[Ervaringen & discussie] WordPress 5
  • 724 views
  • robcoenen
  • Laatst online: 15-10 09:38
We’ve made some big upgrades to the editor. Our new block-based editor is the first step toward an exciting new future with a streamlined editing experience across your site. You’ll have more flexibility with how content is displayed, whether you are building your first site, revamping your blog, or write code for a living.
Afbeeldingslocatie: https://i1.wp.com/wordpress.org/news/files/2018/12/Gutenberg.jpg?resize=768%2C384&ssl=1
The new block-based editor won’t change the way any of your content looks to your visitors. What it will do is let you insert any type of multimedia in a snap and rearrange to your heart’s content. Each piece of content will be in its own block; a distinct wrapper for easy maneuvering. If you’re more of an HTML and CSS sort of person, then the blocks won’t stand in your way. WordPress is here to simplify the process, not the outcome.
We've made some big upgrades to the editor. Our new block-based editor is the first step toward an exciting new future with a streamlined editing experience across your site. You’ll have more flexibility with how content is displayed, whether you are building your first site, revamping your blog, or write code for a living.
Building with Blocks
The new block-based editor won';t change the way any of your content looks to your visitors. What it will do is let you insert any type of multimedia in a snap and rearrange to your heart’s content. Each piece of content will be in its own block; a distinct wrapper for easy maneuvering. If you're more of an HTML and CSS sort of person, then the blocks won’t stand in your way. WordPress is here to simplify the process, not the outcome.
We have tons of blocks available by default, and more get added by the community every day.
This new editing experience provides a more consistent treatment of design as well as content. If you're building client sites, you can create reusable blocks. This lets your clients add new content anytime, while still maintaining a consistent look and feel.
Afbeeldingslocatie: https://i0.wp.com/wordpress.org/news/files/2018/12/twenty-nineteen.jpg?resize=768%2C512&ssl=1
Introducing Twenty Nineteen, a new default theme that shows off the power of the new editor.
Designed for the block editor
Twenty Nineteen features custom styles for the blocks available by default in 5.0. It makes extensive use of editor styles throughout the theme. That way, what you create in your content editor is what you see on the front of your site.
Simple, type-driven layout
Featuring ample whitespace, and modern sans-serif headlines paired with classic serif body text, Twenty Nineteen is built to be beautiful on the go. It uses system fonts to increase loading speed. No more long waits on slow networks!
Versatile design for all sites
Twenty Nineteen is designed to work for a wide variety of use cases. Whether you’re running a photo blog, launching a new business, or supporting a non-profit, Twenty Nineteen is flexible enough to fit your needs.
Afbeeldingslocatie: https://i1.wp.com/wordpress.org/news/files/2018/12/Classic.jpg?resize=768%2C362&ssl=1
Prefer to stick with the familiar Classic Editor? No problem! Support for the Classic Editor plugin will remain in WordPress through 2021.
The Classic Editor plugin restores the previous WordPress editor and the Edit Post screen. It lets you keep using plugins that extend it, add old-style meta boxes, or otherwise depend on the previous editor. To install, visit your plugins page and click the “Install Now” button next to “Classic Editor”. After the plugin finishes installing, click “Activate”. That’s it!
Note to users of assistive technology: if you experience usability issues with the block editor, we recommend you continue to use the Classic Editor.
[ Voor 4% gewijzigd door robcoenen op 07-12-2018 10:44 ]
  • DJMaze
robcoenen schreef op vrijdag 7 december 2018 @ 10:36:
Is denk ik wel weer de knuppel in het hoenderhok....
Maak je niet druk, dat doet de compressor maar
  • JeroenH
  • Laatst online: 15:20
Ik heb zojuist geüpdate naar 5.0.1 (5.0 overgeslagen), maar ik ben heel dom geweest; ik heb niet vooraf even op twitter gekeken naar wat mensen van deze update vinden. Als ik dat wel had gedaan was ik mooi bij 4.x gebleven.
In het kort: die nieuwe editor ZUIGT, gelukkig is d.m.v. een plug in nu nog met de classic editor te werken. Ik hoop maar dat WP naar hun users luistert en de editor sterk verbetert. Anders zullen forks als Classicpress het erg druk krijgen...
-edit-
De comments bij de classic-editor-plugin liegen er niet om...
[ Voor 13% gewijzigd door JeroenH op 13-12-2018 11:39 ]
  • DJMaze
JeroenH schreef op donderdag 13 december 2018 @ 11:17:
Bij Gutenberg ook niet https://wordpress.org/support/plugin/gutenberg/reviews/
  • q-enf0rcer.1
  • Laatst online: 20-10 09:17
Ik gebruik geen Wordpress, maar die blocks zien er toch wel heel mooi uit. Denk dat de Wordpress community niet zo angstig moet doen en dit juist zou moeten omarmen. Dat iets voorheen altijd anders heeft gewerkt, betekent niet dat dit beter was. Ik heb de oude editor wel eens gezien, en daar moest je doormiddel van een eigen Wordpress syntax allemaal rare codes toevoegen om custom dingen te doen. Zo te zien neemt Blocks dat probleem uit handen.
  • JeroenH
Het hangt er denk ik van af wat je zoekt. Als je iets zoekt wat lijkt op bv Wix of Squarespace dan zie ik wel wat het toe kan voegen.
Als ik echter door de comments en reviews blader dan lijkt het er sterk op dat heel veel gebruikers Wordpress "simpel" gebruiken, die hebben helemaal geen behoefte aan een dergelijk complex systeem.
Verder heb ik het idee dat de wijziging te groot en te plotseling is. Ik zie ook veel comments van site-beheerders die compleet verrast zijn, en die nu met klanten zitten die ineens niet meer snappen hoe ze hun site moeten beheren. Is dat hun eigen fout? Misschien gedeeltelijk, maar ik vind na wat leeswerk dat WP de wensen van hun userbase erg verkeerd heeft ingeschat. Deze nieuwe editor als optie aanbieden had denk ik al veel gedoe voorkomen.
De grote vraag is wat WP nu gaat doen. Ze hebben voorzover ik weet nog compleet niet gereageerd op de heisa. Dat vind ik niet slim.
  • Whounclat
Wij hebben verschillende websites onder Wordpress draaien. Mijn ervaringen met Wordpress 5 (en hoger) zijn gemixt. Uiteraard heb ik eerst backups gemaakt van de websites en databases. De meeste thema's en plug-ins waren direct compatible met WP 5 volgens de auteurs. Helaas bleek dit niet voor elke website niet helemaal waar te zijn. De ene website werkte prima met de update terwijl een andere website een deel van de inhoud niet meer zien. Dit werd waarschijnlijk veroorzaakt door de verschillende page builders en caching op de achtergrond.
Het idee van de block editor spreekt mij wel erg aan, alleen laat de implementatie nog te wensen over. Daarom vind ik het jammer dat WP over een paar jaar de stekker uit de "oude" editor trekt.
Mijn advies zou zijn om in ieder geval handmatige back-ups te maken en goed te controleren of je thema's, plug-ins etc. compatible zijn met WP 5.
  • Spinal
  • Laatst online: 23-10 09:00
q-enf0rcer.1 schreef op vrijdag 14 december 2018 @ 18:46:
Gutenberg heeft potentie, maar het is wel jammer dat het zo gehaast is. Elke versie van Gutenberg wijzigde veel t.o.v. de vorige versie, waardoor een plugin die je compatible had gemaakt met Gutenberg 3.7 ineens niet meer kon werken voor Gutenberg 3.8. En dan dus weer voor 3.9. En 4.0...
Daarnaast is er bijzonder weinig informatie te vinden over hoe je plugins (compatible) maakt voor Gutenberg, mede doordat alles zo snel veranderde. Dit alles motiveert totaal niet om er mee aan de slag te gaan.
Full-stack webdeveloper in Groningen
  • DJMaze
Spinal schreef op donderdag 20 december 2018 @ 13:34:
Ach ze zitten nu al op 5.0.2 en daaruit blijkt inderdaad hoe "goed" het is.
https://wordpress.org/new...-0-2-maintenance-release/
  • Creepy
  • Laatst online: 16:05
Creepy
Tactical Espionage Splatterer
Ik zie hoeveel discussie er gelijk is, maar ik wil toch even link naar NMe in "[WordPress 5] Ervaringen & Discussie" . Dit is niet de vorm waarin we dit soort topics willen zien. De release notes kan iedereen prima opzoeken natuurlijk ;)
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
