Best gaming laptops(hardware & software)
  • 510 views
Best 17-inch gaming laptop
The Alienware 17 R5 is the latest in a long line of well-regarded laptops from this Dell subsidiary, but this one raises the bar. Actually, it throws the bar high up in the air, leaps after it, catches it mid-somersault, and lands cleanly while onlookers stare, agog.
[ Further reading: Our picks for best PC laptops ]
The key difference: an upgrade to Intel’s 8th-gen mobile processors, which pack more CPU cores than previous generations did. Even better, the one in our review unit is Intel’s high-performance Core i9 -8950HK, which turns this already beastly gaming laptop into an utter monster.
The Alienware 17 R5 is available in a variety of configurations, from a $1,560 model with a 6-core Core i7-8750H, an overclocked GeForce GTX 1060, and a 60Hz 1080p display, all the way up to the price-is-no-object-I-want-performance version we tested ($3,810 from Dell). Optional features could push that total even higher, but there’s already plenty to love. This is 10 pounds of gaming-laptop-slash-desktop-replacement-extraordinaire. Read our review.
Best 15-inch gaming laptop
Just a few years ago, if you said you wanted 1080p Very High or Ultra gaming performance in a laptop, you’d be lifting eight pounds of laptop. If you wanted a six-core CPU too, that’d be 12 pounds of laptop with a desktop chip inside. And decent battery life? مبل بابل Fuhgetaboutit.
That you can get the same or better performance with the four-pound MSI GS65 Stealth Thin 8RE ($1,799 at Amazon) is a testament to just how far we’ve gone—and also proof of just how awesome this laptop is.On the outside, it’s sedate black aluminum with bronze edges. On the inside are state-of-the-art, gaming-grade components with enough performance to basically put anything made before it to shame.
The GS65 is basically a complete rework of the ground-breaking GS63VR gaming laptop that made its debut in 2016. The most important upgrade is what’s inside: Intel 6-core Core i7-8750H and 16GB of DDR4/2400 in dual-channel mode; the full-fat Nvidia GeForce GTX 1060 6GBl and a 256GB Samsung PM981 NVMe SSD.
The six-core CPU inside is the real news. You’ve probably seen people dismiss it as “more of the same from Intel,” but those folks are wrong. This latest iteration is a screaming-fast CPU unlike any that we’ve ever seen in a laptop before.
Runner-up
The Dell G7 15 is a mid-size gaming laptop with middle-of-the-road GTX 1060 Max-Q graphics, middling battery life, and—you guessed it—a mid-range price tag. But this system boasts a stellar feature that sets it apart from the crowd: a six-core, benchmark-crushing Core i7 processor that’ll thrill content creators. Indeed, the G7 15’s overall performance is only a step or two behind that of our current top pick among 15-inch gaming laptops, the thinner and lighter MSI GS65 Stealth Thin 8RE—and it costs about $600 less. Despite a dim screen and an occasionally too-hot chassis, this is still a worthy contender.
Best budget gaming laptop
The Dell G3 15 gaming laptop delivers solid performance in a package that’s a little less than an inch thick. The Model 3579 we tested is very affordable, too.
The G3 15 has its downsides, including a Full-HD display that isn’t as bright as we’d like, frame rates that struggle to reach 60 fps on top-tier games, and a weight exceeding five pounds (although it’s not as massive as some gaming laptops). But when we compared it to the Acer Nitro 5, another budget gaming laptop we like, with an even lower price point, there was no سطل زباله contest. The G3 15 posted stronger benchmarks and battery life. In particular, its GTX 1050 Ti graphics showed the limitations of the Nitro 5's mere GTX 1050. Nothing wrong with the Nitro 5, but if you can afford the G3 15 we tested, it's the better choice. Read our full review.
Best portable gaming laptop
Nvidia’s Pascal GPUs haven’t just put the traditional beefy gaming laptops on par with desktop machines. They’ve also made it so the term “portable gaming laptop” is no longer an oxymoron. Put a GeForce GTX 1060 into a laptop and you have a capable machine that can survive away from a wall socket—and won’t break your back while carrying it, either.
Now, at five pounds, the Alienware 13 (available at Dell.com) is a little heavy for its size—but it’s worth toting around those extra ounces. The model we reviewed packs a gorgeous OLED 2560x1440 display, a quad-core i7 processor, and a VR-capable Nvidia GTX 1060 for flawless 1080p gaming. (Yes, you can play at 2560x1440, too, if you crank down some of the settings... or buy an Alienware Amplifier and pop in a beefier video card.)
Its extra weight comes from its incredibly sturdy and solid chassis, built to withstand hot climates and gamers who react physically to the highs and lows of gameplay. For some, that’ll be a drawback. But it’s hard to hold the Alienware 13’s design against it, especially after experiencing the pure luxury of its OLED screen: Gaming on it makes the best LCD panels seem pixelated and washed out.
While performance is a hair under rival machines like the MSI GS63VR, the difference is almost negligble—just one or two frames less per second in our Tomb Raider and Middle-earth: Shadow of Mordor benchmarks. If you can splurge on this version of the Alienware 13, we say do it. From its slick design to its performance, battery life, and OLED display, it’s exceptional in every metric we usually examine.
  • avasn22
  • Registratie: Mei 2026
  • Laatst online: 21-05 13:23
Hello,
A solid gaming laptop setup isn’t just about GPU power anymore. A lot of players also tweak communication and privacy tools for smoother sessions and better control over chats. I recently came across *SPAM* which adds extra customization and privacy features for Telegram on Android, and it fits nicely into a more personalized gaming setup.
[ Voor 8% gewijzigd door dion_b op 21-05-2026 13:32 ]
  • dion_b
  • Laatst online: 22:03
dion_b
say Baah
:w
Oslik, blyat! Oslik!
