M'n tv kaart een Studio pctv Rave van Pinnacle geeft als ik me tv aanzet maar 1 beeld en het geluid gaat wel door
weet iemand wat het probleem is?
Alvast bedankt!!
Alvast bedankt!!
If nothing is written below, I was the last to reply...
Suc6 ermee"They have broken overlay support in all of their drivers since the 2.08 version. Here is the info we found:
On AMD systems, it is VERY necessary to update you AGP port drivers. Especially if you have the AlladinV chipset on your motherboard. This will fix a LOT of stability problems.
If you need to use drivers newer than the 2.08 drivers, you can force overlay by changing the registry:
Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services/Services/Display/000#/NVidia/DirectDraw
ADD a new DWORD value called VideoBusMasterMode
Set the Value to 1.
Also, try changing the overlaymode key from 1 to 5.
We found that this fixed the surface overlay with the newer drivers, but the display was just a little bit choppy! Right now, there is nothing we can do about this until NVidia fixes their drivers.
The 2.08 drivers do not have choppy surface overlay."
