harde schijf kapot pls help !!
Ik wou vanmorgen eens linux installeren. Dus heb ik een van de 2 hardeschijven proberen om te toveren tot een linux schijf in partition magic 6.0. hij zei dat allles goed was totdat ik linux wou installeren. hij bleef steeds vragen om een lunix hd aan te maken en zei dat ie er geen een kon vinden. Dus ik weer in partition magic kijken. En nu staat er error #108 bij die schijf en ik kan er nu met geen mogelijkheid meer partities op aanmaken. wweten jullie wat ik kan doen of was die foutmelding betekend.
bvd
Is er geen restore functie in PM6 :?
#108 see error :#105 Partition starts on wrong boundary
The hard-disk partition table contains erroneous values. PartitionMagic expects
partitions to begin and end on the correct cylinder boundaries. If they do not, the
disk may be partially corrupted. In this circumstance, if PartitionMagic were to
make any modifications it might cause the loss of data. Therefore, PartitionMagic
refuses to recognize any of the hard disks partitions. To resolve this problem, see
the instructions in Resolving Partition Table Errors on page 118.
aha page 118:
Norton Utilities
You can safely use PartitionMagic and Norton products together. The following
information will help you avoid any problems.
Norton Disk Doctor
If an extended partition ends at the end of a drive, Norton Disk Doctor (NDD) will
sometimes display this message: An extended partition has invalid parameters and
probably is inaccessible. Correct this situation if you are unable to access partitions on
hard disk 1. Do you wish to correct this problem? To eliminate this message, use
PartitionMagic to resize the logical and extended partitions at the end of the drive to leave
some free space before the end of the drive.
Additionally, when you delete, move, or resize partitions, it appears to NDD that you
could have inadvertently deleted a partition. NDD displays the following message: If you
are unable to access a disk that you previously could, you should revive this partition.
Would you like to revive this partition? If you inadvertently deleted a partition, select
Ye s . If you do not want this message to appear every time you run NDD, complete the
following:
1 Click No.
NDD displays this message: You have chosen not to revive the partition. Do you
want Norton Disk Doctor to mark the partition so it doesnt ask about it again?
2 Click Yes .
The Create Undo File dialog appears.
3 Click Skip Undo File. (Creating an undo file uses many diskettes.)
NDD displays this message: If you wish to undelete this partition at a later time, use
the /UNDELETE switch.
4 Click OK.
NDD displays this message: Partition information has been changed. Would you like
to restart your computer?
5 Click Restart Your Computer.
Nou, ik wordt er niet veel wijzer van :?
maar ja, dit is in ieder geval wat de error betekend...
het zal wel maar wat is wrong boundery ik snap er niets van
als ik bij partition info kijk staan er allemaal verschillende partities van dingen die ik geprobeerd heb (met in totaal veel meer geheugen als dat de shijf aankan. En hij zegtdat hij geen fouten kan vinden. is er niet iets okm een hd te resetten michewin helptdat.
ik heb hem weer voor elkaar. Alleen voor maar 927 Kb (ja echt kb) de rest is bad tenminste dat staat in pm6. het aantal bad geheugen is net zo groot als de linux partitie die ik wou maken. is de schijf nu echt door alleen een partitie aan te maken kapot
Wat is het merk van de harde schijf?
wassup
