Misschien heb je hier iets aan..
PSS ID Number: Q197141
The information in this article applies to:
- Microsoft Systems Management Server version 1.2
SYMPTOMS
When attempting to take Remote Control of a remote computer, the SMS
Administrator program user interface (UI) and Remote Control Quick Viewer window
close without warning.
CAUSE
The problem occurs because both the original Systems Management Server 1.2
installation and the Systems Management Server 1.2 Service Pack 4 installation
overwrite the Windows NT Server 4.0 Service Pack 4 version of the Sightnt.dll
file.
WORKAROUND
To work around this problem, copy the Sightnt.dll file from the appropriate
platform directory (Alpha or X86) of the Windows NT Server 4.0 Service Pack 4
media to the Systems Management Server site server or Administrator Tools
computer. Replace the existing copy of Sightnt.dll located in the
<sms_root_dir>\Site.srv\<Platform>.bin directory.
To update the clients, either manually run Upgrade.bat on each client or follow
the instructions in the following article in the Microsoft Knowledge Base:
Q166771 SMS: How to Force Site-Wide Client Updates
Although the versions of Sightnt.dll included with Windows NT Server 4.0 Service
Pack 4 and Systems Management Server 1.2 Service Pack 4 have identical file
sizes, their contents are different. You can identify the correct file by
comparing the date/timestamps. The Sightnt.dll file included with Windows NT
Server 4.0 Service Pack 4 is dated 10/15/98, while the Sightnt.dll file included
with Systems Management Server 1.2 and Systems Management Server 1.2 Service
Pack 4 have earlier date/timestamps.
......ik heb het een beetje ingekort, maar ik denk dat dit je probleem is.
Suc6
Men are from Mars, women are meteors crashing into Mars.
Discogs
