Iiyama 451 heb ik ,met de nieuwe series zijn geen problemen meer ,deze werkt nu probleemloos
*Mooi design
*Usb Hub
*Speakers
*Diamondtron beeldbuis
Ach ja kijk zelf maar
High Contrast 19"(18", 46 cm viewable) Flat screen Diamondtron NF
0,25/0,27mm aperture grille, dual focus CRT, for a crisp clear, dynamic display
Simply to operate 6 push button controls
High resolution On-screen Display for ease of set-up and use
Plug-and-play DDC1/2BTM compatible
Auto selection of dual input 15 pin D-sub
Ecologically manufactured, fully recyclable
TCO99 approved
Model A902MT Vision Master Pro451
CRT 49cm (19"),
Flatscreen Diamondtron NF (18", 46cm viewable)
Dot pitch 0,25/0,27mm AG Pitch Aperture Grille
Sync Frequentie Horizontal: 30 - 115kHz, Vertical: 50 - 180Hz
Video bandwidth 300MHz dot clock
Resolution 640 x 480 @ 180Hz refresh
800 x 600 @ 180Hz refresh
1024 x 768 @ 142Hz refresh
1152 x 864 @ 126Hz refresh
1280 x 1024 @ 107Hz refresh
1600 x 1200 @ 92Hz refresh
1800 x 1440 @ 77Hz refresh
Mooie reso's en refreshrates
Input connectors 2 x 15 pin D-sub connector, Audio, USB upstream / 4 x downstream,
Headphone connector ø 3.5mm mini jack
Plug & Play VESA DDC 2BTM Compliance
Number of signal storage Factory-presets: 6 User memory locations: 10
Dimensions 450mm x 450mm x 447mm(WxHxD)
Net weight 24kg
Power management VESA DPMS, NUTEK,
Energy Star© Compliance
Power consumption 138W maximum in normal use
<=10W in suspend mode
<= 3W in active-off mode
Screen controls Contrast, Brightness, Color temp. 4.500 - 10.000K, Zoom, H-size, V-size, H-position, V-position, Pin-cushion, Trapezoid, Parallelogram, Pin-balance, Tilt, H-convergence, V-convergence, H-moiré, OPQ-Text/ Picture/Movie, Degauss, Landing 4 corners, OSD Position, OSD Off-timer 3,5,15,30-45sec, Language (UK, D, F, NL, SWE, JAP), Lockout, Save recall, Help on/off, Information
Color temperature Adjustable between 4.500 - 10.000K
Approvals TCO99, CE, TÜV-GS/MPR II/ISO 9241-3/ ISO 9241-7/ISO 9241-8, PTB, FCC-B, UL/C-UL, DHHS, DHNW
Manufacture All monitors manufactured using CFC
free materials, non-toxic metals and
non-bromided flame retardants, and
are fully recyclable. Recycled material used for packaging and user documentation
Additional Intergrated self-powered USB HUB
(1 upstream, 4 downstream ports Rev1.1), 2 x 1W front firing speakers, Headphone connector, All controls and input connectors are lokated in the monitor stand
Warranty 3 years on-site service
