Ff iets anders........... firewire kaart.........
Ik hoor dit hier en daar erg veel, maar is voor mij nieuw kan iemand vertellen wat het precies is en wat je ermee kunt ??
De een zegt Asus Firewire, de ander weer iets anders ben al op zoek gegaan naar wat het is maar nog niet echt iets gevonden........
  • JvS
  • Laatst online: 14:40
JvS
Ik heb hem zelf ook
lijkt me een duidelijk geval van I/O :P
move naar dit forum dus. ;)
FireWire
FireWire is Apple Computer's version of a standard, IEEE 1394, High Performance Serial Bus, for connecting devices to your personal computer. FireWire provides a single plug-and-socket connection on which up to 63 devices can be attached with data transfer speeds up to 400 Mbps (megabits per second). The standard describes a serial bus or pathway between one or more peripheral devices and your computer's microprocessor. Many peripheral devices now come equipped to meet IEEE 1394. FireWire and other IEEE 1394 implementations provide:
A simple common plug-in serial connector on the back of your computer and on many different types of peripheral devices
A thin serial cable rather than the thicker parallel cable you now use to your printer, for example
A very high-speed rate of data transfer that will accommodate multimedia applications (100 and 200 megabits per second today; with much higher rates later)
Hot-plug and plug and play capability without disrupting your computer
The ability to chain devices together in a number of different ways without terminators or complicated set-up requirements
In time, IEEE 1394 implementations are expected to replace and consolidate today's serial and parallel interfaces, including Centronics parallel, RS-232C, and Small Computer System Interface (SCSI). The first products to be introduced with FireWire include digital cameras, digital video disks (DVDs), digital video tapes, digital camcorders, and music systems. Because IEEE 1394 is a peer-to-peer interface, one camcorder can dub to another without being plugged into a computer. With a computer equipped with the socket and bus capability, any device (for example, a video camera) can be plugged in while the computer is running.
Briefly How It Works
There are two levels of interface in IEEE 1394, one for the backplane bus within the computer and another for the point-to-point interface between device and computer on the serial cable. A simple bridge connects the two environments. The backplane bus supports 12.5, 25, or 50 megabits per second data transfer. The cable interface supports 100, 200, or 400 megabits per second. Each of these interfaces can handle any of the possible data rates and change from one to another as needed.
The serial bus functions as though devices were in slots within the computer sharing a common memory space. A 64-bit device address allows a great deal of flexibility in configuring devices in chains and trees from a single socket.
IEEE 1394 provides two types of data transfer: asynchronous and isochronous. Asynchronous is for traditional load-and-store applications where data transfer can be initiated and an application interrupted as a given length of data arrives in a buffer. Isochronous data transfer ensures that data flows at a pre-set rate so that an application can handle it in a timed way. For multimedia applications, this kind of data transfer reduces the need for buffering and helps ensure a continuous presentation for the viewer.
The 1394 standard requires that a device be within 4.5 meters of the bus socket. Up to 16 devices can be connected in a single chain, each with the 4.5 meter maximum (before signal attenuation begins to occur) so theoretically you could have a device as far away as 72 meters from the computer.
Another new approach to connecting devices, the Universal Serial Bus (USB), provides the same "hot plug" capability as the 1394 standard. It's a less expensive technology but data transfer is limited to 12 Mbps (million bits per second). Small Computer System Interface offers a high data transfer rate (up to 40 megabytes per second) but requires address preassignment and a device terminator on the last device in a chain. FireWire can work with the latest internal computer bus standard, Peripheral Component Interconnect (PCI), but higher data transfer rates may require special design considerations to minimize undesired buffering for transfer rate mismatches.
firewire is dus gewoon een (parallelle?) bus waar je externe apparatuur aan kunt hangen die erg hoge snelheden vraagt. Verder is het hotswappable, dus verwisslebaar als de pc aanstaat.
Gewoonlijk wordt het gebruikt voor externe harddisks, camcorders en dat soort dingen.
Firewire-netwerken is ook mogelijk vanaf WinXP (WinME ook), en anders www.unibrain.com
