• Lwout
  • Registratie: December 2015
  • Laatst online: 01-06 10:08
Note: After first install crossfade (Kruiselings oplossen) works ok, but when using it a lot more (like hundreds of times) it malfunction and instead of crossfade it fade out to black en fade in from black in the next clip but also, a lot of times, makes the next clip complete black.
I read this problem before (see below) but have some additions to it:
After changing the duration (control panel) of the effects in broken seconds like 1:30s the effect crosfade goes to black in the middle. Changing it back to 2s or 1s it works fine again.
THE WORKARROUND IS TO WORK WITH WHOLE SECONDS
I use the dutch version
Quote:
Ripple transition with crossfade is not crossfading but leaves gap between clips
I use crossfade often and to apply the transition I use the ripple transition function. While applying a single effect with drag and drop works ok, if I select the entire track and use ripple, the resulting crossfades dont affect both clips but rather the end of the front clip. Instead of moving the second clip and use it for crossfade it will only use the first still frame of that clip for the transition. So the crossfade will unite the end of the first clip with a freeze frame from the second clip, wich is weird and toes not look good.... Is there a way to fix this? In all the other versions of Pinnacle ripple transition worked ok. Thanks
In Engels omdat ik het ook aan Pinnacle heb gestuurd.
