• TomN87
  • Registratie: Mei 2015
  • Laatst online: 24-10 20:55
Beste,
Krijg op geen mogelijkheid Windows geboot op een Panasonic CF-19, Linux boot wel Harde schijf ligt het niet aan omdat ik deze al gewisseld heb. Heb een log file gemaakt met boot repair.
Zou iemand hier een blik over kunnen werpen?
Boot Info Script 8f991e4 + Boot-Repair extra info [Boot-Info 25oct2017]
============================= Boot Info Summary: ===============================
=> Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sda.
=> Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows 7/2008: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /bootmgr /Boot/BCD /Windows/System32/winload.exe
sdb1: __________________________________________________________________________
File system: ntfs
Boot sector type: SYSLINUX 6.03
Boot sector info: Syslinux looks at sector 44096 of /dev/sdb1 for its
second stage. The integrity check of Syslinux failed.
Operating System:
Boot files: /boot/grub/grub.cfg /syslinux.cfg /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 2,048 625,137,663 625,135,616 7 NTFS / exFAT / HPFS
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 28.7 GiB, 30752000000 bytes, 60062500 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
/dev/sdb1 * 2,048 60,062,499 60,060,452 7 NTFS / exFAT / HPFS
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/sda1 A6A0CCBBA0CC936B ntfs
/dev/sdb1 96E0E04BE0E03363 ntfs Boot-Repair-Disk 32bit
/dev/zram0 4d09d38c-3348-4c3b-b8dd-eb274bc3f629 swap
/dev/zram1 6f180dd9-2d13-47a3-a54c-d9e2a46811e9 swap
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root 9 Jun 8 18:37 ata-WDC_WD5000LPCX-24C6HT0_WD-WX21E54RK341 -> ../../sda
lrwxrwxrwx 1 root root 10 Jun 8 18:37 ata-WDC_WD5000LPCX-24C6HT0_WD-WX21E54RK341-part1 -> ../../sda1
lrwxrwxrwx 1 root root 9 Jun 8 18:37 usb-SanDisk_Ultra_4C530001020708120484-0:0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Jun 8 18:37 usb-SanDisk_Ultra_4C530001020708120484-0:0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 9 Jun 8 18:37 wwn-0x50014ee604c53e37 -> ../../sda
lrwxrwxrwx 1 root root 10 Jun 8 18:37 wwn-0x50014ee604c53e37-part1 -> ../../sda1
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/loop0 /rofs squashfs (ro,noatime)
/dev/sdb1 /cdrom fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
=========================== sdb1/boot/grub/grub.cfg: ===========================
if loadfont /boot/grub/font.pf2 ; then
set gfxmode=auto
insmod efi_gop
insmod efi_uga
insmod gfxterm
terminal_output gfxterm
fi
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
menuentry "Boot-Repair-Disk session" {
set gfxpayload=keep
linux /casper/vmlinuz.efi file=/cdrom/preseed/lubuntu.seed boot=casper quiet splash --
initrd /casper/initrd.lz
============================== sdb1/syslinux.cfg: ==============================
DEFAULT loadconfig
LABEL loadconfig
CONFIG /isolinux/isolinux.cfg
APPEND /isolinux/
=================== sdb1: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
?? = ?? boot/grub/grub.cfg
================= sdb1: Location of files loaded by Syslinux: ==================
?? = ?? syslinux.cfg
?? = ?? ldlinux.sys 1
ADDITIONAL INFORMATION :
=================== log of boot-repair 20180608_1837 ===================
boot-repair version : 4ppa62
boot-sav version : 4ppa62
boot-sav-extra version : 4ppa62
glade2script version : 3.2.3~ppa4
boot-repair is executed in live-session (Boot-Repair-Disk 32bit 1oct2017, zesty, Ubuntu, i686)
CPU op-mode(s): 32-bit, 64-bit
file=/cdrom/preseed/lubuntu.seed boot=casper initrd=/casper/initrd.lz quiet splash -- debian-installer/language=nl keyboard-configuration/layoutcode?=us keyboard-configuration/variantcode?=intl
ls: cannot access '/home/usr/.config': No such file or directory
The disk contains an unclean file system (0, 0).
The file system wasn't safely closed on Windows. Fixing.
=================== os-prober:
/dev/sda1:Windows 7:Windows:chain
=================== blkid:
/dev/sda1: UUID="A6A0CCBBA0CC936B" TYPE="ntfs" PARTUUID="50190806-01"
/dev/sdb1: LABEL="Boot-Repair-Disk 32bit" UUID="96E0E04BE0E03363" TYPE="ntfs" PARTUUID="28fa2b08-01"
/dev/loop0: TYPE="squashfs"
/dev/zram0: UUID="4d09d38c-3348-4c3b-b8dd-eb274bc3f629" TYPE="swap"
/dev/zram1: UUID="6f180dd9-2d13-47a3-a54c-d9e2a46811e9" TYPE="swap"
1 disks with OS, 1 OS : 0 Linux, 0 MacOS, 1 Windows, 0 unknown type OS.
=================== UEFI/Legacy mode:
This live-session is not EFI-compatible.
SecureBoot maybe enabled.
=================== PARTITIONS & DISKS:
sda1 : sda, not-sepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, is-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, is-winboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, notbiosboot, /mnt/boot-sav/sda1.
sda : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes
=================== parted -lm:
BYT;
/dev/sda:500GB:scsi:512:4096:msdos:ATA WDC WD5000LPCX-2:;
1:1049kB:320GB:320GB:ntfs::boot;
BYT;
/dev/sdb:30.8GB:scsi:512:512:msdos:SanDisk Ultra:;
1:1049kB:30.8GB:30.8GB:ntfs::boot;
BYT;
/dev/zram1:501MB:unknown:4096:4096:loop:Unknown:;
1:0.00B:501MB:501MB:linux-swap(v1)::;
BYT;
/dev/zram0:501MB:unknown:4096:4096:loop:Unknown:;
=================== lsblk:
KNAME TYPE FSTYPE SIZE LABEL
loop0 loop squashfs 642,9M
sda disk 465,8G
sda1 part ntfs 298,1G
sdb disk 28,7G
sdb1 part ntfs 28,7G Boot-Repair-Disk 32bit
zram0 disk 477,9M
zram1 disk 477,9M
KNAME ROTA RO RM STATE MOUNTPOINT
loop0 1 0 0 /rofs
sda 1 0 0 running
sda1 1 0 0 /mnt/boot-sav/sda1
sdb 1 0 1 running
sdb1 1 0 1 /cdrom
zram0 0 0 0 [SWAP]
zram1 0 0 0 [SWAP]
=================== mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=953460k,nr_inodes=206613,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=195756k,mode=755)
/dev/sdb1 on /cdrom type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/loop0 on /rofs type squashfs (ro,noatime)
/cow on / type overlay (rw,relatime,lowerdir=//filesystem.squashfs,upperdir=/cow/upper,workdir=/cow/work)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,relatime)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15423)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=195752k,mode=700,uid=999,gid=999)
gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=999,group_id=999)
/dev/sda1 on /mnt/boot-sav/sda1 type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
=================== ls:
/sys/block/sda (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sda1 size slaves stat subsystem trace uevent
/sys/block/sdb (filtered): alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sdb1 size slaves stat subsystem trace uevent
/dev (filtered): autofs block bsg btrfs-control bus char console core cpu cpu_dma_latency cuse disk dri drm_dp_aux0 ecryptfs fb0 fd full fuse fw0 hidraw0 hpet hugepages hwrng i2c-0 i2c-1 i2c-2 i2c-3 i2c-4 i2c-5 i2c-6 initctl input kmsg lightnvm log mapper mcelog mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx pts random rfkill rtc rtc0 sda sda1 sdb sdb1 sg0 sg1 shm snapshot snd stderr stdin stdout tpm0 uhid uinput urandom userio vfio vga_arbiter vhci vhost-net vhost-vsock zero
ls /dev/mapper: control
=================== hexdump -n512 -C /dev/sda1
00000000 eb 52 90 4e 54 46 53 20 20 20 20 00 02 08 00 00 |.R.NTFS .....|
00000010 00 00 00 00 00 f8 00 00 3f 00 ff 00 00 08 00 00 |........?.......|
00000020 00 00 00 00 80 00 80 00 f8 cf 42 25 00 00 00 00 |..........B%....|
00000030 00 00 0c 00 00 00 00 00 02 00 00 00 00 00 00 00 |................|
00000040 f6 00 00 00 01 00 00 00 6b 93 cc a0 bb cc a0 a6 |........k.......|
00000050 00 00 00 00 fa 33 c0 8e d0 bc 00 7c fb 68 c0 07 |.....3.....|.h..|
00000060 1f 1e 68 66 00 cb 88 16 0e 00 66 81 3e 03 00 4e |..hf......f.>..N|
00000070 54 46 53 75 15 b4 41 bb aa 55 cd 13 72 0c 81 fb |TFSu..A..U..r...|
00000080 55 aa 75 06 f7 c1 01 00 75 03 e9 dd 00 1e 83 ec |U.u.....u.......|
00000090 18 68 1a 00 b4 48 8a 16 0e 00 8b f4 16 1f cd 13 |.h...H..........|
000000a0 9f 83 c4 18 9e 58 1f 72 e1 3b 06 0b 00 75 db a3 |.....X.r.;...u..|
000000b0 0f 00 c1 2e 0f 00 04 1e 5a 33 db b9 00 20 2b c8 |........Z3... +.|
000000c0 66 ff 06 11 00 03 16 0f 00 8e c2 ff 06 16 00 e8 |f...............|
000000d0 4b 00 2b c8 77 ef b8 00 bb cd 1a 66 23 c0 75 2d |K.+.w......f#.u-|
000000e0 66 81 fb 54 43 50 41 75 24 81 f9 02 01 72 1e 16 |f..TCPAu$....r..|
000000f0 68 07 bb 16 68 70 0e 16 68 09 00 66 53 66 53 66 |h...hp..h..fSfSf|
00000100 55 16 16 16 68 b8 01 66 61 0e 07 cd 1a 33 c0 bf |U...h..fa....3..|
00000110 28 10 b9 d8 0f fc f3 aa e9 5f 01 90 90 66 60 1e |(........_...f`.|
00000120 06 66 a1 11 00 66 03 06 1c 00 1e 66 68 00 00 00 |.f...f.....fh...|
00000130 00 66 50 06 53 68 01 00 68 10 00 b4 42 8a 16 0e |.fP.Sh..h...B...|
00000140 00 16 1f 8b f4 cd 13 66 59 5b 5a 66 59 66 59 1f |.......fY[ZfYfY.|
00000150 0f 82 16 00 66 ff 06 11 00 03 16 0f 00 8e c2 ff |....f...........|
00000160 0e 16 00 75 bc 07 1f 66 61 c3 a0 f8 01 e8 09 00 |...u...fa.......|
00000170 a0 fb 01 e8 03 00 f4 eb fd b4 01 8b f0 ac 3c 00 |..............<.|
00000180 74 09 b4 0e bb 07 00 cd 10 eb f2 c3 0d 0a 41 20 |t.............A |
00000190 64 69 73 6b 20 72 65 61 64 20 65 72 72 6f 72 20 |disk read error |
000001a0 6f 63 63 75 72 72 65 64 00 0d 0a 42 4f 4f 54 4d |occurred...BOOTM|
000001b0 47 52 20 69 73 20 6d 69 73 73 69 6e 67 00 0d 0a |GR is missing...|
000001c0 42 4f 4f 54 4d 47 52 20 69 73 20 63 6f 6d 70 72 |BOOTMGR is compr|
000001d0 65 73 73 65 64 00 0d 0a 50 72 65 73 73 20 43 74 |essed...Press Ct|
000001e0 72 6c 2b 41 6c 74 2b 44 65 6c 20 74 6f 20 72 65 |rl+Alt+Del to re|
000001f0 73 74 61 72 74 0d 0a 00 8c a9 be d6 00 00 55 aa |start.........U.|
00000200
=================== df -Th:
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 932M 4.0K 932M 1% /dev
tmpfs tmpfs 192M 6.1M 186M 4% /run
/dev/sdb1 fuseblk 29G 784M 28G 3% /cdrom
/dev/loop0 squashfs 643M 643M 0 100% /rofs
/cow overlay 956M 9.6M 947M 2% /
tmpfs tmpfs 956M 0 956M 0% /dev/shm
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 956M 0 956M 0% /sys/fs/cgroup
tmpfs tmpfs 956M 44K 956M 1% /tmp
tmpfs tmpfs 192M 4.0K 192M 1% /run/user/999
/dev/sda1 fuseblk 299G 190G 109G 64% /mnt/boot-sav/sda1
=================== fdisk -l:
Disk /dev/loop0: 642.9 MiB, 674103296 bytes, 1316608 sectors
Disklabel type: dos
Disk identifier: 0x28fa2b08
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 60062499 60060452 28.7G 7 HPFS/NTFS/exFAT
Disk /dev/zram0: 477.9 MiB, 501129216 bytes, 122346 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 477.9 MiB, 501129216 bytes, 122346 sectors
Disklabel type: dos
Disk identifier: 0x50190806
/dev/sda1 * 2048 625137663 625135616 298.1G 7 HPFS/NTFS/exFAT
=================== Recommended repair
The default repair of the Boot-Repair utility will restore the [(generic mbr)] MBR in sda, and make it boot on sda1.
Additional repair will be performed: unhide-bootmenu-10s
Will restore the MBR_TO_RESTORE : sda (generic mbr) into sda
dd if=/usr/lib/syslinux/mbr/mbr.bin of=/dev/sda
0+1 records in
0+1 records out
Repareren van Boot is geslaagd.
U kunt uw computer nu herstarten.
[ Voor 0% gewijzigd door br00ky op 10-07-2018 20:55 . Reden: Ivm lengte in quote tags gezet ]
