Zsh pakt niet de eerste executable in $PATH
  • 523 views
Mijn vraag
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
$ python3 -m venv .venv
$ . .venv/bin/activate
$ pip install -e .
Obtaining file:///home/iemanddieboosis/raar
Collecting flask (from raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl
Collecting click>=5.1 (from flask->raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
Collecting Jinja2>=2.10 (from flask->raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl
Collecting itsdangerous>=0.24 (from flask->raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
Collecting Werkzeug>=0.14 (from flask->raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl
Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->flask->raar==0.0.0)
  Using cached https://files.pythonhosted.org/packages/e4/c4/adcc2d6f2ac2146cc04e076f14f1006c1de8e1e747fa067668b6573000b8/MarkupSafe-1.1.0-cp37-cp37m-manylinux1_x86_64.whl
Installing collected packages: click, MarkupSafe, Jinja2, itsdangerous, Werkzeug, flask, raar
  Running setup.py develop for raar
Successfully installed Jinja2-2.10 MarkupSafe-1.1.0 Werkzeug-0.14.1 click-7.0 flask-1.0.2 itsdangerous-1.1.0 raar
$ which flask
/home/iemanddieboosis/raar/.venv/bin/flask
$ FLASK_APP=raar flask --version
Flask 1.0.2
Python 3.7.2rc1 (default, Dec 12 2018, 06:25:49)
[GCC 8.2.0]
$ which flask
/usr/bin/flask
$ /home/iemanddieboosis/raar/.venv/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/home/iemanddieboosis/.gopath/bin:/home/iemanddieboosis/.config/composer/vendor/bin:/home/iemanddieboosis/.fzf/bin
$ ls -hal /home/iemanddieboosis/raar/.venv/bin
total 44K
drwxr-xr-x 1 iemanddieboosis iemanddieboosis  184 Dec 21 19:35 .
drwxr-xr-x 1 iemanddieboosis iemanddieboosis   66 Dec 21 19:35 ..
-rw-r--r-- 1 iemanddieboosis iemanddieboosis 2.2K Dec 21 19:35 activate
-rw-r--r-- 1 iemanddieboosis iemanddieboosis 1.3K Dec 21 19:35 activate.csh
-rw-r--r-- 1 iemanddieboosis iemanddieboosis 2.4K Dec 21 19:35 activate.fish
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  256 Dec 21 19:35 easy_install
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  256 Dec 21 19:35 easy_install-3.7
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  234 Dec 21 19:35 flask
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  238 Dec 21 19:35 pip
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  238 Dec 21 19:35 pip3
-rwxr-xr-x 1 iemanddieboosis iemanddieboosis  238 Dec 21 19:35 pip3.7
lrwxrwxrwx 1 iemanddieboosis iemanddieboosis    7 Dec 21 19:35 python -> python3
lrwxrwxrwx 1 iemanddieboosis iemanddieboosis   16 Dec 21 19:35 python3 -> /usr/bin/python3
Zoals je ziet lijkt Zsh eerst wel de goede Flask uit de venv te pakken, echter pakt die toch de globaal geïnstalleerde Flask wanneer ik hem probeer uit te voeren (wat ik kan bevestigen als ik in mijn app een module probeer te importeren die ik niet globaal geïnstalleerd heb). Dit terwijl als eerste in mijn $PATH de venv staat, en daar ook flask te vinden is als executable. Als ik echter een nieuw tabblad in mijn terminal emulator open en daarin de venv weer activeer, heb ik geen last van dit probleem meer. Waardoor komt dit en hoe los ik dit op?
- Debian GNU/Linux Unstable
- Zsh 5.6.2-3
Ik heb geprobeerd om in een schone chroot (gemaakt met debootstrap) hetzelfde te doen, maar daar heb ik exact hetzelfde resultaat.
  • Mijzelf
Volgens de man page van which gebruikt which hetzelfde zoekalgoritme als bash.
Volgens de man page van bash wordt PATH afgezocht, maar is er ook een hashtabel, die eerst wordt gebruikt. Door die tabel te manipuleren kun je dus zorgen dan een andere executable wordt gebruikt.
Mogelijk gebruikt zsh ook die hash.
Mijzelf schreef op zaterdag 22 december 2018 @ 12:59:
Echter is er in Zsh which ook als shell built-in command, die dus gebruikt wordt. Daarnaast heb ik in Bash dit probleem niet.
  • Wolfboy
Wolfboy
ubi dubium ibi libertas
zsh gebruikt een soort van cache hiervoor, nadat je een programma geinstalleerd hebt in je pad moet je het volgende commando gebruiken om deze opnieuw te bouwen:
rehash
Blog [Stackoverflow] [LinkedIn]
Wolfboy schreef op zondag 23 december 2018 @ 02:15:
rehash
Na 'rehash' werkt het inderdaad wel, echter is het dan toch raar dat 'which' eerst wel het goede pad zegt, toch?
  • Wolfboy
Wolfboy
Wel apart ja, ik heb eerlijk gezegd geen idee wat er intern gebeurd. Ik gebruik zsh erg veel maar ik ben verre van expert :P
  • sam.vimes
  • Laatst online: 30-05 11:33
De shell heeft een interne hashtable zodat een extern commando maar 1 keer via een PATH-search opgezocht hoeft te worden. Als er een nieuw commando wordt geïnstalleerd met dezelfde naam maar dat eerder in het PATH komt, moet de hashtable opnieuw geïnitialiseerd worden met "hash -r" of "rehash". "which" is een extern commando dat geen weet heeft van de interne hashtable van de shell en dat gewoon braaf iedere keer het PATH afloopt.
  • Hero of Time
  • Laatst online: 30-09 22:32
Hero of Time
Moderator LNX
There is only one Legend
Zo te zien heeft de TS besloten geen gebruik meer te maken van het forum. Dit topic heeft daarom geen zin meer en wordt derhalve gesloten.
[ Voor 3% gewijzigd door Hero of Time op 29-12-2018 22:47 ]
Commandline FTW
