Hoe kom ik af van de ruis uit mijn speakers?
  • ontjie
  • Laatst online: 15-03-2024
Net 2 stuks kustom PA40BATBT speakers ontvangen. Dit sprak mij wel aan omdat je deze kan opladen.
Echter wat mij opvalt is dat dit apparaat direct ruis produceert als je hem aanzet.
Ze zijn dus nergens op aangesloten.
Is het mogelijk om hier vanaf te komen?
Dit zijn de specs
The PA40BATBT Battery Powered 40-Watt P.A. System with built-in Bluetooth capability gives you quality performance and convenient features into an extremely portable all-in-one package. Similar in design to our popular PA50 and PA100 P.A. Systems, the PA40 differs in that we've moved the controls to the front of the unit for your easy access. With a built-in rechargable battery and portable design, the PA40 allows you to take your music anywhere you need it. The PA40BATBT Battery Powered 40-Watt P.A. System gives you quality performance and convenient features into an extremely portable all-in-one package. Similar in design to our popular PA50 and PA100 P.A. Systems, the PA40 differs in that we've moved the controls to the front of the unit for your easy access. With a built-in rechargable battery and portable design, the PA40 allows you to take your music anywhere you need it. With built-in Bluetooth capability, the PA40BATBT allows you to stream music wirelessly from up to 33 feet away from any Bluetooth device, including iPhone, iPad & Android devices. The PA40BATBT features 2 channels controlled by a Master Level Control. The first channel incorporates both a XLR microphone input and a line level input. The second channel consists of an auxiliary input and line level input. Both channels have individual high and low EQ controls and a volume control knob. All four inputs can be used simultaneously. The PA40BATBT has a built-in rechargable battery for up to 10 hours of uninterrupted music, or if AC power is available plug-in directly. The Powerlink Circuit allows two or more units to be linked together and function as one P.A. system. So as your sound grows, your system can, too. Multiple units can be connected to increase the sound coverage in your venue of choice. And for maximum flexibility and convenience, the PA40 has carry handle, rubber feet on the bottom and side, or if you need to place it on a speaker stand has a built-in standard speaker adaptor.
  • .Maarten
  • Laatst online: 11:38
Heb je alle volume regelaars al eens op het laagste gezet?
  • TRAXION
  • Laatst online: 08-10 20:15
En heb je al een bron aangesloten ? Misschien elimineer je daarmee de ruis.
  • ontjie
bedankt voor de reacties
@.Maarten Alles volume regelaars inderdaad uitgestaan
@TRAXION ik heb een digitale piano aangesloten op de line ingang met een jack kabel, het ruis bleef
  • bzzzt
  • Laatst online: 07-10 14:47
PA speakers zijn bedoeld als zaalversterker en geoptimaliseerd om een flinke geluidsdruk te kunnen leveren. Zeker het goedkopere spul gaat dat niet redden zonder ruis. Als je alleen thuis speelt is het waarschijnlijk handiger over een keyboardversterker of studiomonitoren te spelen.
  • ontjie
bzzzt schreef op dinsdag 29 mei 2018 @ 15:53:
speakers van 200 euro per stuk zijn niet echt goedkoop spul toch?
  • Marcel
  • Registratie: Juli 1999
  • Laatst online: 11-10 20:00
Definities van PA speakers daargelaten: als je ze nieuw hebt gekocht zou ik niet lang nadenken en ze retourneren/omruilen.
  • Flimovic
  • Laatst online: 11-10 23:20
Flimovic
PC Gamer / BBQ-liefhebber
ontjie schreef op woensdag 30 mei 2018 @ 12:07:
Het is zeker geen high-end speaker. Maar of het echt goedkoop spul is, ligt aan waar ze voor bedoeld zijn. Als het idd PA's zijn, dan is 200 euro goedkoop.
Steam/Discord: Flimovic
  • bzzzt
Nope, maar ook niet echt high-end. Het verschil zit 'm meer in het feit dat de ingebouwde versterker voor PA doeleinden gebouwd is (40W RMS leveren doen de meeste hifi blikjes niet). Dat je van dichtbij dan wat ruis hoort is wel vrij normaal.
  • TBTL
Uit de handleiding: Hum & Noise: -56 dB (alle regelaars op 0); -52 dB (normaal gebruik).
Dat hoor je inderdaad wel. Er is geen oplossing voor.
