnen stoppen. Die kun je dan op je dashboard zetten zoals andere sensoren.
Als het heel veel statistieken zijn is dat misschien wat veel van het goede.
Je kan ook een text sensor gebruiken en daar van alles in proppen en die op het dashboard zetten.
Kijk ook eens naar dashticz. Misschien kan je daar wel zelf iets aan toevoegen.
Er is overigens ook een Domoticz topic.
