123 ERRORS LAPTOP SCAN BURNIN SOFTWARE ASUS GAMER Overzicht Laatste deel
  • 2.028 views
  • digidokter.net
  • Laatst online: 07-01-2024
digidokter.net
... en 'Niets' van 'Alles' LOL
@Verwijderd
Kunnen jullie me helpen de fouten op te lossen?! _/-\o_
PassMark BurnInTest Log file - https://www.passmark.com
Date: Thu Feb 28 02:27:25 2019
BurnInTest V9.0 Pro 1013 (64-bit)
*** Unlicensed trial version ***
System summary:
Windows 10 build 17763 (64-bit),
1 x Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz,
7.9GB RAM,
Intel(R) HD Graphics 530, NVIDIA GeForce GTX 960M (Mobile),
932GB HDD,
CD-RW/DVDRW,
General:
System Name: XXX
Motherboard Manufacturer: ASUSTeK COMPUTER INC.
Motherboard Name: GL552VW
Motherboard Version: 1.0
BIOS Manufacturer: American Megatrends Inc.
BIOS Version: GL552VW.300
BIOS Release Date: 09/06/2016
BIOS Serial Number: G1N0CV01T074539
TPM: Available, V2.0
Battery 1: ASUSTeK, Design Capacity: 48240 mWh [SN: ]
Webcam USB2.0 HD UVC WebCam
CPU:
CPU manufacturer: GenuineIntel
CPU Type: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Codename: Skylake
CPUID: Family 6, Model 5E, Stepping 3
Socket: LGA 1151
Lithography: 14nm
Physical CPU's: 1
Cores per CPU: 4
Hyperthreading: Enabled
CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX Turbo AES AVX AVX2 FMA3
Clock frequencies:
- Measured CPU speed: 2592.1 MHz [Turbo: 3290.0MHz]
- Multiplier: x26.0 [Turbo: x33.0]
- Base Clock: 100.0 MHz
- Multiplier range: Min: x8, Max non turbo: x26 [Ratio: 4C: x31, 3C: x32, 2C: x33, 1C: x35]
Cache per CPU package:
- L1 Instruction Cache: 4 x 32 KB
- L1 data cache: 4 x 32 KB
- L2 cache: 4 x 256 KB
- L3 cache: 6 MB
Memory
Total Physical Memory: 8088MB
Available Physical Memory: 3436MB
Memory devices:
Slot 1:
- 4GB DDR4 SDRAM PC4-17000
- Samsung M471A5143DB0-CPB, wk/yr: 46/2015
- 1.2V, Clk: 1066.7MHz, Timings 15-15-15-36 (@ Max. freq.)
Slot 2:
Slot 3:
- Not populated
Slot 4:
- Not populated
Virtual memory: pagefile.sys (allocated base size 1232MB)
Virtual memory: pagefile.sys (allocated base size 4000MB)
Memory SPD:
DIMM#0
Memory type: DDR4 SDRAM
SPD revision: 1.0
Manufacturer: Samsung
Manufacturing date: Year: 2015, Week: 46
Serial number: 9218FA40
Part number: M471A5143DB0-CPB
Clock speed: 1066.7 MHz
Memory size: 4096 MB
ECC: No
Module voltage: 1.2V
DIMM#1
SPD revision: 1.0
Serial number: 9218FB00
ECC: No
Graphics
Chip Type: Intel(R) HD Graphics Family
DAC Type: Internal
Memory: 1024MB
BIOS: Intel Video BIOS
Driver provider: Intel Corporation
Driver version: 21.20.16.4550
Driver date: 11-11-2016
Monitor 1: 1920x1080x32 60Hz 96 DPI (Primary monitor)
Chip Type: 0x139B
DAC Type: Integrated RAMDAC
Memory: 2047MB
BIOS: 82.07.97.00.0e
Driver provider: NVIDIA
Driver version: 398.35
Driver date: 6-21-2018
Disk volumes
C: Local Drive, \\?\Volume{247343f5-bc19-4111-b76f-d6e483dece25}\, ONVEILIGSYS, NTFS, (29.30GB total, 0.51GB free)
D: Local Drive, \\?\Volume{89ae2285-0000-0000-0000-100000000000}\, BACKUPS, NTFS, (1863.02GB total, 444.34GB free)
E: Local Drive, \\?\Volume{fa4e6a72-e80a-4292-ba72-23fae497716d}\, ONEDRIVE, NTFS, (28.19GB total, 23.86GB free)
G: Optical drive, \\?\Volume{40baedb1-017e-11e9-a391-806e6f6e6963}\
H: Removable
I: Local Drive, \\?\Volume{68769c2f-898f-46e8-ac04-a1f0b7c19a3e}\, DOCONEDRIVEBELANGRIJK, NTFS
T: Local Drive, \\?\Volume{f17114bc-3cde-45ed-80ae-64fb4ac5fb2d}\, RAID398DOC, FAT32
U: Local Drive, \\?\Volume{751c78b6-643d-4c6a-9aed-464f8989ab27}\, RAID976DOC, NTFS, (976.56GB total, 0.05GB free)
V: Local Drive, \\?\Volume{2b69389c-8df2-4271-bf8f-f4fd6f93962e}\, RAID97DOC, NTFS, (97.66GB total, 26.88GB free)
W: Local Drive, \\?\Volume{de781094-366c-431b-813a-a25be14009d0}\, 105GBDOWNLOADA, NTFS, (97.66GB total, 0.00GB free)
X: Local Drive, \\?\Volume{61fce452-0fc9-4aae-ab7b-b76a93f680a4}\, RAID96DOC, NTFS, (97.66GB total, 97.56GB free)
Y: Local Drive, \\?\Volume{9bf6207c-fe9e-4144-a036-5dcae548491a}\, RAID195DOC, NTFS, (195.31GB total, 86.17GB free)
Z: Local Drive, \\?\Volume{7b69e494-bb58-462c-a737-0dce1a0f52ac}\, SYSTEEM.OLD.BK.KODIAPPSCONFIG, NTFS, (29.30GB total, 4.79GB free)
Disk drives
Schijfstation: Model: SDHC Card Serial: N/A (Disk: 2, Size: 29.72GB, Interface: N/A, Volumes: N/A)
Schijfstation: Model: TOSHIBA External USB 3.0 USB Device Serial: 77L2T0PZT (Disk: 1, Size: 1863.01GB, Interface: USB, Volumes: T U V W X Y)
Schijfstation: Model: HGST HTS721010A9E630 Serial: JR10004M0K1A7F (Disk: 0, Size: 931.51GB, Interface: SATA, Volumes: C E I Z)
Schijfstation: Model: TOSHIBA External USB 3.0 USB Device Serial: 87M2T4A4T (Disk: 3, Size: 1863.01GB, Interface: USB, Volumes: D)
Optical drives
G: Slimtype DVD A DA8A6SH (CD-RW/DVDRW)
Network
Realtek PCIe GBE Family Controller
Intel(R) Dual Band Wireless-AC 7265 (Speed: 866Mb/s)
Ports
USB
USB xHCI-compatibele hostcontroller
- Logitech USB Receiver
- Intel(R) Wireless Bluetooth(R)
- TOSHIBA External USB 3.0 (SN: 20170721024989F)
- TOSHIBA External USB 3.0 (SN: 20170822002887F)
RESULT SUMMARY
Test Start time: - (Accumulated results start time: Thu Feb 28 02:17:40 2019)
Test Stop time: - (Accumulated results stop time: Thu Feb 28 02:20:57 2019)
Test Duration: - (Accumulated results duration: 000h 03m 17s)
Temperature CPU 0 average (Min/Current/Max): 49.5C / 84.0C / 85.3C
Temperature CPU 0 core 0 (Min/Current/Max): 49.0C / 83.0C / 86.0C
Temperature CPU 0 core 1 (Min/Current/Max): 53.0C / 92.0C / 92.0C
Temperature CPU 0 core 2 (Min/Current/Max): 48.0C / 77.0C / 79.0C
Temperature CPU 0 core 3 (Min/Current/Max): 48.0C / 84.0C / 84.0C
Temperature HDD 0 (HGST HTS721010A9E630) (Min/Current/Max): 37.0C / 38.0C / 38.0C
Temperature HDD 1 (TOSHIBA External USB 3.0 USB Device) (Min/Current/Max): NA / NA / NA
Temperature HDD 3 (TOSHIBA External USB 3.0 USB Device) (Min/Current/Max): NA / NA / NA
Battery 1:
Unique ID: ASUSTeKASUS Battery Manufacturer: ASUSTeK [Serial number: ]
Designed capacity: 48240 mWh Capacity: 35467 mWh Voltage: 14400mV Charge Rate: -288mW Status: N/A
Afbeeldingslocatie: https://i.imgur.com/yqB0D6J.jpg
TEST RUN FAILED
DETAILED EVENT LOG
LOG NOTE: 2019-02-28 02:16:45, Status, Webcam pre-test started
LOG NOTE: 2019-02-28 02:17:04, Status, Microphone pre-test started
LOG NOTE: 2019-02-28 02:17:12, Microphone, Recording from Stereo-mix (Conexant SmartAudio HD)
LOG NOTE: 2019-02-28 02:17:12, Microphone, Selected format: 2 Channel 48.0 kHz 32 bits per sample
LOG NOTE: 2019-02-28 02:17:37, Microphone, Microphone test passed
LOG NOTE: 2019-02-28 02:17:37, Status, Battery pre-test started
LOG NOTE: 2019-02-28 02:17:38, Battery, Battery test using full capacity based threshold
SERIOUS: 2019-02-28 02:17:39, Battery, Battery threshold exceeded error
LOG NOTE: 2019-02-28 02:17:39, Battery, Battery: 1 - Threshold exceeded (Design Capacity: 48240 mWh - Full Capacity: 35467 mWh)
LOG NOTE: 2019-02-28 02:17:39, Status, TPM pre-test started
SERIOUS: 2019-02-28 02:17:39, TPM, TPM self test command blocked
LOG NOTE: 2019-02-28 02:17:41, Status, Main Tests started
https://nl.wikipedia.org/wiki/Trusted_Platform_Module
De chip zal als een vast token gebruikt worden. De chip wordt meestal geïnstalleerd op het moederbord van de computer of laptop. De TPM-chip zorgt ervoor dat de informatie die erop wordt bewaard, veilig is. De beveiliging wordt gerealiseerd door het TCG-subsysteem (Trusted Computing Group).
De TPM-chip wordt gebruikt als opslagelement voor cryptografische sleutels en certificaten. Al wat nodig is om het platform (pc, laptop …) te authenticeren, zal op de TPM-chip worden opgeslagen. Ook het versleutelen van volledige harde schijven kan worden gedaan met een TPM-chip.
Voordelen[bewerken]
Minder kwetsbaar voor fysieke en virtuele aanvallen
Flexibel, op veel verschillende platformen bruikbaar
Elke TPM-chip heeft een unieke en geheime RSA-sleutel waardoor de TPM de computer of mediaspeler authenticeert en niet de gebruiker
Nadelen[bewerken]
Als het moederbord waarop de chip geïnstalleerd is, kapot gaat, is het niet mogelijk om je versleutelde gegevens terug op te halen tenzij de decryption key op een andere locatie geback-upt is. Dit wordt ook wel een recovery agent genoemd.
Mijn TMP optie heb ik in bios aanstaan wellicht daarom deze melding?!
LOG NOTE: 2019-02-28 02:17:41, 3D Graphics, 3D test starting: Duty cycle = 50. Test on primary monitor (0). (x,y) = (0,0). WxH = 1920x1080.
LOG NOTE: 2019-02-28 02:17:41, 3D Graphics, Starting DX12 Test
LOG NOTE: 2019-02-28 02:17:41, 3D Graphics, 3D test starting: Duty cycle = 50. Test on monitor number 1. (x,y) = (20,20). WxH = 1920x1080.
LOG NOTE: 2019-02-28 02:17:42, 3D Graphics, 3D test starting: Duty cycle = 50. Test on monitor number 2. (x,y) = (40,40). WxH = 1920x1080.
LOG NOTE: 2019-02-28 02:17:42, 3D Graphics, Starting DX12 Test
LOG NOTE: 2019-02-28 02:17:42, 3D Graphics, 3D test starting: Duty cycle = 50. Test on monitor number 3. (x,y) = (60,60). WxH = 1920x1080.
WARNING: 2019-02-28 02:17:42, Optical disk, G: Could not determine type of Passmark test CD/DVD
Heb getest met audio cd, snap de fout niet?!
CRITICAL: 2019-02-28 02:17:43, PCIe, Could not detect PCIe loopback card: PCIe 0
https://nl.wikipedia.org/wiki/PCI_Express
Deze was disabled
LOG NOTE: 2019-02-28 02:17:43, Battery, Battery test using full capacity based threshold
SERIOUS: 2019-02-28 02:17:43, Tape drive, Could not access the tape drive selected
Is niet aanwezig.
CRITICAL: 2019-02-28 02:17:43, USB, Could not detect USB loopback plug: USB 1 Plug: -1
Is aanwezig kan waarde -1 niet vinden (google etc.) Wat is betekenis?!
WARNING: 2019-02-28 02:17:43, Disk, C: Not enough free disk space
WARNING: 2019-02-28 02:17:44, Disk, I: Not enough free disk space
WARNING: 2019-02-28 02:17:44, Disk, T: Not enough free disk space
WARNING: 2019-02-28 02:17:44, Disk, U: Not enough free disk space
Vrijgemaakt ruimte op disks
SERIOUS: 2019-02-28 02:17:44, Serial, The requested COM port could not be found
Niet aanwezig
WARNING: 2019-02-28 02:17:44, Parallel, Configured Parallel port does not exist
Niet aanwezig
LOG NOTE: 2019-02-28 02:17:44, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
Niet aanwezig
WARNING: 2019-02-28 02:17:44, Disk, W: Not enough free disk space
Vrijgemaakt ruimte disk
SERIOUS: 2019-02-28 02:17:44, Battery, Battery threshold exceeded error
LOG NOTE: 2019-02-28 02:17:44, Battery, Battery: 1 - Threshold exceeded (Design Capacity: 48240 mWh - Full Capacity: 35467 mWh)
[url="https://translate.google.com/translate?hl=nl&sl=auto&tl=nl&u=https%3A%2F%2Fwiki.osdev.org%2FEnhanced_Host_Controller_Interface[/url]
Weet niet waarom?! Of hoe dit komt, graag feedback...
WARNING: 2019-02-28 02:17:45, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:17:48, Optical disk, G: Could not determine type of Passmark test CD/DVD
audiocd, snap het niet?!
SERIOUS: 2019-02-28 02:17:52, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:17:52, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
Disabled klopt
WARNING: 2019-02-28 02:17:54, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:17:57, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:01, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:18:01, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
Disabled
WARNING: 2019-02-28 02:18:03, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:18:06, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:10, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:18:10, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
Disabled
WARNING: 2019-02-28 02:18:12, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:13, Tape drive, Could not access the tape drive selected
WARNING: 2019-02-28 02:18:14, Parallel, Configured Parallel port does not exist
SERIOUS: 2019-02-28 02:18:15, Serial, The requested COM port could not be found
LOG NOTE: 2019-02-28 02:18:15, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
Zoals genoemd
WARNING: 2019-02-28 02:18:15, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:18:18, Optical disk, G: Could not determine type of Passmark test CD/DVD
WIFI werkt maar LAN disabled, heeft dat ermee te maken?!
Disabled
Disabled
Disabled
Disabled
WARNING: 2019-02-28 02:18:30, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:18:33, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:38, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:18:38, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:18:39, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:18:42, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:44, Tape drive, Could not access the tape drive selected
Niet aanwezig
WARNING: 2019-02-28 02:18:45, Parallel, Configured Parallel port does not exist
LOG NOTE: 2019-02-28 02:18:45, Battery, Battery test using full capacity based threshold
WARNING: 2019-02-28 02:18:45, Optical disk, G: Could not determine type of Passmark test CD/DVD
audiocd, snap het niet?! De rest is bekend
SERIOUS: 2019-02-28 02:18:46, Battery, Battery threshold exceeded error
LOG NOTE: 2019-02-28 02:18:46, Battery, Battery: 1 - Threshold exceeded (Design Capacity: 48240 mWh - Full Capacity: 35467 mWh)
LOG NOTE: 2019-02-28 02:18:46, Memory (RAM), System Memory Total: 8087MB, Test RAM allocated: 0MB, Available: 783MB
SERIOUS: 2019-02-28 02:18:46, Serial, The requested COM port could not be found
Klopt niet aanwezig
LOG NOTE: 2019-02-28 02:18:46, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
SERIOUS: 2019-02-28 02:18:47, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:18:47, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:18:48, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:18:51, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:18:56, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:18:56, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:18:57, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:00, Optical disk, G: Could not determine type of Passmark test CD/DVD
Disabled
SERIOUS: 2019-02-28 02:19:05, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:19:05, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:06, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:10, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:15, Tape drive, Could not access the tape drive selected
SERIOUS: 2019-02-28 02:19:15, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:19:15, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:16, Parallel, Configured Parallel port does not exist
WARNING: 2019-02-28 02:19:16, Optical disk, G: Could not determine type of Passmark test CD/DVD
audiocd, snap het niet?! rest disabled
SERIOUS: 2019-02-28 02:19:18, Serial, The requested COM port could not be found
LOG NOTE: 2019-02-28 02:19:18, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
WARNING: 2019-02-28 02:19:19, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:22, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:24, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:19:24, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:25, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:28, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:33, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:19:33, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:34, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:37, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:43, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:19:43, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:43, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:46, Tape drive, Could not access the tape drive selected
WARNING: 2019-02-28 02:19:46, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:46, Parallel, Configured Parallel port does not exist
LOG NOTE: 2019-02-28 02:19:47, Battery, Battery test using full capacity based threshold
audiocd, snap het niet?! Rest is bekend disabled
SERIOUS: 2019-02-28 02:19:48, Battery, Battery threshold exceeded error
Bekend
LOG NOTE: 2019-02-28 02:19:48, Battery, Battery: 1 - Threshold exceeded (Design Capacity: 48240 mWh - Full Capacity: 35467 mWh)
WARNING: 2019-02-28 02:19:49, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:19:50, Serial, The requested COM port could not be found
LOG NOTE: 2019-02-28 02:19:50, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
Klopt niet aanwezig
SERIOUS: 2019-02-28 02:19:52, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:19:52, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:19:52, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:19:55, Optical disk, G: Could not determine type of Passmark test CD/DVD
Disabled en audiocd, snap het niet?!
SERIOUS: 2019-02-28 02:20:01, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:20:01, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:20:01, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:20:04, Optical disk, G: Could not determine type of Passmark test CD/DVD
Disabled& audiocd, snap het niet?!
SERIOUS: 2019-02-28 02:20:11, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:20:11, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:20:14, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:16, Tape drive, Could not access the tape drive selected
Disabled
WARNING: 2019-02-28 02:20:17, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:20:17, Parallel, Configured Parallel port does not exist
WARNING: 2019-02-28 02:20:20, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:20, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:20:20, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
Disabled
SERIOUS: 2019-02-28 02:20:22, Serial, The requested COM port could not be found
LOG NOTE: 2019-02-28 02:20:22, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
WARNING: 2019-02-28 02:20:23, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:20:26, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:29, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:20:29, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:20:32, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:20:35, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:38, Bluetooth, Error searching for Bluetooth device.
Disabled
LOG NOTE: 2019-02-28 02:20:38, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:20:41, Optical disk, G: Could not determine type of Passmark test CD/DVD
WARNING: 2019-02-28 02:20:44, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:47, Tape drive, Could not access the tape drive selected
Niet aanwezig
WARNING: 2019-02-28 02:20:47, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:48, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:20:48, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
WARNING: 2019-02-28 02:20:48, Parallel, Configured Parallel port does not exist
LOG NOTE: 2019-02-28 02:20:50, Battery, Battery test using full capacity based threshold
WARNING: 2019-02-28 02:20:50, Optical disk, G: Could not determine type of Passmark test CD/DVD
Besproken & audiocd, snap het niet?!
SERIOUS: 2019-02-28 02:20:51, Battery, Battery threshold exceeded error
Bekend
LOG NOTE: 2019-02-28 02:20:51, Battery, Battery: 1 - Threshold exceeded (Design Capacity: 48240 mWh - Full Capacity: 35467 mWh)
WARNING: 2019-02-28 02:20:53, Optical disk, G: Could not determine type of Passmark test CD/DVD
SERIOUS: 2019-02-28 02:20:53, Serial, The requested COM port could not be found
Niet aanwezig
LOG NOTE: 2019-02-28 02:20:53, Serial, Het systeem kan het opgegeven bestand niet vinden. (2)
CRITICAL: 2019-02-28 02:20:56, Temperature, Temperature threshold exceeded
Snap het niet 50 graden is max hij kan tot 90 graden
WARNING: 2019-02-28 02:20:56, Optical disk, G: Could not determine type of Passmark test CD/DVD
LOG NOTE: 2019-02-28 02:20:56, BurnInTest, Temperature CPU 0 core 1: Current 92.0C / Threshold 90.0C
LOG NOTE: 2019-02-28 02:20:56, BurnInTest, Stopping tests due to high temperature
SERIOUS: 2019-02-28 02:20:57, Bluetooth, Error searching for Bluetooth device.
LOG NOTE: 2019-02-28 02:20:57, Bluetooth, Please check your BlueTooth device is ready to accept a connection: 10108
LOG NOTE: 2019-02-28 02:21:00, GPGPU, GPGPU ops for NVIDIA GeForce GTX 960M: 10237.01 billion
LOG NOTE: 2019-02-28 02:21:00, GPGPU, GPGPU ops for Intel(R) HD Graphics 530: 8024.47 billion
SERIOUS: 2019-02-28 02:21:35, Memory (RAM), No operations during test period
LOG NOTE: 2019-02-28 02:21:35, Status, Test run stopped
LOG NOTE: 2019-02-28 02:21:36, BurnInTest, BurnInTest was unable to send a result message to the Management Console.
Meeste errors zijn van disabled componenten. Bij de rest heb ik hierboven vragen gesteld, hoop dat jullie feedback kunnen geven aan deze noob LOL :? 8)7 |:( O-)
Verstand van 'Alles' van 'Niets'
  • br00ky
  • Laatst online: 08:29
br00ky
(jarig!)
Ik stel voor dat je een nieuw topic opent met;
1. Een normale titel zonder een overdaad aan hoofdletters.
2. Een duidelijke vraagstelling.
3. Zonder allerlei quotes en copy-pastes van Wikipedia die er niet toe doen.
In je huidige topicstart staat zoveel dat het onmogelijk is geworden eruit te halen wat je nou precies wil.
