• sebastius
  • Laatst online: 00:13
sebastius
Laten we lekker link gaan doen
Although i'm a Dutch native i'm posting this topic in English to reach a wider audience. Please note that everything below is theoretical at this point, do NOT desolder your RAM just yet ;)
I'm still in love with my by now classic Macbook Pro early 2015 13". It's a wonderful little Macbook but two specs are becoming a bit... outdated and that is the disk-size and the amount of RAM. Mine came with 8 gigabytes worth of RAM (max was 16GB and that was way to expensive back then). A random google showed that it is actually possible to upgrade soldered RAM chips on some Macbooks, so now i'm investigating mine.
My inspiration was this video on Youtube:
But that is for a Macbook Air...
My Macbook is a A1502, 820-4924 board.
In the schematics we're off to a promising start:
Afbeeldingslocatie: https://revspace.nl/images/4/48/Mbproramupgrade00.png
So all different models of this macbook are done with the same logic board.
Afbeeldingslocatie: https://revspace.nl/images/1/15/Mbproramupgrade01.png
And apparently all models use 1866mhz DDR3, either by Hynix, Epida or Samsung
Afbeeldingslocatie: https://revspace.nl/images/3/34/Mbproramupgrade02.png
And you can configure the amount of RAM using some config-lines!
So this seems to be pretty straightforward. The different options of RAM are controlled by a few GPIO lines on the CPU which are either pulled high or low with a few resistors.
Afbeeldingslocatie: https://revspace.nl/images/4/43/Mbproramupgrade03.png
Afbeeldingslocatie: https://revspace.nl/images/5/56/Mbproramupgrade04.png
Now what model of RAM should we buy? Apple provides one type in the schematic:
Afbeeldingslocatie: https://revspace.nl/images/4/42/Mbproramupgrade05.png
LPDDR3-1600-32GB, EDFB232A1MA
Which leads to... A testing document by Intel in which they've tested compatibility of various RAM chips for the specific CPU i'm using:
Afbeeldingslocatie: https://revspace.nl/images/c/c5/Mbproramupgrade06.png
So i'll probably need either:
• Micron EDFB232A1MA-JD-F
• Samsung K4EBE304EB-EGCF
• Hynix H9CCNNNCLTMLAR-NUD
Another option is maybe the MT52L1G32D4PG-107 WT:B from Micron
And with a bit of puzzling i've figured out (i think) what each of the 4 configuration settings does:
Afbeeldingslocatie: https://revspace.nl/images/d/df/Mbproramupgrade07.png
My questions now: is my reasoning correct in assuming the three chips i've mentioned will probably fit and work? Where can i obtain these chips?
Feel free to reply in Dutch :)
[ Voor 4% gewijzigd door sebastius op 03-03-2019 21:50 ]
  • rvanpruissen
  • Laatst online: 29-08 17:05
rvanpruissen
rePear.it
Tof project, maar ik zou er (als ervaren Apple soldeerder) niet aan beginnen:
1. Het is lastig om aan deze chips te komen van een betrouwbare bron.
2. Je moet zoveel warmte toevoegen aan het bord, dat de kans aanwezig is dat je iets anders sloopt (dichtbij CPU bijvoorbeeld). Dit is me het risico niet waard.
3. De kans dat er wat mis gaat met het solderen van 16 BGA chips met ±100 verbindingen per stuk is vrij hoog. Hoe vindt je uit wat er mis is gegaan mocht het zover komen?
  • sebastius
sebastius
rvanpruissen schreef op zondag 3 maart 2019 @ 22:14:
Als mede ervaren soldeerder heb ik daar ook wel antwoord op:
1) Dit is m'n enige issue
2) Valt wel mee hoor :)
3) Het zijn er maar 4. En als het faalt zet ik de oude chips terug of schrap ik de laptop. Leergeld.
  • mux
  • Laatst online: 04-11 10:40
mux
99% efficient!
Met RAM moet je vooral opletten dat de bit width hetzelfde is per package en, wanneer er meerdere dies op elkaar liggen, dat de controller daarmee kan omgaan. Dat lijkt hier geen probleem, gezien alles tot quad chip packages blijkbaar compatibel zijn. Aantal pins is hetzelfde, RAM type is hetzelfde... tja, gaan met de banaan.
Die logic lines bepalen niet zozeer de hoeveelheid RAM als wel het aantal dies dat wordt geaddresseerd. Dat komt niet altijd op hetzelfde neer; je kunt misschien zowel 32Gbit als 64Gbit quad die 178-pin LPDDR3 vinden.
Ik heb een tijdje terug chips van Kynix getrokken, die waren genuine en pasten in mijn Cube i7 Stylus chinese windows-tablet.
  • sebastius
sebastius
Zo, een dag verder en de stoute schoenen aangedaan op Alibaba… Ik heb 4x H9CCNNNCLTMLAR-NUD besteld, 120 dollar incl DHL shipping (zal dus nog wel een "boete" op komen van de douane).
  • jbhc
  • Laatst online: 16-11 11:07
Kan die amerikaanse apple reparateur de ic's niet leveren?
/edit: Ik bedoel Luis Rossmann
[ Voor 22% gewijzigd door jbhc op 05-03-2019 16:52 ]
  • rvanpruissen
rvanpruissen
rePear.it
jbhc schreef op dinsdag 5 maart 2019 @ 16:49:
Nee, die brandt hier zijn vingers ook niet aan :) Wellicht dat mijn eerdere post daarom wat pessimistisch overkwam: als hobby is dit een vet project, als je er geld mee moet verdienen is het risico waarschijnlijk te groot.
Succes @sebastius ik ben beniewd naar het resultaat!
  • PLeX
  • Laatst online: 24-11-2025
Petje af dat je er aan begint!
P.s. een Rossman-style Youtube video waarin we je learnings kunnen volgens zou ook wel tof zijn!
[ Voor 62% gewijzigd door PLeX op 08-03-2019 12:13 ]
Hoi.
  • Wh4ck0
  • Laatst online: 12-11 07:21
sebastius schreef op maandag 4 maart 2019 @ 14:37:
Hallo Sebastius,
Ik ben benieuwd of je deze upgrade nog hebt uitgevoerd en of deze succesvol was?
Ik heb namelijk ook een MBP uit 2015.
Door een opgezwollen accu is de ram chip losgeraakt of beschadigd. Apple en reparatiebedrijven branden zich hier niet aan, en zou volledige vervanging van het moederbord betekenen. en dat is behoorlijk prijzig. Dus vroeg me af of dit een mogelijkheid is, misschien reflowen of iets dergelijks.
  • sebastius
sebastius
Ik heb de chips gekocht maar ik heb er niks meer mee gedaan. Durfde niet.
  • Wh4ck0
sebastius schreef op woensdag 3 februari 2021 @ 13:23:
Thanks voor je snelle antwoord.
Kan me voorstellen dat het inderdaad nog een drempel is ja. Ik ga eens kijken of ik iemand kan vinden die het aandurft. Ding is hoe dan ook nutteloos en garantie krijg ik al niet meer helaas.
  • sebastius
sebastius
Oh ik durf het met iemand anders z’n dode hardware wel aan, alleen niet met een werkend exemplaar :)
  • kitao
  • Laatst online: 11:46
Mijn ram is maar 128 bytes :'(
Afbeeldingslocatie: https://tweakers.net/i/ly0aSTeNX6rwyqw3d-uj2k6HSMw=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/4jpRjKExmM0CH1WVLbYKLgSx.jpg?f=user_large
kitao in "Het grote 'breadbord computer' topic"
Virtueel valt er weinig te slopen :P
Hi Bas, alles kits? ;)
