geheugen probleem
Ik heb net naast mn 128 mb spectek een 256 mb kingston ram bankje gezet.
zou dus 384 moeten zijn.
alleen hij pakt maar 256 als ie begint te tellen bij boot.
chipset is een Ali V op een asus p5 a-b
hier is wat mm er van vond.
SPD dump of Dimm in socket :1
SPD - Number of bytes available :128 bytes
SPD - Total bytes of memory device :256 bytes
SPD - Revision :1,2
SPD - Checksum :OK
Manufacturer - Name :Kingston
Manufacturer - Location :3 ($03)
Manufacturer - Part Number :KVR133x64C3SS/256
Manufacturer - Revision code :255255 ($FFFF)
Manufacturer - Manufacturing date :$0115
Manufacturer - Assembly Serial Number :826256
Manufacturer - Manufacturer Specific Data :
Memory - Type :Sync Dram
Memory - Row Addresses :0 | 13
Memory - Column Addresses :0 | 10
Memory - Module Banks :1
Memory - Data Width :64
Memory - Voltage interface standard :LVTTL
Memory - Cycle time at Max. Supported CAS :7.5 ns.
Memory - SDRAM Access from Clock at :5.4 ns.
Memory - DIMM Configuration type :None
Memory - Refresh Rate/Type :Self Refresh, Reduced (.5x)...7.8 us
Memory - Minimum Clock Delay :1
Memory - Burst Lengths Supported :1 2 4 8
Memory - Banks on Each SDRAM device :4
Memory - CAS Latencies Supported :2 3
Memory - CS Latencies Supported :0
Memory - WE Latencies Supported :0
Memory - Min. Clock Cycle Time @ CL X-1 :10.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :6.0 ns.
Memory - Min. Clock Cycle Time @ CL X-2 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-2 :0.0 ns.
Memory - Minimum Row Precharge Time :20 ns.
Memory - Minimum Row Active to Row Active delay :15 ns.
Memory - Minimum RAS to CAS delay :20 ns.
Memory - Minimum RAS Pulse Width :45 ns.
Memory - Module Bank Density :512 MB.
Memory - Module Total Density :512 MB.
Memory - Speed :133 Mhz
SPD dump of Dimm in socket :2
SPD - Revision :1,2
SPD - Checksum :OK
Manufacturer - Name :SpecTek Incorporated
Manufacturer - Location :255 ($FF)
Manufacturer - Manufacturing date :$FFFF
Manufacturer - Assembly Serial Number :255255255255
Memory - Row Addresses :0 | 12
Memory - Column Addresses :0 | 9
Memory - Module Banks :2
Memory - Refresh Rate/Type :Normal (15.625 us)
Memory - Burst Lengths Supported :Page 1 2 4 8
Memory - Minimum RAS Pulse Width :44 ns.
Memory - Module Bank Density :64 MB.
Memory - Module Total Density :128 MB.
de 2 bankjes zijn allebei 133mhz cas 3 en doen 100mhz cas2 stabiliteit is verder geen probleem. op cas3 zetten maakt geen verschil.
mn moederbord zou tot 768 moeten ondersteunen zoals in het boekje staat.
wie heeft hier een idee of oplossing voor?
  • CrazyA
  • Laatst online: 18-07 12:28
Misschien stom maar, wissel ze 's om ??
kan het ook zijn dat ie alleen maar single sided ram pakt (dus chips aan 1 kant) want die spectek heeft ze aan 1 kant en kingston aan 2 en die kingston pakt ie maar 128 van.
denk ik dan. want er staat ook in mn mobo boekje : "One side (with memory chips) of the DIM takes up one row on the motherboard.
is er dan nog een mogelijkheid om toch gebruik te maken van die 256 i.p.v 128?
  • CrazyA
Op vrijdag 20 juli 2001 16:59 schreef kRiTz_C het volgende:
denk ik dan.
Dat zou dan toch ergens in het boekje van je mobo moeten staan,
Op vrijdag 20 juli 2001 17:01 schreef Crazy A het volgende:
idd zag het nu staan.: "One side (with memory chips) of the DIMM takes up one row on the motherboard.
  • CrazyA
Op vrijdag 20 juli 2001 17:04 schreef kRiTz_C het volgende:
Hmmm... dan geef ik je weinig hoop eigenlijk. ;(
  • BezurK
  • Laatst online: 14-06 09:12
Zet de 128 module in slot 1 en die 256 module in slot 3... :?
Rookworst zonder R is ook worst.
oke ben weer ff beziggeweest. die spectek (die het al een jaar goed doet ) was dus double sided! en de kingston niet..vreemd.
de kingston is het bankje wat ik dus nieuw heb.
Ik heb de spectek eruit gehaald en die kingston erin gedaan (i.p.v samen) en op ieder geheugen slot in mobo geprobeert ze pakten allemaal 128mb i.p.v 256mb.
iemand nog ideeen?
die mm output van die kingston zitten ook vreemde getallen in waar slaat die 512mb op :?
  • Abbadon
  • Laatst online: 27-08 22:33
Ik ken dat Asus P5 a-b bord verder niet, maar moeten de 256MB DIMM's niet aan bepaalde voorwaarden voldoen wat betreft SDRAM structuurdiepte en datalijnen? Zou dat eerst maar even nagaan. Oudere chipsets zijn wat beperkter in hun mogelijkheden m.b.t. deze zaken. (veel voorkomend 'symptoom' is dat de helft maar wordt 'gezien')
zou best kunnen uit de mm file zie je ook dat die kingston meer functies ondersteunt.
mn boekje spreekt over wat vage dingen:
single sided dimm's are avaiable in 16,32,64,128mb;double sided in 32,64,128,256
heb ik toch een single side 256 hoe kan dat dan?
  • Abbadon
Op vrijdag 20 juli 2001 18:40 schreef kRiTz_C het volgende:
Die Kingston DIMM, is dat een PC133? Zo ja, dan is er een gerede kans dat deze afwijkt van Intel's PC100 specificatie. Het ziet er naar uit dat jouw bord alleen PC100 compliant DIMM's pakt. Niet dat er geen PC133 in kan, maar 256MB modules die aan de PC100 eis voldoen zijn naar ik meen per definitie voorzien van 16Mx8 SDRAM's (16 stuks, dus doublesided). Je hebt genoeg PC133 DIMM's die dezelfde chipstructuur hebben (en dus prima op een oud bord werken), maar ze zijn er ook met bijvoorbeeld 32Mx4 of 16Mx16 SDRAM's. Die laatsten werken wel met moderne 133MHz chipsets, maar dus niet volledig met de oudere zoals o.a. de BX, en hoogstwaarschijnlijk ook de ALi Alladin V. Kun je niet nagaan wat voor chips er op zitten? (Sisoft of zo). In ieder geval ben ik bijna zeker dat dit het probleem is.
  • Jester
  • Laatst online: 27-08 19:42
boekje misschien verouderd...
of geheugen vernieud :P
- hardware always changes.. -
Op vrijdag 20 juli 2001 18:57 schreef abbadon het volgende:
zitten toshiba chips op maar te zien aan het feit dat er in het boekje bij dimm's maximum 16 chips staan wijst dus al uit dat 256 single sided niet maar double wel kan.
thanks abbodon ik ga er morgen even wat double 256 in doen.
  • Abbadon
Op vrijdag 20 juli 2001 19:20 schreef kRiTz_C het volgende:
thanks abbodon ik ga er morgen even wat single 256 in doen.
Nou, ik denk juist niet dat je er een single-sided DIMM in moet doen. Je moet een double-sided met 16Mx8 SDRAM's hebben (dan is het probleem volgens mij wel opgelost). Vergeet niet dat er ook DIMM's zijn met 16 32Mx4 SDRAM's, en ik denk dat jij die laatste nu hebt.
  • Chop2000
  • Laatst online: 23-08 20:50
Chop2000
Vroem
In mijn a7v boekje staat:
single-sided dimms come in 16,32,64,128, 256 MB;Double-sided come in 32,64,128,256,512MB
hmmm geheugen is dus geupdate probeer de bios te flashen mischien denkt ie nog steeds dat de max voor single 128 is daarom zegt ie mischien 128mb ff en klaar (hoop ik :) )
niks
i know had het er zelf verkeerd neergezet
|:( i mean double.
