mysql wel erg vaak
  • 143 views sinds 30-01-2008
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
tcp   0 0 localhost:3821        localhost:mysql    TIME_WAIT
tcp   0 0 localhost:mysql      localhost:1213       ESTABLISHED
tcp   0 0 localhost:1213        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1154       ESTABLISHED
tcp   0 0 localhost:1154        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1053       ESTABLISHED
tcp   0 0 localhost:1053        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1036       ESTABLISHED
tcp   0 0 localhost:1036        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1035       ESTABLISHED
tcp   0 0 localhost:1035        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1034       ESTABLISHED
tcp   0 0 localhost:1034        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1033       ESTABLISHED
tcp   0 0 localhost:1033        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:1032       ESTABLISHED
tcp   0 0 localhost:1032        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4959       ESTABLISHED
tcp   0 0 localhost:4959        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4958       ESTABLISHED
tcp   0 0 localhost:4958        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4957       ESTABLISHED
tcp   0 0 localhost:4957        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4956       ESTABLISHED
tcp   0 0 localhost:4956        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4955       ESTABLISHED
tcp   0 0 localhost:4955        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4954       ESTABLISHED
tcp   0 0 localhost:4954        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4953       ESTABLISHED
tcp   0 0 localhost:4953        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4952       ESTABLISHED
tcp   0 0 localhost:4952        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4951       ESTABLISHED
tcp   0 0 localhost:4951        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4944       ESTABLISHED
tcp   0 0 localhost:4944        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4943       ESTABLISHED
tcp   0 0 localhost:4943        localhost:mysql    ESTABLISHED
tcp   0 0 localhost:mysql      localhost:4942       ESTABLISHED
tcp   0 0 localhost:4942        localhost:mysql    ESTABLISHED
unix  1 [ W ]    STREAM     CONNECTED     4142779 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4142770 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4142681 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4142622 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4141338 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4131411 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4131362 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4122947 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4113668 /var/lib/mysql/mysql.sock
unix  1 [ W ]    STREAM     CONNECTED     4112351 /var/lib/mysql/mysql.sock
dit kreeg ik te zien na een
[root admin]# netstat | grep mysql |less
Betekend dit dat er gewoon veel mensen tegelijkertijd van een dbase gebruik maken? Of is het ernstiger. Had vanmiddag nog een scriptkidde eraf moeten gooien, dus ik ben een beetje huiverig.
  • Coen Rosdorff
Ziet eruit als php met persistent connecties enabled. Niks om je druk over te maken denk ik.
Doe eens een SHOW PROCESSLIST; in mysql.
  • ACM
ACM
Software Architect
Werkt hier
't Zijn allemaal lokale verbindingen.
Wat ik dan weer niet vat, is dat je zowel lokale netwerk- als socketvervindingen hebt.
Maar als je dat lijstje zou krijgen van t.net's database servers, zou je veel harder gillen ;)
Om te checken of het persistent php connecties zijn.
Kan je ook nog es 'ps xauf' doen, bij mysql is dat minder duidelijk dan bij postgresql te bekijken, maar je krijgt er een aardig overzicht van.
