[OpenVPN] Werkt niet, certificaat error
  • c-nan
Ik heb op een CentOS 7 server OpenVPN geinstalleerd, ik maak gebruik van self-signed certificaten.
Een aantal checks:
[user@openvpn openvpn]$ sudo openssl verify -CAfile ca.crt  server.crt
server.crt: OK
[user@openvpn openvpn]$ sudo openssl verify -CAfile ca.crt  client-user.crt
client-user.crt: OK
Mijn server.conf:
[user@openvpn openvpn]$ sudo cat /etc/openvpn/server.conf |grep -v '^;\|^#\|^$'
port 1194
proto udp
dev tun
ca ca.crt
cert server.crt
key server.key  # This file should be kept secret
dh dh2048.pem
topology subnet
server 10.8.0.0 255.255.255.0
ifconfig-pool-persist ipp.txt
keepalive 10 120
tls-crypt myvpn.tlsauth
cipher AES-256-CBC
user nobody
group nobody
persist-key
persist-tun
status openvpn-status.log
verb 5
explicit-exit-notify 1
remote-cert-eku "TLS Web Client Authentication"
Mijn Windows 10 configuratie:
client
tls-client
ca "C:\\Users\\polat\\OpenVPN\\config\\ca.crt"
cert "C:\\Users\\polat\\OpenVPN\\config\\client-user.crt"
key "C:\\Users\\polat\\OpenVPN\\config\\client-user.key"
tls-crypt "C:\\Users\\polat\\OpenVPN\\config\\myvpn.tlsauth"
proto udp
remote <openvpn server> 1194 udp
dev tun
topology subnet
pull
user nobody
group nobody
Server log:
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=606586 MULTI: multi_create_instance called
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=607330 83.84.27.x:1194 Re-using SSL/TLS context
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=607504 83.84.27.x:1194 Control Channel MTU parms [ L:1621 D:1156 EF:94 EB:0 ET:0 EL:3 ]
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=607528 83.84.27.X:1194 Data Channel MTU parms [ L:1621 D:1450 EF:121 EB:406 ET:0 EL:3 ]
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=607577 83.84.27.X:1194 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1557,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
Dec  8 13:36:37 openvpn openvpn: Sat Dec  8 13:36:37 2018 us=607595 83.84.27.X:1194 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1557,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Dec  8 13:36:37 openvpn openvpn: RSat Dec  8 13:36:37 2018 us=607707 83.84.27.X:1194 TLS: Initial packet from [AF_INET]83.84.27.x:1194, sid=f6c4a4a3 46cf3dc9
Dec  8 13:36:42 openvpn openvpn: WRRWWWWRWRRWWRSat Dec  8 13:36:42 2018 us=665568 83.84.27.X:1194 TLS: new session incoming connection from [AF_INET]83.84.27.x:1194
Dec  8 13:36:47 openvpn openvpn: WRRWWWWRWRRWWWWRSat Dec  8 13:36:47 2018 us=718079 83.84.27.X:1194 TLS: new session incoming connection from [AF_INET]83.84.27.x:1194
Windows client log:
Sat Dec 08 13:36:39 2018 NOTE: --user option is not implemented on Windows
Sat Dec 08 13:36:39 2018 NOTE: --group option is not implemented on Windows
Sat Dec 08 13:36:39 2018 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Sat Dec 08 13:36:39 2018 Windows version 6.2 (Windows 8 or greater) 64bit
Sat Dec 08 13:36:39 2018 library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
Enter Management Password:
Sat Dec 08 13:36:39 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]85.17.X.X:1194
Sat Dec 08 13:36:39 2018 UDP link local (bound): [AF_INET][undef]:1194
Sat Dec 08 13:36:39 2018 UDP link remote: [AF_INET]85.17.x.x:1194
Sat Dec 08 13:36:40 2018 OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
Sat Dec 08 13:36:40 2018 TLS_ERROR: BIO read tls_read_plaintext error
Sat Dec 08 13:36:40 2018 TLS Error: TLS object -> incoming plaintext read error
Sat Dec 08 13:36:40 2018 TLS Error: TLS handshake failed
Sat Dec 08 13:36:40 2018 SIGUSR1[soft,tls-error] received, process restarting
Sat Dec 08 13:36:45 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]85.17.x.x:1194
Sat Dec 08 13:36:45 2018 UDP link local (bound): [AF_INET][undef]:1194
Sat Dec 08 13:36:45 2018 UDP link remote: [AF_INET]85.17.x.x:1194
Sat Dec 08 13:36:45 2018 OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
Sat Dec 08 13:36:45 2018 TLS_ERROR: BIO read tls_read_plaintext error
Sat Dec 08 13:36:45 2018 TLS Error: TLS object -> incoming plaintext read error
Sat Dec 08 13:36:45 2018 TLS Error: TLS handshake failed
Sat Dec 08 13:36:45 2018 SIGUSR1[soft,tls-error] received, process restarting
De client zegt duidelijk in de logs het volgende:
maar volgens mij klopt de certificaat gewoon, dus wat kan er nog meer verkeerd/fout zijn?
EU DNS: 86.54.11.100
  • CAPSLOCK2000
  • Laatst online: 12:54
CAPSLOCK2000
zie teletekst pagina 888
In je client config staat:
Moet dat niet
remote-cert-eku "TLS Web Server Authentication"
zijn?
This post is warranted for the full amount you paid me for it.
  • init6
Je zal als cliënt een ca certificate moeten gebruiken, je gebruikt selfsigned certificaten en die worden gevalideerd door certificate authorities. Gezien je nu dat valideren zelf moet doen zal je de cliënt zo'n ca cert moeten geven.
  • Thralas
  • Laatst online: 01-10 01:14
CAPSLOCK2000 schreef op zaterdag 8 december 2018 @ 17:27:
Moet dat niet
zijn?
:Y
remote-cert-tls server is daar een duidelijke shorthand voor
  • Zjemm
  • Laatst online: 01-10 07:34
Zjemm
misschien ook leuk om eens naar wireguard te kijken als alternatief :)
  • Bamboozled
  • Laatst online: 01-10 16:39
init6 schreef op maandag 10 december 2018 @ 08:46:
Echt niet. Ik gebruik al jaren Openvpn en genereer gewoon zelf certs. Dit moet gewoon werken.
  • CAPSLOCK2000
CAPSLOCK2000
Ik volg het niet, hij heeft toch een CA-certificate op de client?
Ik weet niet hoeveel zin het nog heeft om hier over verder te praten aangezien de TS niks meer van zich laat horen.
  • BoAC
  • Laatst online: 01-10 22:50
BoAC
Memento mori
@Polat06 kijk hier eens rond. Heb je een PKI opgezet?
https://wiki.gentoo.org/w...sing_the_easy-rsa_Scripts
  • SenZatioN
  • Laatst online: 08-02-2025
SenZatioN
Improvise...
CA cert wel aanwezig in de correcte certificate store op de client aangezien die de chain niet kan valideren?
My software never has bugs, it just develops random features...
  • Thralas
CAPSLOCK2000 schreef op donderdag 20 december 2018 @ 16:33:
Geen. Bovendien zijn er nu al 3 verkeerde suggesties gedaan ná het juiste anwoord.
Ja TS heeft een PKI (zie config), nee OpenVPN doet niets met een system CA store. @CAPSLOCK2000 gaf het juiste anwoord al.
@Polat06 Werkt het al?
[ Voor 7% gewijzigd door Thralas op 20-12-2018 20:46 ]
  • c-nan
Bedankt allen voor de reacties, nee niet werkend gekregen.
@CAPSLOCK2000 Ook dat was niet de oplossing.
Heb de boel nu anders ingericht, nog steeds OpenVPN, maar geen certificaten. Kan later posten hoe ik het opgelost heb.
Nieuwe client config waarmee het werkt:
client
proto udp
cert "C:\\Users\\polat\\OpenVPN\\config\\client.crt"
key "C:\\Users\\polat\\OpenVPN\\config\\client.key"
port 1194
dev tun
nobind
persist-key
persist-tun
resolv-retry infinite
cipher AES-256-CBC
route-metric 1
redirect-gateway def1
Eventueel kan ik ook de server (gewijzigde) server configu posten.
[ Voor 51% gewijzigd door c-nan op 21-12-2018 15:00 ]
