Anti-cheat tool (CSGO) geeft Windows en browser problemen
  • lex0r
  • Laatst online: 05-08 17:41
Mijn vraag
Na het installeren van ESEA anti cheat of FACEIT Anti cheat krijg ik zwart beeld na een reboot en als ik hem opgestart krijg crashed de browser constant en gaat de PC raar doen.
Processor : i7-6700K
Mobo : asus rog VIII maximus ranger
Geheugen : 16GB DDR4 corsair (2x8)
Voeding : 750w voeding (Corsair)
Gpu : gtx 1070
Ssd's : crucial 256 gb en samsung eco 128gb
Koeling : hyper212
Case : sharkoon nightshark (nieuw)
OS: Windows 10 PRO
- bios update, windows update, drivers updates
- memtest86
- Prime95
- Logs bekeken via Event Manager (zie hetonder)
- PSU vervangen
- geheugen in andere DDR4 slots gestopt
- GPU in ander slot
Bij deze de logs via Event Manager:
A TCG Command has returned an error.
Desc: AuthenticateSession
Param1: 0x1
Param2: 0x60000001C
Param3: 0x900000006
Param4: 0x0
Status: 0x12
source: EnhancedStorage-EhStorTcg
The NcbService service terminated with the following error:
The service has not been started.
source: Service Control Manager
The DusmSvc service failed to start due to the following error:
The pipe has been ended.
The DusmSvc service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 300000 milliseconds: Restart the service.
The server {AB93B6F1-BE76-4185-A488-A9001B105B94} did not register with DCOM within the required timeout.
source: DistributedCOM
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Source: DistributedCOM
The Windows Search service terminated with the following error:
Not enough memory resources are available to complete this operation.
The Windows Search service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 30000 milliseconds: Restart the service.
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
Windows.SecurityCenter.WscDataProtection
and APPID
Unavailable
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
and APPID
Unavailable
The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Search service, but this action failed with the following error:
An instance of the service is already running.
Dit zijn alle errors welke er voorbij komen in de log.
Is er iemand die er handig mee is?
Gr,
Lex
