Windows 10 bevries in een half uur twee keerna 5-10 minuten
  • MetalSonic
  • Laatst online: 25-10 21:07
Probleem
Windows 10 crasht in de afgelopen uren steeds na ongeveer 5 tot 10 minuten gamen. Tijdens de crash liep de computer helemaal vast waarbij de computer een vervelend geluid maakte. Computer is gecrasht tijdens Overwatch en tijdens Maelstrom.
CPUID HWMonitor Report
Voor het gamen, valt mij op dat voltages constant springen/ wisselen en cpu niet op 4,1 gigahez staat
]CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.5.0
Monitoring
Mainboard Model Z77X-D3H (0x0000020C - 0x00B845F6)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 01 00 00 00 F3 10 00 00 00 40 80 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 0A 20 00 00 00 00 00 00 00 00 00 00 00 00
70 09 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.06 Volts [0x58] (CPU VTT)
Voltage 1 3.30 Volts [0xA7] (VCC3)
Voltage 2 12.31 Volts [0xAB] (+12V)
Voltage 3 3.34 Volts [0xA7] (+VCC)
Voltage 4 1.00 Volts [0x53] (vAXG)
Voltage 5 0.96 Volts [0x50] (CPU VCORE)
Voltage 6 1.52 Volts [0x7F] (DRAM)
Voltage 7 3.41 Volts [0x8E] (+3.3V)
Temperature 0 48 degC (118 degF) [0x30] (TMPIN0)
Temperature 1 53 degC (127 degF) [0x35] (TMPIN1)
Temperature 2 41 degC (105 degF) [0x29] (TMPIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 1B 10 00 00 FF EF 00 00 00 80 60 05 30 FF FF FF
10 FF FF FF 76 C7 82 80 82 FF FF FF FF FF FF FF FF
20 58 A7 AB A7 53 4F 7F 8E 83 30 35 29 B9 00 C0 C0
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 FF FF FF FF
50 FF D8 7F 7F 7F 40 00 00 90 61 3E 12 65 00 00 00
60 00 00 00 00 00 00 00 FF 00 14 32 46 20 03 00 FF
70 00 14 41 46 1C 03 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF 02 30 01 02 01 E7 E0 2A
90 FF 00 00 00 FF 00 00 00 10 97 00 00 40 1D C1 25
A0 C8 A6 A6 A6 A6 A6 A6 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Display API
Hardware monitor NVIDIA NVAPI
Voltage 0 0.85 Volts [0x352] (GPU)
Power 0 8.26 pc (GPU)
Temperature 0 45 degC (113 degF) [0x2D] (GPU)
Fan 0 0 RPM [0x0] (GPU)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 324.00 MHz [0x87] (Memory)
Processors
Number of sockets 1
Number of threads 8
APICs
Socket 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 2 2
-- Thread 3 3
-- Core 2
-- Thread 4 4
-- Thread 5 5
-- Core 3
-- Thread 6 6
-- Thread 7 7
Timers
ACPI timer 3.580 MHz
Perf timer 3.421 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name Intel Core i7 3770K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1/L1
Technology 22 nm
TDP Limit 77.0 Watts
Tjmax 105.0 °C
Core Speed 3903.3 MHz
Multiplier x Bus Speed 39.0 x 100.1 MHz
Base frequency (cores) 100.1 MHz
Base frequency (ext.) 100.1 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Microcode Revision 0x1C
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
FID/VID Control yes
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
IBRS_ALL not supported
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 39x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 39x
Ratio 2 cores 39x
Ratio 3 cores 39x
Ratio 4 cores 39x
TDP Level 77.0 W @ 35x
Temperature 0 49 degC (120 degF) (Package)
Temperature 1 49 degC (120 degF) (Core #0)
Temperature 2 48 degC (118 degF) (Core #1)
Temperature 3 51 degC (123 degF) (Core #2)
Temperature 4 49 degC (120 degF) (Core #3)
Voltage 0 1.15 Volts (VID #0)
Voltage 1 0.91 Volts (VID #1)
Voltage 2 1.20 Volts (VID #2)
Voltage 3 1.15 Volts (VID #3)
Power 00 14.22 W (Package)
Power 01 9.20 W (IA Cores)
Power 02 n.a. (GT)
Power 03 5.02 W (Uncore)
Clock Speed 0 3903.28 MHz (Core #0)
Clock Speed 1 3903.28 MHz (Core #1)
Clock Speed 2 1601.35 MHz (Core #2)
Clock Speed 3 3903.28 MHz (Core #3)
Core 0 max ratio 39.0 (effective 39.0)
Core 1 max ratio 39.0 (effective 39.0)
Core 2 max ratio 39.0 (effective 39.0)
Core 3 max ratio 39.0 (effective 39.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306A9 0x00100800 0x7F9AE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B2FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000281 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D376920 0x30373733
0x80000004 0x5043204B 0x20402055 0x30352E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00081010 0xF0012300
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x27272727
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001FC 0x00000000 0x0014005F
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000601 0x18141494 0x00000960
MSR 0x00000602 0x18141494 0x00000960
MSR 0x00000610 0x0000A580 0x00009F40
MSR 0x00000611 0x00000000 0xB8CEC79C
MSR 0x00000639 0x00000000 0x808D82F5
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x01E00268
MSR 0x00000648 0x00000000 0x00000023
MSR 0x00000649 0x01E00000 0x00000000
MSR 0x0000064A 0x01E00000 0x00000000
MSR 0x0000064B 0x00000000 0x80000000
MSR 0x0000019C 0x00000000 0x88310000
MSR 0x000001A2 0x00000000 0x00691400
MSR 0x000001B1 0x00000000 0x88310000
MSR 0x00000198 0x000023DE 0x00002700
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x000306A9 0x01100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0xB8CF2070
MSR 0x00000639 0x00000000 0x808DC871
MSR 0x0000019C 0x00000000 0x88300000
MSR 0x000001B1 0x00000000 0x88300000
MSR 0x00000198 0x000024D4 0x00002700
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x000306A9 0x02100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x00000611 0x00000000 0xB8CF7CAC
MSR 0x00000639 0x00000000 0x808E12B7
MSR 0x0000019C 0x00000000 0x88320000
MSR 0x000001B1 0x00000000 0x88320000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x000306A9 0x03100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0xB8CFE7CF
MSR 0x00000639 0x00000000 0x808E6A92
MSR 0x00000198 0x000025A1 0x00002700
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000306A9 0x04100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0xB8D04268
MSR 0x00000639 0x00000000 0x808EB346
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x000306A9 0x05100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0xB8D09D35
MSR 0x00000639 0x00000000 0x808EFAEF
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x000306A9 0x06100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0xB8D0EF99
MSR 0x00000639 0x00000000 0x808F3B81
MSR 0x0000019C 0x00000000 0x882F0000
MSR 0x000001B1 0x00000000 0x882F0000
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x000306A9 0x07100800 0x7F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0xB8D14948
MSR 0x00000639 0x00000000 0x808F820D
MSR 0x0000019C 0x00000000 0x882E0000
MSR 0x000001B1 0x00000000 0x882E0000
Storage
Drive 0
Name M4-CT128M4SSD2
Revision 070H
Serial 0000000012400917EB20
Capacity 119.2 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 118.7 GBytes (33.0 percent available)
Drive 1
Name ST2000DM001-9YN164
Revision CC4H
Serial Z1E1T6VP
Capacity 1863.0 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume d:\, 1863.0 GBytes (31.3 percent available)
Drive 2
Name KINGSTON SV300S37A120G
Revision 521ABBF0
Serial 50026B7741062695
Capacity 111.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume f:\, 111.8 GBytes (40.2 percent available)
USB Devices
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device Generieke USB-hub, class=0x09, subclass=0x00, vendor=0x2109, product=0x0811
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x046D, product=0xC07D
USB Device Generieke USB-hub, class=0x09, subclass=0x00, vendor=0x05E3, product=0x0607
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x046D, product=0xC228
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x046D, product=0xC229
USB Device Samengesteld USB-apparaat, class=0x00, subclass=0x00, vendor=0x03F0, product=0xCE11
USB Device XBOX 360-controller voor Windows, class=0xFF, subclass=0xFF, vendor=0x045E, product=0x028E
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1080204
Name NVIDIA GeForce GTX 980
Board Manufacturer Micro-Star International Co., Ltd. (MSI)
Revision A1
Codename GM204
Technology 28 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1462)
Model ID 0x13C0 (0x3170)
Revision ID 0xA1
Performance Level 0
Core clock 135.0 MHz
Memory clock 324.0 MHz
Monitor 0
Model S24B150 (Samsung)
ID SAM0983
Serial H4MD100401
Manufacturing Date Week 1, Year 2013
Size 23.4 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-81 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
1) na de eerste crash heb ik mijn Nvidia drivers geüpdate naar de nieuwste drivers
2) na mijn 2de crash heb ik een virus scan gedaan (0 resultaten), gekeken of er nog genoeg vrije ruimte is op de SSD (39 GIG)
3) gekeken of er nog beveiligingsupdates zijn? nee
4) nu bezig met deze stappen: https://www.drivereasy.co...-up-randomly-easily/#temp
Edit: 22:45, geheugen laten controleren net de melding gekregen na restart "er zijn geen geheugen fouten gevonden"
Edit: 22:54 , virtual memory vergroot, en verder de C schijf (waar Windows op staat) en de D schijf (opslag schijf) op fouten gecontroleeerd beiden de "geen fouten melding" F Schijf (waar beide games op staan) ook geen fouten
Edit: 23:05, pc is het afgelopen half uur niet gecrasht tijdens gebruik van windows , combinatie van Tweakers en Youtube, ik laat de computer nu (weer) de hele nacht lopen kijken of hij crasht en of het dus echt alleen bij de videogames gebeurt.
Edit 03 juli 2018, 08:47 computer heeft hele nacht aangestaan en muziek afgespeeld gelukkig niet vastgelopen. :)
Wat wellicht zou helpen?
Ik weet niet waarom mijn computer deze avond 2x bevroren is, wat zou helpen is als ik bij mijn crash log kom. Dan hebben we iets waar we verder mee kunnen.
@mods
Ik weet niet of mijn topic hier goed staat, als hij niet goed staat graag verplaatsen. Alvast bedankt.
[ Voor 167% gewijzigd door MetalSonic op 03-07-2018 19:30 ]
  • MAX3400
  • Laatst online: 08:35
MAX3400
XBL: OctagonQontrol
Je zou je eventvwr eens kunnen bekijken en/of je memory.dmp analyseren.
Maar tijdens games is er een (grotere) kans dat jet aan temperaturen of voltages ligt; die kan je ook loggen met verschillende tools en kijken of het nogmaals gebeurt.
  • MetalSonic
MAX3400 schreef op maandag 2 juli 2018 @ 22:17:
Door gegaan met eerder genoemde 10 stappen plan, geheugen goed, geen fouten op de schijven tot nu toe..
Welke programma's raad je aan om temps en voltages te checken? ik kom nietbij een memory.dmp (dit begrijp ik niet). Wil je die toelichten?
  • mrmrmr
mrmrmr
𓅓 𓂋 𓅓 𓂋 𓅓 𓂋
Welke voeding gebruik je? Dat is vaak een oorzaak van instabiliteit bij zware belasting.
Een memory dump wordt weggeschreven na het crashen van een programma. Het bestaat uit hetgeen in het geheugen staat en debug informatie. Het kan soms helpen aan te wijzen waar het probleem zit. Vaak is het een probleem in een Windows API maar ligt de oorzaak elders. Het heeft niets te maken met de kwaliteit van geheugenmodules.
Een aantal memory dump analyse tools voor gebruikers.
  • Klippy
  • Laatst online: 16:31
Klippy
Still Game
Wat bedoel je met een vervelend geluid, komt dit uit je speakers of uit je kast?
Heel veel mechanisch zit er niet in als het uit je kast komt, dus ik zou ook aan temperatuur denken (koeler loopt misschien vast).
Via een van onderstaande tools kan je de temperatuur van je CPU en/of GPU controleren, lijkt me goed begin punt.
Als alles OK is kan je een game starten voor een paar minuten en daarna nog eens kijken.
https://www.howtogeek.com...e-your-cpu-is-running-at/
Steam | SXQncyBhbGwgZ29vZCwgbWFuISDwn5iO
  • MetalSonic
mrmrmr schreef op maandag 2 juli 2018 @ 23:46:
be Quiet 700, ik zal als ik weer thuis ben eens kijken of ik nog een memory dump kan bemachtigen. Heel vreemd dit allemaal.
Voeding: goede kwaliteit, videokaart MSI GTX 980 niet geocd, CPu heeft een Scythen Mugen v3
  • MisterJD
  • Laatst online: 09:10
Als het een soort buzzing sound is, lijkt verdomd veel op het probleem wat ik destijds had met een Skylake based system. Ondanks dat ik de onderdelen aan een stresstest heb onderworpen waar niks uit kwam. Temps die goed waren. En aangezien het probleem optrad onder het gamen, heb ik de gok genomen om de PSU te vervangen aangezien die ook op leeftijd (7 jaar) was. Sindsdien geen problemen meer gehad.
AMD 9800X3D | Noctua NH-D15S chromax | Asus B650m + wifi | Gigabyte RX6800 Gaming OC | G.Skill Flare X 6000 - 32GB | Samsung 990 pro 2TB | Samsung 960 500GB | Samsung G7 27 | MSI MPG A850G | Be quiet pure base 501 LX
  • MetalSonic
MisterJD schreef op dinsdag 3 juli 2018 @ 17:53:
Mijn PSU is 5 jaar oud, 5,5 jaar ik ga zo nog eens wat games draaien. Hopelijk slaan die benchmark progs ook gegevens op want op 't moment dat mijn computer bevriest zie ik 't niet meer
ik zal zo ook eens kijken of 't geluid uit mijn speakers komt of uit de kast
[ Voor 5% gewijzigd door MetalSonic op 03-07-2018 18:53 ]
  • Hackus
Hackus
Lifting Rusty Iron !
@MetalSonic probeer het eens met een nieuwe voeding
  • Uszka
  • Registratie: Maart 2018
  • Laatst online: 15:10
Dat hoor ik vaker. Zonder merk en type valt er niets van te zeggen.
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 19:00:
be quiet! System Power 7 700W ATX22
Hackus schreef op dinsdag 3 juli 2018 @ 18:56:
Zit ik nu ook aan te denken vooral doordat mijn voltages constant een beetje heen en weer springen en de CPU niet meer op 4,1 staat via auto overclock hij hangt nu op 3,9 gigahez. Soms gaan de cores qua clock zelfs naar 1601 mhz..
Of mijn CPU is defect?
[ Voor 48% gewijzigd door MetalSonic op 03-07-2018 19:06 ]
  • Uszka
MetalSonic schreef op dinsdag 3 juli 2018 @ 19:04:
Tsja, het is maar wat je goede kwaliteit noemt. Met een betrouwbare levensduur van een jaar of 6 heb je het wel gehad. De een wat meer, de ander wat minder maar met gemiddeld 6 jaar houdt het wel op.
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 19:23:
Jij nog tips dan? lijkt erop dat ik een nieuwe PSU moet kopen ik dacht aan een Be Quiet 6 650..... ik wil een voeding die krachtig en zo stil mogelijk is
ik denk aan deze:
pricewatch: be quiet! Straight Power 11 650W
[ Voor 14% gewijzigd door MetalSonic op 03-07-2018 19:29 ]
  • FreshMaker
Gaaf zo'n megazwart vlak op mijn mobiel ...
Misschien gewoon beter de MO tag gebruiken, ipv spoiler ?
[ Voor 41% gewijzigd door FreshMaker op 03-07-2018 19:30 ]
  • Uszka
Tips genoeg maar zonder te weten hoe je systeem er, naast de GTX 980, uit ziet valt er geen zinnig advies te geven.
Die ken ik niet. Heb je een link?
Edit: de SP11 650w zie ik. Is vrij zwaar. De SP 11 550w is meer dan genoeg waarschijnlijk.
[ Voor 12% gewijzigd door Uszka op 03-07-2018 19:31 ]
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 19:30:
https://nl.hardware.info/...ew-stilte-kent-zijn-prijs
in mijn OP staat mijn systeem maar hieronder dan nog eens de hoofdcomponenten:
I7 3770K cpu, MSI GTX 980 gpu, Scythen Mugen v3 cpu koeler,
edit in de toekomst wordt mijn gpu vervangen door een 1080 ti of 1180, de PSU wordt meegenomen naar een nieuw systeem waarin ook nog eens een I7 8700K komt dus ik wil wel power
[ Voor 13% gewijzigd door MetalSonic op 03-07-2018 19:34 ]
  • Uszka
Nu staat het wel in de OP ja, net nog niet.
550w heb je meer dan genoeg aan. Meer dan 300w ga je niet gebruiken. Een 8700K met 1080 Ti zal aan de 350w komen. Neem een pricewatch: be quiet! Straight Power 11 550W
[ Voor 45% gewijzigd door Uszka op 03-07-2018 19:36 ]
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 19:34:
Bedankt voor je ondersteuning, argh ik vind dit wel lastig. Ik wil gewoon een super stille en sterke PSU maar nu twijfel ik tussen de 550 en 650... Waarom zou ik 550 nemen ipv 650? Voordeel van 650 is dat je wat meer power hebt voor oc'n, eventueel later waterkoeling of wat dan ook.....
Misschien moet ik Corsair nemen heb ik 10 jaar warranty:
CORSAIR RMx Series, RM650x, 650 Watt, Fully Modular Power Supply, 80+ Gold Certified
pricewatch: Corsair RM650x Zwart
ok ik zie hier dat mijn huidige psu eigenlijk helemaal niet zo stil is, 43 dba onder idle (!)
https://www.techpowerup.c.../StraightPower700W/5.html
ik ga er qua psu sowieso op vooruit qua geluid _O_
Ok het wordt de
https://nl.hardware.info/...ssers-conclusien#comments
RM 650x excellent award :D O+
[ Voor 31% gewijzigd door MetalSonic op 03-07-2018 20:20 ]
  • MetalSonic
CPU TEMP MAX op de 4 cores komt op 92 graden!, net 15 minuten zonder crash kunnen gamen dus ik denk dat 't mijn CPU koeler is die aan vervanging toe is
Afbeeldingslocatie: https://preview.ibb.co/kBLJ4y/max_temps_CPU.jpg
[ Voor 27% gewijzigd door MetalSonic op 03-07-2018 21:07 ]
  • Uszka
Die awards zeggen helemaal niets want bij HWI hebben ze de ballen verstand van voedingen. Er is trouwens een nieuwe versie van die voeding pricewatch: Corsair RM650x (2018)
MetalSonic schreef op dinsdag 3 juli 2018 @ 21:03:
Eerder de koelpasta die vervangen moet worden, defecte fan van de Mugen of hele slechte airflow in de behuizing. Koelpasta en fan kan je heel makkelijk vervangen. Airflow in de behuizing is iets waar je dieper in moet duiken.
[ Voor 8% gewijzigd door Uszka op 03-07-2018 21:40 ]
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 21:38:
Air flow is denk ik wel goed...
1) koelpasta vervangen? dat is wat tussen de CPU en moederbord zit toch? nog tips daarvoor ik zag net in elk geval dat o.a Mediamarkt koelpasta verkoopt
2) geen idee hoe ik kan controleren of de fan van mijn Mugen werkt, dan moet ik de computer aanzetten, zij kant open en dan erin kijken?
  • Uszka
MetalSonic schreef op dinsdag 3 juli 2018 @ 21:44:
Denken is niet genoeg. Welke behuizing heb je, hoeveel casefans zitten daarin en op welk toerental draaien ze?
Tussen cpu en cpukoeler.
CPUkoeler eraf halen, koelpasta van cpu en koeler verwijderen met een niet pluizende doek en een beetje alcohol, een erwt koelpasta op de cpu en de koeler weer monteren.
Onder andere. Je kunt ook in HWMonitor zien of de fan van de koeler draait behalve als de sensor defect is.
  • MetalSonic
Uszka schreef op dinsdag 3 juli 2018 @ 21:51:
behuizing is nanoxia deep silence 3, case fans zijn allemaal Noctua geïnstalleerd door Mycom verder weet ik niet hoeveel fans er zijn en op welk toerental ze draaien.
ok thanks
Morgen maar eens schoonmaak alcohol, koelpasta halen bij de MM zou fijn zijn als ik dit kan oplossen met een paar tientjes
  • Uszka
Een Deep Silence 3 heeft 3 casefans. 2 in het front en 1 achterin. De fans zijn aangesloten op de fancontrollers achter het deurtje van de odd's. Staan de fancontrollers op de laagste stand? Zo ja, deze hoger zetten.
Het komt ook wel eens voor dat achter het moederbord de voedingsstekkers van de fans losraken. Controleer dit.
[ Voor 4% gewijzigd door Uszka op 03-07-2018 22:02 ]
  • Klippy
Klippy
Still Game
MetalSonic schreef op dinsdag 3 juli 2018 @ 21:57:
Ik zou niet meteen te lastig denken.
Eerst eens je zijpaneel van de kast halen en kijken/voelen of de CPU fan draait.
Als dat zo is, voel of er geen beweging in je koeler t.o.v. je moederbord zit, kan best dat de koeler niet (meer) goed vast zit.
Als dat allemaal OK is kan je de pasta gaan vervangen (of kijken of hij er wel op zit).
  • MetalSonic
Klippy schreef op dinsdag 3 juli 2018 @ 22:39:
Dat ga ik vanavond doen inderdaad, er klopt in elk geval iets niet want temps in idle van rond de 50 graden. Wellicht is mijn cpu fan defect geraakt, iemand van Tweakers wel eens een CPU fan vervangen?
  • shadvet
  • Registratie: Juli 2015
  • Laatst online: 16:38
Iedereen die ooit een pc in elkaar heeft gezet weet hoe dit moet.
De meeste fans hebben namelijk een doodsimpel kliksysteempje op het koelblok.
Schroef je kast vanavond maar eens open en kijk even erg goed hoe de fan vast zit, dan kom je er denk ik wel uit.
Losse fans van 120 en 140 mm zijn gewoon te koop online. (uit mijn hoofd heeft de mugen 3 een 120mm fan)
i5-6400, r9 280x, 8g ram, BenQ GW2470H, NZXT S340 Black | i5-4570, XFX 7970, 8g ram, Acer X223W, FD Core1000
  • MetalSonic
shadvet schreef op woensdag 4 juli 2018 @ 09:01:
Net mijn computer open gemaakt, ik heb de buitenste onderdelen weer eens goed schoongemaakt met een luchtdruk spuitbus... Gaf mij tevens de kans om te kijken wat werkte
Front fans x 2, stoffig maar draaide (en super stil), grote fan vlakbij de cpu draaide ook , panel onderkant pc schoon gemaakt
En......... ontdekt wat 't is, beide cpu koeler fans werken niet, beiden stonden stil! zag geen los kabeltje dus ik denk dat ze beiden zijn overleden
Omdat ze beiden kapot zijn kan ik 2 x een noctua fan kopen:
pricewatch: Noctua NF-P12 redux-1700 PWM, 120mm
maar ik kan ook een Dark Rock pro kopen van 70 euro.....
verschil is ongeveer 40 euro..... hmm, wat als ik straks 2 fans koop voor mijn cpu koeler en hij doet nog steeds niks en 't motortje in de koeler kapot is, lastig lastig |:(
Edit: 21:05 toch weer de kast open gemaakt en gecontroleerd op losse draadjes wel ja één van de cpu koeler kabeltjes los verbonden en meteen ging de fan die 't verste van de achterkant van de computer verwijderd is draaien, de ander bleef helaas stil.
Edit: 21:28 kwartiertje Overwatch gedaan, CPU temp max was 74 op één van de cores andere zaten tussen de 71 en 73 al een stuk lager in elk geval dan de 90 die ik eerder zag tijdens mijn game sessie .. De idle temps zijn nog wat hoog maarja nu vraag ik mij af of het normaal is dat één van de 2 fans van de Scythe mugen 3 stil blijft, wellicht pas in actie onder load? of hij is echt kapot? vind de idle temps namelijk nog wat hoog......
nu blijft cpu hangen op rond de 55 graden terwijl ik al niet meer game, zou toch rond de 30 moeten zijn?
[ Voor 41% gewijzigd door MetalSonic op 04-07-2018 21:30 ]
  • shadvet
MetalSonic schreef op woensdag 4 juli 2018 @ 20:33:
Er zit geen motortje in een koelblok, het enige wat kan bewegen zijn fans.
Nu werkt je koeler dus zonder actieve koeling omdat de fan het niet doet?
Gewoon nieuwe fans kopen en deze erop monteren, stuk goedkoper dan een Dark Rock 4
  • MetalSonic
shadvet schreef op donderdag 5 juli 2018 @ 09:00:
Van één van de fans was het draadje los gegaan, degene die het verst afzit van de achterkant van de computer. Nadat ik het draadje (stroom) weer had verbonden ging hij weer draaien. De andere fan, ja mijn koeler heeft er 2 die blijft stil dus ik denk dat ik die ga vervangen.
De temps in idle schommelen rond de 40 á 50 , onder load tussen de 70 en 75
  • shadvet
MetalSonic schreef op donderdag 5 juli 2018 @ 09:03:
Dat is in ieder geval goedkoper dan een nieuwe koeler. Je temps zijn niet gevaarlijk dus het is maar de vraag of het je oorspronkelijke freeze-probleem oplost.
  • MetalSonic
shadvet schreef op donderdag 5 juli 2018 @ 09:59:
Gisteren een half uur gegamed zonder freeze problemen. Lijkt erop (ben voorzichtig) dat freeze problemen weg zijn.
Zojuist maar 2 x een Noctua NF-P12 redux-1700 PWM, 120mm besteld :) ben erg enthousiast over Noctua en als ik de koelpasta ga vervangen en in de kast ga zitten kan ik net zo goed twee gloed nieuwe fans erin zetten
[ Voor 21% gewijzigd door MetalSonic op 05-07-2018 22:54 ]
  • MetalSonic
MetalSonic schreef op woensdag 4 juli 2018 @ 07:46:
Idle temps nu tussen minimaal: 32 en maximaal 40 graden terwijl cpu nu richting 3,9 gigahez overclockt uit zichzelf. Ik ben hier zeer tevreden mee
gevloek dus spoiler
spoiler:
wat een tyfus klote klus was het om de cpu koeler te vervangen op het moederbord, ik heb een grote kast dus 't was vrijwel onmogelijk om de moertjes op de schroefjes vast te draaien. Moederbord bleef in de kast (want door eerder falen van mijzelf kan hij niet meer los) maar man oh man.. 5 uur mee bezig geweest
2 cpu fans vervangen door Noctua, koelpasta vervangen.....
Wat een rotklus was dit zeg dacht meerdere malen dat ik die Scythe mugen 3 niet meer op zijn plek kon krijgen :') en dan nog gegoogld hoe ik die brackets in de fans moest doen (ja eerste keer)
Alles is gelukt maar ik blijf voorlopig af van de koeler en fans :>
Bedankt voor jullie reacties en tips jongens _/-\o_ _/-\o_ _/-\o_ _/-\o_ _/-\o_ _/-\o_ _/-\o_
edit: 09 juli: hele dag gewerkt computer aangedaan blijft hij hangen in het opstartscherm, 4 x opnieuw opgestart oznder dat ik in de bios kon komen. Uieindelijk maar battery eruit gehaald en weer erin. Ik wil geen moederbord van Gigabyte meer hoor. Hierna MSI :/
[ Voor 14% gewijzigd door MetalSonic op 09-07-2018 19:23 ]
