RedHat 7.1 C-compiler probleem.
  • theezeefje
  • Laatst online: 01-09 16:10
Bij de install van verschillende applicaties krijg ik de volgende melding.
wie kent het, en wie weet wat ik er tegen kan doen ?? :
[root@enterprise micq-0.4.7]# ./configure
checking build system type... i586-pc-linux-gnu
checking host system type... i586-pc-linux-gnu
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking for working autoconf-2.50... missing
checking for working autoheader-2.50... missing
checking for gcc... gcc
checking for C compiler default output... configure: error: C compiler cannot create executables
ik vond overigens deze logfile:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:581: checking for a BSD compatible install
configure:634: checking whether build environment is sane
configure:691: checking whether make sets ${MAKE}
configure:737: checking for working aclocal
configure:750: checking for working autoconf
configure:763: checking for working automake
configure:776: checking for working autoheader
configure:789: checking for working makeinfo
configure:803: checking whether to enable maintainer-specific portions of Makefi
les
configure:828: checking for gcc
configure:941: checking whether the C compiler (gcc ) works
configure:957: gcc -o conftest conftest.c 1>&5
/usr/bin/ld: cannot find -lc
collect2: ld returned 1 exit status
configure: failed program was:
#line 952 "configure"
#include "confdefs.h"
main(){return(0);}
[root@enterprise opennap-0.41]#
Vroeger, toen de kratten bier nog van hout waren, en je moest doorzuipen om de kachel warm te houden....
Ga eens glibc installeren ofzo :)
  • theezeefje
Op vrijdag 20 juli 2001 20:11 schreef beelzebubu het volgende:
Zit dat niet standaard in RedHat 7.1 ?
Dat mag ik hopen van wel voor je... :P
Kijk eens naar bestanden die libc.a of lic.so heten en waar ze staan ("locate libc.so" en "locate libc.a").... Kijk ook naar je LD_LIBRARY_PATH ("echo $LD_LIBRARY_PATH") om te kijken welke dirs standaard worden meegecompileerd...
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Kan iemand hier een FAQ van maken ? Dit is het 'ik heb geen glibc-devel geinstalleerd' probleem.
[quote]
[/quite]
Je mist glibc-devel
  • Qui-Gon
  • Laatst online: 06-04 10:29
Ik heb even gekeken op
/pub/redhat/linux/7.1/en/os/i386/SRPMS
bij ftp.redhat.com
aan daar staat geen glibc-devel.
hoe moet ik daar aan komen?
(ben theezeefje even aan het helpen)
  • Jordi
Jordi
#1#1
igmar: dat vind ik niks voor in een FAQ, dit kan men beter zelf ondervinden (en dat ding is al groot genoeg)
Het zal wel niet, maar het zou maar wel.
  • igmar
igmar
ISO20022
bij ftp.redhat.com
Omdat de SRPMS directory alleen sources bevat. glibc-devel, glibc en glibc-profile worden alle 3 uit glibc-xxx.src.rpm gegenereerd.
De binary staat in /pub/redhat/linux/7.1/en/os/i386/RedHat/RPMS
  • igmar
igmar
ISO20022
50% van de compile problemen zijn het niet hebben van *-devel packages. Op zich reden genoeg voor een FAQ zou ik zeggen, maar ja, ik ben geen mod :)
