ATmega2560 + sd kaart initialization failed
  • Jboy1991
  • Laatst online: 00:43
Goedendag Tweakers,
Voor een leuk led projectje heb ik een sdcard module nodig. Deze heb ik inmiddels binnen gekregen. Alleen ik krijg steeds de volgende error:
14:10:09.637 -> Initializing SD card...initialization failed. Things to check:
14:10:11.681 -> * is a card inserted?
14:10:11.681 -> * is your wiring correct?
14:10:11.681 -> * did you change the chipSelect pin to match your shield or module?
14:10:14.425 ->
14:10:14.425 -> Soft WDT reset
14:10:14.425 ->
14:10:14.425 -> >>>stack>>>
14:10:14.425 ->
14:10:14.425 -> ctx: cont
14:10:14.459 -> sp: 3ffffde0 end: 3fffffc0 offset: 01b0
14:10:14.494 -> 3fffff90: feefeffe feefeffe feefeffe 3ffeea20
14:10:14.561 -> 3fffffa0: 3fffdad0 00000000 3ffee9ec 40205158
14:10:14.595 -> 3fffffb0: feefeffe feefeffe 3ffe85d8 40100981
Ik heb het aangesloten op de volgende manier:
Afbeeldingslocatie: https://4.bp.blogspot.com/-SyYsDrjrQ1Q/VV9olE2tBlI/AAAAAAAAGiU/Jqmkrpd9Lko/s1600/sd_card_module.png
De code die ik gebruik is het volgende:
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 53;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
pinMode(chipSelect, OUTPUT);
digitalWrite(chipSelect, HIGH); // Add this line
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
while (1);
} else {
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.println();
Serial.print("Card type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
while (1);
Serial.print("Clusters: ");
Serial.println(volume.clusterCount());
Serial.print("Blocks x Cluster: ");
Serial.println(volume.blocksPerCluster());
Serial.print("Total Blocks: ");
Serial.println(volume.blocksPerCluster() * volume.clusterCount());
Serial.println();
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("Volume type is: FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize /= 2; // SD card blocks are always 512 bytes (2 blocks are 1KB)
Serial.print("Volume size (Kb): ");
Serial.println(volumesize);
Serial.print("Volume size (Mb): ");
volumesize /= 1024;
Serial.print("Volume size (Gb): ");
Serial.println((float)volumesize / 1024.0);
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
En ik gebruik de volgende board en volgende sd module:
Board: https://nl.aliexpress.com...042311.0.0.8e2f4c4dNts1hb
sdcard module:
https://www.hobbyelectron...odule-lezenschrijven-spi/
Doe ik iets verkeerds? of zie ik iets over het hoofd?
Ben al de hele ochtend en begin van de middag aan het googlen en heb na mijn idee alles al geprobeerd.
de sdcard is 2gb en geformatteerd naar Fat32
Drukte te vroeg op enter, excuus voor de wazige titel. Heb al aan mod gevraagd dit te wijzigen.
  • Microkid
  • Laatst online: 10:36
Microkid
Smile
De code gaat uit van:
Ik zie dat jij e.e.a. hebt aangesloten op 50, 51, 52. Wellicht daar eens beginnen?
  • Jboy1991
Microkid schreef op zaterdag 19 januari 2019 @ 14:41:
Ik had het in eerste instantie ook aangesloten via de poorten die jij opnoemt. Alleen zijn deze poorten niet voor de Mega (kwam ik dus achter na lang googlen).
Ik kwam dus uit op deze site:
http://www.galaxysofts.co...ino-using-sd-card-module/
Update:
inmiddels het met een arduino mega geprobeerd en daar werkt het wel op. Er moet dus iets mis zijn met deze board. Iemand een idee wat het probleem kan zijn?
[ Voor 11% gewijzigd door Jboy1991 op 19-01-2019 15:49 ]
  • Damic
  • Laatst online: 10:05
Damic
Tijd voor Jasmijn thee
@Microkid de pinnen van atmega2560 en uno zijn anders ;)
@Jboy1991 Die snap ik niet je hebt het geprobeerd op een atmega2560 bord en daar werkt het wel op? Ik lees het waarschijnlijk verkeerd.
  • Vuikie
  • Laatst online: 22-10 21:12
@Jboy1991
Je hebt jouw'n shield al getest op een andere Arduino, dus die werkt. Dan is zijn er, naar mijn mening, 2 opties. OF je hebt toch iets fout in de bedrading OF er is 1 van de pinnen defect op jouw'n Mega2560.
Heb je al geprobeerd op een ledje op poorten 50, 51, 52 en 53 te laten knipperen? Of een input test gedaan op die poorten?
  • Tom-Z
  • Laatst online: 14-10 02:27
Poort 53 op de AtMega2560 is SS, ofwel Slave Select. Die pin kun je als je SPI gebruikt eigenlijk niet gebruiken, omdat als die pin laag gaat, de AtMega2560 als slave gaat werken (en in dit geval moet hij juist master zijn). Gebruik een willekeurige andere pin om CS aan te sturen.
Edit: dit klopt niet helemaal. Je kan de SS pin niet als input gebruiken terwijl je in master mode zit, maar als output mag kennelijk wel.
[ Voor 21% gewijzigd door Tom-Z op 19-01-2019 17:21 ]
  • Rowwan
  • Laatst online: 24-10 21:18
Dit klopt inderdaad niet helemaal. SS (Slave Select) of CS (Chip Select) wordt bij (zowat) elke SPI communicatie gebruikt. De master heeft per SPI device (want dit is een bus systeem) een SS. Dit wordt gebruikt om de Slave te selecteren. De Slave luistert naar deze pin. Als de pin niet getoggled wordt, is het dus bedoeld voor een andere slave.
Het is niet zo dat de master ineens een Slave wordt :)
[ Voor 7% gewijzigd door Rowwan op 19-01-2019 17:28 ]
  • Tom-Z
Rowwan schreef op zaterdag 19 januari 2019 @ 17:27:
Dé SS pin van de AtMega2560 is bedoeld voor als de AtMega zelf slave is. In master mode heeft de pin geen speciale functie en kan je iedere willekeurige pin gebruiken om de SS pin van de slave aan te sturen. Er is eigenlijk geen enkele reden om SS te prefereren boven een willekeurige andere pin.
Dat kan wel degelijk gebeuren. Gebruik van de SS pin in master mode kan conflicten opleveren:
If the SS pin is driven low by peripheral circuitry when the SPI is configured as a Master with the SS pin defined as an input, the SPI system interprets this as another master selecting the SPI as a slave and starting to send data to it. To avoid bus contention, the SPI system takes the following actions:
1. The MSTR bit in SPCR is cleared and the SPI system becomes a Slave. As a result of the SPI becoming a Slave, the MOSI and SCK pins become inputs.
Zolang je de SS pin als output gebruikt zou dit niet moeten gebeuren (en dat is hier, als het goed is, het geval), maar ik heb wel eens problemen gehad dat SPI niet goed werkte omdat ik dé SS pin gebruikte. Ik dacht dat dat hier het geval zou kunnen zijn, maar dat is kennelijk alleen bij gebruik als input.
  • Rowwan
Klopt helemaal, maar in dit verhaal wordt de pin als output gebruikt. Je kunt ook eens proberen om de pinnen op de header in het midden te gebruiken (ICSP). Zou ook niks uit mogen maken, maar dan kun je uitsluiten dat het aan de spoortjes zelf ligt.
  • Jboy1991
inmiddels led blink test gedaan op verschillende pinnen. En helaas doet hij het op geen enkele pin.
  • Vuikie
Jboy1991 schreef op zaterdag 19 januari 2019 @ 18:31:
Dat klinkt niet goed...
Doen alle pinnen die je probeert het niet? Of doen alleen de spi-pinnen het niet? En andere programma's? Zoals de seriële test, doet die het wel?
Misschien ligt het probleem breder dan alleen je sd-kaart programma.
  • Rowwan
Het programmeren zelf gaat wel goed? Zie je tijdens het programmeren ergens wat ledjes knipperen?
  • Jboy1991
Rowwan schreef op zaterdag 19 januari 2019 @ 19:30:
Neem aan van wel. Sketch word gewoon geüpload en op het board blinken de standaard lichtjes.
Het aparte is dat ik pin 53,15,11,10,8 en 3 heb geprobeerd. En bij geen enkele ging de led aan. (En ja ik heb natuurlijk ook de pinnummer gewijzigd in de source)
  • TomsDiner
  • Registratie: November 2014
  • Laatst online: 18-07-2025
Maar heb je wel zicht op "of het programma loopt?" Het is met Arduino's -bij mij althans- vaak prima mogelijk om code te schrijven die te compileren is zonder fouten, maar op het board zelf niet werkt. Ik laat ook vaak Serial_Print of de onboard led verraden wat het programma aan het doen is.
  • Jboy1991
TomsDiner schreef op zaterdag 19 januari 2019 @ 23:24:
Ah debuggen bijv via serial werkt gewoon prima. Anders kreeg ik ook die log in Mn beginpost niet te zien
  • TomsDiner
Ik wist niet of je ledtest uit je post van 21:39 (want daar heb ik het over) ook zo'n ingebouwde controle had. Want met wat jij zegt -op niet één pin met een reactie- ga ik eerder het programma dan het board verdenken....
Overigens vertel ik je -neem ik aan- niets nieuws dat leds twee verschillende pootjes hebben?
  • Jboy1991
TomsDiner schreef op zondag 20 januari 2019 @ 00:25:
Ik snap je bericht niet helemaal.
Ja een los ledje heeft twee pootjes waarvan 1 de - is en de ander aangestuurd kan worden dmv high en low via een pin (Ik dacht dat jij op lichtjes onboard bedoelde).
  • TomsDiner
Je maakt een bericht over een test op de pins 53,15,11,10,8 en 3. Niet één led reageert.
Ik vraag of je zeker weet dat het programma wel draait.
Je geeft een naar de startpost verwijzend antwoord (en die gaat niet over leds testen)
Dus meld ik dat, en omdat ik nog steeds denk dat als alle pins niet werken, de test waarschijnlijk niet deugt, vraag ik voor de zekerheid of je weet dat je Leds op twee manieren aan kan sluiten: goed, en verkeerd aanom....
  • Jboy1991
TomsDiner schreef op zondag 20 januari 2019 @ 02:12:
Dit is de code die ik nu gebruik:
#include <SD.h>
#include <SPI.h>
File myFile;
int pinCS = 53; // Pin 10 on Arduino Uno
int ledpin = 11;
void setup() {
Serial.begin(9600);
pinMode(ledpin, OUTPUT);
void loop() {
digitalWrite(ledpin, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println("Led is aan");
delay(1000); // wait for a second
digitalWrite(ledpin, LOW); // turn the LED off by making the voltage LOW
Serial.println("Led is uit");
Inmiddels per toeval de led in pin 13 en ground geplaatst en nu blinkt de led. Dit terwijl ik aangeef dat het pin 11 moet zijn...
Dus er moet is fout zijn met het board
het maakt blijkbaar niet uit welke pin ik pak, het werkt alleen op pin 13
[ Voor 3% gewijzigd door Jboy1991 op 20-01-2019 10:54 ]
  • Vuikie
Dit klinkt als een raar probleem. Het lijkt bijna alsof je voor het verkeerde board compileert, waardoor je pin-mapping niet klopt.
Het is misschien een K-klus, maar als je, bijvoorbeeld, pin 53 laat 'blinken', loop dan eens alle pinnen na om te kijken op welke pin de LED aan en uit gaat.
Mijn vermoeden is dat OF de pin-mapping niet klopt OF het stiekum niet een Mega2560 board is.
  • Jboy1991
Vuikie schreef op zondag 20 januari 2019 @ 11:01:
och jij bent geniaal. Ik heb denk ik het probleem ontdekt:
Doordat er ook een esp wifi chip op zit, las ik op internet dat ik via board esp8266 moest uploaden. Helaas zat er geen documentatie bij deze board. Nu ik eens voor de gein ging proberen om te uploaden via de mega 2560 board werkt het ledje.
Wat ik mij dan nu wel afvraag moet ik beide chips apart aansturen en hoe laat ik ze communiceren met elkaar ;o
  • Vuikie
Is het toevallig een board als dit?:
https://nl.aliexpress.com...ino-Mega/32903404379.html
  • Jboy1991
Correct (staat ook in begin post)
inmiddels werkt de sdcard reader :D
Omdat ik dit best lastig vond om te vinden (en dankzij Vuilkie) de naam weet van het product. Hieronder een beschrijving wat erg handig is en helaas ontbreekt bij deze boards op aliexpress
WeMOS Mega + WiFi R3 ATmega2560 + ESP8266 USB-TTL For Arduino Mega NodeMCU
Description:
Features:
Full integration on one board: Mega R3 ATmega2560 and WiFi ESP8266 with memory 32Mb (megabyte)
All of the modules can work together or each separately. And everyone has their own pinout headers
The convenient solution for the development of new projects requiring Uno and WiFi
Via USB you can update sketches and firmvare for ATmega2560 and for ESP8266. For this on board have the USB-serial converter CH340G
Use this board is very simple
The board has DIP-switch, to connect the modules
For example, to: USB and ATmeg2560, USB and ESP8266, ATmega2560 and ESP8266
Table DIP- Switch:
Connection DIP
1 2 3 4 5 6 7
ATmega2560<->ESP8266 ON ON OFF OFF OFF OFF OFF
USB <->ATmega2560 OFF OFF ON ON OFF OFF OFF
USB<->ESP8266 (Update firmware or sketch) OFF OFF OFF OFF ON ON ON
USB<->ESP8266 (communication) OFF OFF OFF OFF ON ON OFF
All independent OFF OFF OFF OFF OFF OFF OFF
Special solution:
USB <->ATmega328<-> ESP8266
DIP SWITH 2
Connection 1 2 3 4 5 6 7
USB <-> ATmega2560<-> ESP8266 ON ON ON ON OFF OFF OFF To RXD3/TXD3
USB converter CH340G connect to RX0/TX0 of ATmega2560
ESP8266 connect to RX3/TX3 of ATmega2560
Quantity: 1 Pc
Note:
1.Transition: 1cm=10mm=0.39inch
2.Please allow 0-3mm error due to manual measurement. pls make sure you do not mind before you bid.
3.Due to the difference between different monitors, the picture may not reflect the actual color of the item. Thank you!
[ Voor 83% gewijzigd door Jboy1991 op 20-01-2019 11:23 ]
  • Vuikie
Jboy1991 schreef op zondag 20 januari 2019 @ 11:15:
oops :D
ieg. deze heb ik ook en hier moet je idd oppassen hoe je de dipswitches zet. Als je een progje naar de Mega2560 upload dan moeten alle dipswitches op 0 staan behalve 3 en 4, dan upload je namelijk direct naar de Mega2560.(En uiteraard als board de Mega2560 kiezen ;) )
Als je naar de ESP wil uploaden moet je dipswitches 5,6 en 7 aanzetten en apart de ESP resetten. Dipswitch 7 hangt namelijk IO-0 van de ESP aan GND zodat ie naar flash-update-mode boot.
Met dipswitches 1 en 2 laat je de Mega2560 en de ESP met elkaar babbelen over UART.
Dipswitch 8 doet niks.
Ik heb ook even zitten knoeien met dit board voordat ik hem doorhad, maar nu dat ik er bekend mee ben, wil ik eigenlijk niet meer terug naar een 'gewone' Arduino :*)
Voor meer info over jouw'n board kan je hier ook terecht
PS, dit board is er ook als Arduino Uno versie :Y)
  • Jboy1991
Vuikie schreef op zondag 20 januari 2019 @ 11:34:
oops :D
het is wel jammer dat ze beide apart geprogrammeerd moeten worden en dus niet beide direct met elkaar kunnen praten.
Nu moet ik voor de esp de wifi settings regelen (wil wifimanager gebruiken). Om vervolgens via serial de data naar de arduino te sturen. Beetje lastig haha
  • TomsDiner
-O- Dempt wat een geheugen....
#bookmark#
  • Jboy1991
TomsDiner schreef op maandag 21 januari 2019 @ 22:29:
#bookmark#
