Ik ben reeds dagen aan het proberen om mijn lumix FZ1000 als wekcam te gebruiken voor skype webinars. Heb ook een Blackmagic mini videorecorder gekocht maar krijg zelfs geen beeld als ik HDMI kabel rechtstreeks op TV aansluit. Met Sony a7r van mijn vrouw wel.
8)7
Hi!
Try this method
1.The camera will output a LIVE HDMI signal.
2. This signal can be made CLEAN by going to the Setup menu (the wrench menu). Go to page 3/5, and select the top option (TV Connection). Turn off HDMI Info Display (REC). You should also turn off the VIERA Link option, since some recorders don't support or play nice with CEC control.
3. The output is 4K or 1080p, depending on what you set as your recording resolution. [As confirmation, Matt supplied us with a photo showing the input resolution from his 4K Dell monitor, which also showed that it was clean, with no sign of focus peaking or any graphic overlays on the LCD display.]
4. I have confirmed that the 1080 signal output is 4:2:2. I connected the HDMI output into an Odyssey 7Q from Convergent Designs and it showed a true 4:2:2 signal. (The Odyssey will not show me bit depth, but it is safe to assume it is at least 8-bit, and I was told no 10-bit out for the FZ1000).
5. I cannot confirm with the equipment I have that the FZ1000 will output 4K 8-bit 4:2:2, because the Odyssey cannot accept a 4k signal over HDMI. With that revelation I am still confident that the 4K output will be 4:2:2; it would require more processing to get the signal down to 4:2:0, and you would have latency in the Live View. I don't see any of that, so I am certain it is 8-bit 4:2:2.
I found this information here - https://www.imaging-resou...n-output-clean-hdmi-video
  • reneeklo
Hallo guapo69,
Ik heb hetzelfde probleem en ook met de instructies lukt het me niet om beeld te krijgen. Afspelen van fotos en video's is geen enkel probleem.
Is het bij jou gelukt uiteindelijk? Kan je me vertellen wat de oplossing was?
