• WingGraph
  • Laatst online: 21-10-2023
hallo iedereen,
ik heb de laatste tijd problemen met mijn computer en mijn geheugen is nog onder garantie.
Ik heb memtest86 laten lopen en memtest86 stopte wegens te veel errors.
Nu wil ik gewoon voor de zekerheid even navragen of het inderdaad klopt, dat mijn geheugen kappot is.
2018-05-08 17:25:18 - Attempting to retrieve the root directory of the data partition.
2018-05-08 17:25:18 - Found 5 handles that supported SimpleFileSystem
2018-05-08 17:25:18 - Checking handle 0 (7AC8CB18)
2018-05-08 17:25:18 - Handle is own partition
2018-05-08 17:25:18 - Checking handle 1 (7AC8CA58)
2018-05-08 17:25:18 - HD node found: MBR type(2), Signature type(2), Part #(2), Start LBA(104448), Num Sectors(202719)
2018-05-08 17:25:18 - Self node: MBR type(2), Signature type(2), Part #(1), Start LBA(2048), Num Sectors(100353)
2018-05-08 17:25:18 - Checking handle 2 (7A31FC98)
2018-05-08 17:25:18 - Checking handle 3 (7A31F698)
2018-05-08 17:25:18 - Checking handle 4 (7A31E858)
2018-05-08 17:25:18 - Could not find Simple Network protocol.
2018-05-08 17:25:18 - =============================================
2018-05-08 17:25:18 - MemTest86 V7.5 Free Build: 1001 (64-bit)
2018-05-08 17:25:18 - SMBIOS BIOS INFO Vendor: "American Megatrends Inc.", Version: "1.J0", Release Date: "12/07/2017"
2018-05-08 17:25:19 - SMBIOS SYSTEM INFO Manufacturer: "MSI", Product: "MS-7976", Version: "1.0", S/N: "Default string", SKU: "", Family: ""
2018-05-08 17:25:19 - SMBIOS: Found SMBIOS BaseboardInformation (pbLinAddr=0x7FEB509B, FormattedLen=15, iTotalLen=91)
2018-05-08 17:25:19 - SMBIOS BASEBOARD INFO Manufacturer: "MSI", Product: "Z170A GAMING M7 (MS-7976)", Version: "1.0", S/N: "F816081278", AssetTag: "Default string", LocationInChassis: "Default string"
2018-05-08 17:25:19 - EFI Specifications: 2.50
2018-05-08 17:25:19 - Found blacklist file
2018-05-08 17:25:19 - [BLACKLIST] Adding "Mac-F42C88C8" (BIOS: "", FLAGS: 1) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Mac-F4238CC8" (BIOS: "", FLAGS: 8) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "80AF" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z97MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170X-Gaming 3" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170X-Gaming 7" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170X-Gaming GT" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170X-UD3-CF" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "Z170-HD3P" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "990FXA-UD3" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "970A-DS3P" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:19 - [BLACKLIST] Adding "X99-Ultra Gaming-CF" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "M5A97 R2.0" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "M5A97 EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "M5A99FX PRO R2.0" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-A" (BIOS: "3701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-A/USB 3.1" (BIOS: "3701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-A II" (BIOS: "1701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-A" (BIOS: "1701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "Sabertooth X99" (BIOS: "3701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "SABERTOOTH 990FX R2.0" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "STRIX X99 GAMING" (BIOS: "1701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-DELUXE" (BIOS: "3701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X99-DELUXE II" (BIOS: "1701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "RAMPAGE V EXTREME" (BIOS: "3701", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "MAXIMUS VIII RANGER" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "Z10PE-D8 WS" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X9DRW" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X9DRW-3LN4F+/X9DRW-3TF+" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:20 - [BLACKLIST] Adding "X9SRL-F" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "X9DRD-iF" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "151-BE-E097" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "131-HE-E095-KR" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "151-HE-E999-KR" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "PRIME B350-PLUS" (BIOS: "", FLAGS: 2) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "PRIME X370-PRO" (BIOS: "", FLAGS: 4) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "CROSSHAIR VI HERO" (BIOS: "1602", FLAGS: 4) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "ROG STRIX X370-F GAMING" (BIOS: "", FLAGS: 4) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "OEMSH Product" (BIOS: "", FLAGS: 8) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] Adding "LNVNB161216" (BIOS: "", FLAGS: 8) to blacklist
2018-05-08 17:25:21 - [BLACKLIST] 41 boards added to blacklist
2018-05-08 17:25:21 - Console Control protocol workaround enabled
2018-05-08 17:25:21 - Number of console modes: 4
2018-05-08 17:25:21 - Mode 0: 80 x 25
2018-05-08 17:25:21 - Mode 1: 80 x 50
2018-05-08 17:25:21 - Mode 2: 100 x 31
2018-05-08 17:25:21 - Mode 3: 128 x 40
2018-05-08 17:25:21 - Initializing localization strings
2018-05-08 17:25:21 - Language en-US is supported
2018-05-08 17:25:21 - Language fr-FR is supported
2018-05-08 17:25:22 - Language it-IT is supported
2018-05-08 17:25:22 - GetGlyph failed for character 0x00F1 (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language es-AR is not supported
2018-05-08 17:25:22 - GetGlyph failed for character 0x00C3 (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language pt-BR is not supported
2018-05-08 17:25:22 - Language ca-ES is supported
2018-05-08 17:25:22 - Language de-DE is supported
2018-05-08 17:25:22 - GetGlyph failed for character 0x010C (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language cs-CZ is not supported
2018-05-08 17:25:22 - Language ru-RU is supported
2018-05-08 17:25:22 - GetGlyph failed for character 0x3041 (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language ja-JP is not supported
2018-05-08 17:25:22 - GetGlyph failed for character 0x4E0F (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language zh-CN is not supported
2018-05-08 17:25:22 - GetGlyph failed for character 0xF944 (Warning Unknown Glyph)
2018-05-08 17:25:22 - Language zh-HK is not supported
2018-05-08 17:25:23 - Font does not support all languages. Installing unicode font...
2018-05-08 17:25:23 - InitFont - Font header version: 1.1
2018-05-08 17:25:23 - InitFont - Number of narrow glyphs: 6969
2018-05-08 17:25:23 - InitFont - Number of wide glyphs: 50117
2018-05-08 17:25:23 - Language en-US is supported
2018-05-08 17:25:23 - Language fr-FR is supported
2018-05-08 17:25:23 - Language it-IT is supported
2018-05-08 17:25:23 - Language es-AR is supported
2018-05-08 17:25:23 - Language pt-BR is supported
2018-05-08 17:25:23 - Language ca-ES is supported
2018-05-08 17:25:23 - Language de-DE is supported
2018-05-08 17:25:23 - Language cs-CZ is supported
2018-05-08 17:25:23 - Language ru-RU is supported
2018-05-08 17:25:23 - Language ja-JP is supported
2018-05-08 17:25:23 - Language zh-CN is supported
2018-05-08 17:25:24 - Language zh-HK is supported
2018-05-08 17:25:24 - Initializing screen for graphics
2018-05-08 17:25:24 - Getting CPUID
2018-05-08 17:25:24 - Getting cache size
2018-05-08 17:25:24 - get_cache_size - Vendor ID: GenuineIntel Brand ID: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
2018-05-08 17:25:24 - L1 data cache: 32, 2, 8 [0x1C004121]
2018-05-08 17:25:24 - L0 cache: 0 KB (1)
2018-05-08 17:25:24 - L1 instruction cache size: 4 x 32KB
2018-05-08 17:25:24 - L1 data cache size: 4 x 32KB
2018-05-08 17:25:24 - L2 cache size: 4 x 256KB
2018-05-08 17:25:24 - L3 cache size: 8192KB
2018-05-08 17:25:24 - Measuring CPU/cache/mem speed
2018-05-08 17:25:24 - hpet_init - Found RSDP. Version: 2
2018-05-08 17:25:24 - hpet_init - Found XSDT. Entry Count: 19
2018-05-08 17:25:24 - hpet_init - Found ACPI table: FACP Version: 6
2018-05-08 17:25:24 - hpet_init - Found ACPI table: APIC Version: 3
2018-05-08 17:25:24 - hpet_init - Found ACPI table: FPDT Version: 1
2018-05-08 17:25:24 - hpet_init - Found ACPI table: MCFG Version: 1
2018-05-08 17:25:24 - hpet_init - Found ACPI table: SSDT Version: 1
2018-05-08 17:25:24 - hpet_init - Found ACPI table: FIDT Version: 1
2018-05-08 17:25:25 - hpet_init - Found ACPI table: SSDT Version: 2
2018-05-08 17:25:25 - hpet_init - Found ACPI table: HPET Version: 1
2018-05-08 17:25:25 - hpet_init - HPET base address: 0xFED00000
2018-05-08 17:25:25 - hpet_init - HPET gen cap: 0x27BC86B8086A701 (Period: 41666667fs)
2018-05-08 17:25:25 - hpet_init - HPET gen cfg: 0x1
2018-05-08 17:25:25 - hpet_init - main counter value (1): 578468238
2018-05-08 17:25:25 - hpet_init - main counter value (2): 579383474
2018-05-08 17:25:25 - cpuspeed_hpet - rdtsc instruction supported: 1
2018-05-08 17:25:25 - cpuspeed_hpet - HPET counter start: 581728057, HPET counter end: 582928056
2018-05-08 17:25:25 - cpuspeed_hpet - start TSC: 102452736669, end TSC: 102655187489 (difference: 202450820)
2018-05-08 17:25:25 - cpu_cache_speed - (Attempt 1) clock cycle (ms): 4049016
2018-05-08 17:25:25 - cpuspeed_hpet - HPET counter start: 587458041, HPET counter end: 588658040
2018-05-08 17:25:25 - cpuspeed_hpet - start TSC: 103446572429, end TSC: 103649035179 (difference: 202462750)
2018-05-08 17:25:25 - cpu_cache_speed - (Attempt 2) clock cycle (ms): 4049255
2018-05-08 17:25:26 - cpuspeed_hpet - HPET counter start: 594222818, HPET counter end: 595422817
2018-05-08 17:25:26 - cpuspeed_hpet - start TSC: 104613404059, end TSC: 104815866788 (difference: 202462729)
2018-05-08 17:25:26 - cpu_cache_speed - (Attempt 3) clock cycle (ms): 4049254
2018-05-08 17:25:26 - cpu_cache_speed - Using average of last 3 samples (4049254, 4049255, 4049016)
2018-05-08 17:25:26 - cpu_cache_speed - CPU speed: 4049.1MHz
2018-05-08 17:25:26 - cpu_cache_speed - measuring L1 cache speed at 0x796D1000 (32 KB)
2018-05-08 17:25:26 - cpu_cache_speed - L1 cache speed: 257601 MB/s
2018-05-08 17:25:26 - cpu_cache_speed - measuring L2 cache speed at 0x79699000 (256 KB)
2018-05-08 17:25:26 - cpu_cache_speed - L2 cache speed: 112233 MB/s
2018-05-08 17:25:26 - cpu_cache_speed - measuring L3 cache speed at 0x78660000 (8192 KB)
2018-05-08 17:25:26 - cpu_cache_speed - L3 cache speed: 61628 MB/s
2018-05-08 17:25:26 - get_mem_speed - measuring mem speed at 0x74BE0000 (68096 KB)
2018-05-08 17:25:26 - get_mem_speed - mem speed: 20915 MB/s
2018-05-08 17:25:27 - cpu_cache_speed - Memory latency: 20.901 ns
2018-05-08 17:25:27 - Retrieving CPU MSR data
2018-05-08 17:25:27 - GetIntelArchitectureSpecificMSRInfo - CPU Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz: 6.94
2018-05-08 17:25:27 - GetIntelArchitectureSpecificMSRInfo - Nehalem et al detected
2018-05-08 17:25:27 - GetSkylakeFamilyMSRInfo_Static - MSR[0xCE] = 00080838F1012800
2018-05-08 17:25:27 - GetSkylakeFamilyMSRInfo_Static - MSR[0x1A2] = 0000000000641400
2018-05-08 17:25:27 - GetSkylakeFamilyMSRInfo_Static - MSR[0x1AD] = 000000002828282A
2018-05-08 17:25:27 - IsIntelTurboSupported - CPUID[0x6][EAX] = 000027F7
2018-05-08 17:25:27 - DisableTurboMode - MSR[1A0] = 0000000000850089
2018-05-08 17:25:28 - DisableTurboMode - New MSR[1A0] = 0000004000850089
2018-05-08 17:25:28 - GetIntelArchitectureSpecificMSRInfo - Turbo disabled
2018-05-08 17:25:28 - IsIntel_PerfMon_Supported - CPUID[0xA][EDX] = 00000603
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - CPUID[0xA][EDX] = 00000603
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38F] = 000000000000000F
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38D] = 0000000000000000
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x199] = 0000000000002800
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x198] = 0000269200002800
2018-05-08 17:25:28 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - high perf counter freq = 4049175000
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - time in ns = 495484712
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - FreqCore in KHz = 4041030, FreqRef in KHz = 4049174, Ratio = 99
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - CPUID[0xA][EDX] = 00000603
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38F] = 000000000000000F
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38D] = 0000000000000000
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x199] = 0000000000002800
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x198] = 0000268F00002800
2018-05-08 17:25:29 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - high perf counter freq = 4049175000
2018-05-08 17:25:30 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - time in ns = 495500250
2018-05-08 17:25:30 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - FreqCore in KHz = 4041030, FreqRef in KHz = 4049175, Ratio = 99
2018-05-08 17:25:30 - GetIntelArchitectureSpecificMSRInfo - MaxRatio = 99
2018-05-08 17:25:30 - GetIntelArchitectureSpecificMSRInfo - Mult = 3960
2018-05-08 17:25:30 - GetIntelArchitectureSpecificMSRInfo - raw_freq_cpu = 4049160
2018-05-08 17:25:31 - EnableTurboMode - MSR[1A0] = 0000004000850089
2018-05-08 17:25:31 - EnableTurboMode - New MSR[1A0] = 0000000000850089
2018-05-08 17:25:31 - EnableTurboMode - MSR[0x198] = 0000269900002800 (Current multiplier: 40)
2018-05-08 17:25:31 - EnableTurboMode - MSR[0x199] = 0000000000002800 (Target multiplier: 40, Max1CTurbo: 42)
2018-05-08 17:25:31 - EnableTurboMode - Setting MSR[0x199] to 0000000000002A00
2018-05-08 17:25:31 - EnableTurboMode - New MSR[0x199] = 0000000000002A00 (Target multiplier: 42)
2018-05-08 17:25:31 - GetIntelArchitectureSpecificMSRInfo - TargetRatio = 102
2018-05-08 17:25:31 - IsIntel_PerfMon_Supported - CPUID[0xA][EDX] = 00000603
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - CPUID[0xA][EDX] = 00000603
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38F] = 000000000000000F
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x38D] = 0000000000000000
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x199] = 0000000000002A00
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - MSR[0x198] = 0000269900002800
2018-05-08 17:25:31 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - high perf counter freq = 4049175000
2018-05-08 17:25:32 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - time in ns = 495455591
2018-05-08 17:25:32 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - FreqCore in KHz = 4041030, FreqRef in KHz = 4049174, Ratio = 99
2018-05-08 17:25:34 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - time in ns = 495524716
2018-05-08 17:25:34 - GetIntelCPUMaxSpeed_CPU_CLK_UNHALTED - FreqCore in KHz = 4041030, FreqRef in KHz = 4049174, Ratio = 99
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - MaxTurboRatio = 99
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - TurboMult = 3960
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - new TurboMult = 4000
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - CPUSpeedTurbo = 4049160
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - CPUSpeedTurboTheoreticalMax = 4251618
2018-05-08 17:25:34 - GetIntelArchitectureSpecificMSRInfo - Freq: 4049160, 4000, 101229, Turbo: 4049160, 4000, 0 (4251618)
2018-05-08 17:25:34 - Getting memory size
2018-05-08 17:25:34 - 0x000000000000 - 0x000000057FFF (352KB) {Free Memory}
2018-05-08 17:25:34 - 0x000000058000 - 0x000000058FFF (4KB) {Reserved Memory}
2018-05-08 17:25:34 - 0x000000059000 - 0x00000009DFFF (276KB) {Free Memory}
2018-05-08 17:25:35 - 0x00000009E000 - 0x00000009FFFF (8KB) {Reserved Memory}
2018-05-08 17:25:35 - 0x000000100000 - 0x00000FFFFFFF (255MB) {Free Memory}
2018-05-08 17:25:35 - 0x000010000000 - 0x00001000AFFF (44KB) {Boot Services Code}
2018-05-08 17:25:35 - 0x00001000B000 - 0x00005F6BFFFF (1270MB) {Free Memory}
2018-05-08 17:25:35 - 0x00005F6C0000 - 0x00005F6FFFFF (256KB) {Boot Services Data}
2018-05-08 17:25:35 - 0x00005F700000 - 0x00006F0F9FFF (249MB) {Free Memory}
2018-05-08 17:25:35 - 0x00006F0FA000 - 0x00006F201FFF (1056KB) {Loader Code}
2018-05-08 17:25:35 - 0x00006F202000 - 0x00006F23DFFF (240KB) {Loader Data}
2018-05-08 17:25:35 - 0x00006F23E000 - 0x00006F600FFF (3MB) {Boot Services Data}
2018-05-08 17:25:35 - 0x00006F601000 - 0x00006F601FFF (4KB) {ACPI Non-volatile}
2018-05-08 17:25:35 - 0x00006F602000 - 0x00006F602FFF (4KB) {Runtime Services Data}
2018-05-08 17:25:35 - 0x00006F603000 - 0x00006F6AFFFF (692KB) {Boot Services Data}
2018-05-08 17:25:35 - 0x00006F6B0000 - 0x00006F6BEFFF (60KB) {Loader Data}
2018-05-08 17:25:35 - 0x00006F6BF000 - 0x00007E0A8FFF (233MB) {Boot Services Data}
2018-05-08 17:25:35 - 0x00007E0A9000 - 0x00007E316FFF (2MB) {Free Memory}
2018-05-08 17:25:35 - 0x00007E317000 - 0x00007EBAFFFF (8MB) {Boot Services Code}
2018-05-08 17:25:35 - 0x00007EBB0000 - 0x00007EEE8FFF (3MB) {Reserved Memory}
2018-05-08 17:25:35 - 0x00007EEE9000 - 0x00007F380FFF (4MB) {Free Memory}
2018-05-08 17:25:35 - 0x00007F381000 - 0x00007F6F6FFF (3MB) {ACPI Non-volatile}
2018-05-08 17:25:35 - 0x00007F6F7000 - 0x00007FF84FFF (8MB) {Runtime Services Data}
2018-05-08 17:25:36 - 0x00007FF85000 - 0x00007FFFEFFF (488KB) {Runtime Services Code}
2018-05-08 17:25:36 - 0x00007FFFF000 - 0x00007FFFFFFF (4KB) {Boot Services Data}
2018-05-08 17:25:36 - 0x000100000000 - 0x000476BFFFFF (14188MB) {Free Memory}
2018-05-08 17:25:36 - 0x0000000A0000 - 0x0000000FFFFF (384KB) {Reserved Memory}
2018-05-08 17:25:36 - 0x000080000000 - 0x000087FFFFFF (128MB) {Reserved Memory}
2018-05-08 17:25:36 - 0x000088000000 - 0x0000883FFFFF (4MB) {Reserved Memory}
2018-05-08 17:25:36 - 0x0000E0000000 - 0x0000EFFFFFFF (256MB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - 0x0000FE000000 - 0x0000FE010FFF (68KB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - 0x0000FEC00000 - 0x0000FEC00FFF (4KB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - 0x0000FED00000 - 0x0000FED00FFF (4KB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - 0x0000FEE00000 - 0x0000FEE00FFF (4KB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - 0x0000FF000000 - 0x0000FFFFFFFF (16MB) {OS Memory-mapped IO}
2018-05-08 17:25:36 - Available Memory: 0x3E6352000 (15GB)
2018-05-08 17:25:36 - Reserved Memory: 0x29CC2000 (668MB)
2018-05-08 17:25:36 - mem_size - Number of entries: 35
2018-05-08 17:25:36 - mem_size - Max address: 0x476C00000
2018-05-08 17:25:36 - mem_size - Total memory size (17017262080 bytes)
2018-05-08 17:25:37 - Getting memory SPD info
2018-05-08 17:25:37 - Attempting to enable any disabled SMBus controllers...
2018-05-08 17:25:37 - Attempting to enable SMBUS:
2018-05-08 17:25:37 - Searching PCI for SMBus Controller
2018-05-08 17:25:37 - Found SMBus device: VID:8086 DID:A123 Bus:00 Dev:1F Fun:04 IO Add:F000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:31 [Intel Sunrise Point-H]
2018-05-08 17:25:37 - Finished searching PCI for SMBus Controller
2018-05-08 17:25:37 - Raw SPD bytes for DIMM#0:
2018-05-08 17:25:37 - 23 10 0C 02 85 21 00 08 00 00 00 03 01 03 00 00
2018-05-08 17:25:37 - 00 00 08 0C FC 03 00 00 6C 6C 71 11 08 74 F0 0A
2018-05-08 17:25:37 - 20 08 00 05 00 A8 1E 2B 2B 00 00 00 00 00 00 00
2018-05-08 17:25:38 - 00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36
2018-05-08 17:25:38 - 16 36 16 36 00 00 2B 0C 2B 0C 2B 0C 2B 0C 00 00
2018-05-08 17:25:38 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:38 - 00 00 00 00 00 ED B5 CF 00 C0 00 00 00 C2 ED 51
2018-05-08 17:25:38 - 11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:38 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6 58
2018-05-08 17:25:38 - 02 9E 00 00 00 00 00 00 00 43 4D 4B 31 36 47 58
2018-05-08 17:25:39 - 34 4D 32 42 33 30 30 30 43 31 35 20 20 00 80 AD
2018-05-08 17:25:39 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:39 - 0C 4A 01 20 00 00 00 00 00 A3 00 00 06 FC 3F 04
2018-05-08 17:25:39 - 00 50 5B 5B 10 BA 16 F0 0A 20 08 00 05 00 B0 20
2018-05-08 17:25:39 - 2B 00 00 00 00 00 00 00 00 D3 00 BA D3 D3 00 AD
2018-05-08 17:25:39 - Raw SPD bytes for DIMM#1:
2018-05-08 17:25:39 - 23 10 0C 02 85 21 00 08 00 00 00 03 01 03 00 00
2018-05-08 17:25:39 - 00 00 08 0C FC 03 00 00 6C 6C 71 11 08 74 F0 0A
2018-05-08 17:25:39 - 20 08 00 05 00 A8 1E 2B 2B 00 00 00 00 00 00 00
2018-05-08 17:25:40 - 00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36
2018-05-08 17:25:40 - 16 36 16 36 00 00 2B 0C 2B 0C 2B 0C 2B 0C 00 00
2018-05-08 17:25:40 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:40 - 00 00 00 00 00 ED B5 CF 00 C0 00 00 00 C2 ED 51
2018-05-08 17:25:40 - 11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:40 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6 58
2018-05-08 17:25:41 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-05-08 17:25:41 - 02 9E 00 00 00 00 00 00 00 43 4D 4B 31 36 47 58
2018-05-08 17:25:41 - 34 4D 32 42 33 30 30 30 43 31 35 20 20 00 80 AD
2018-05-08 17:25:41 - 0C 4A 01 20 00 00 00 00 00 A3 00 00 06 FC 3F 04
2018-05-08 17:25:41 - 00 50 5B 5B 10 BA 16 F0 0A 20 08 00 05 00 B0 20
2018-05-08 17:25:41 - 2B 00 00 00 00 00 00 00 00 D3 00 BA D3 D3 00 AD
2018-05-08 17:25:41 - Getting memory controller info
2018-05-08 17:25:41 - find_mem_controller - found Intel Skylake (8086:191F) at 0-0-0
2018-05-08 17:25:41 - Intel Skylake chipset init
2018-05-08 17:25:41 - MCHBAR_LO=FED10001
2018-05-08 17:25:42 - MCHBAR_HI=00000000
2018-05-08 17:25:42 - MCHBAR=FED10000
2018-05-08 17:25:42 - CAPID0_A=6201267D
2018-05-08 17:25:42 - INTRA_MAD_0=00000111, INTRA_MAD_1=00000111
2018-05-08 17:25:42 - ERRSTS=0000
2018-05-08 17:25:42 - find_mem_controller - Intel Skylake (8086:191F) at 0-0-0
2018-05-08 17:25:42 - find_mem_controller - Intel Skylake ECC mode: detect: no, correct: no, scrub: no, chipkill: no
2018-05-08 17:25:42 - ECC polling disabled
2018-05-08 17:25:42 - Successfully located the PI MpService protocol.
2018-05-08 17:25:42 - BSP is Proc 0
2018-05-08 17:25:42 - This platform has 8 logical processors of which 8 are enabled.
2018-05-08 17:25:42 - ProcID Enabled Type Status Pkg Core Thread Hyperthread?
2018-05-08 17:25:42 - -------- -------- ---- -------- ----- ---- ------ ------------
2018-05-08 17:25:42 - 00000000 Y BSP 00000007 0 0 0 N
2018-05-08 17:25:42 - 00000001 Y AP 00000006 0 0 1 Y
2018-05-08 17:25:42 - 00000002 Y AP 00000006 0 1 0 N
2018-05-08 17:25:42 - 00000003 Y AP 00000006 0 1 1 Y
2018-05-08 17:25:42 - 00000004 Y AP 00000006 0 2 0 N
2018-05-08 17:25:42 - 00000005 Y AP 00000006 0 2 1 Y
2018-05-08 17:25:42 - 00000006 Y AP 00000006 0 3 0 N
2018-05-08 17:25:43 - 00000007 Y AP 00000006 0 3 1 Y
2018-05-08 17:25:43 - Number of hyperthreads detected: 4
2018-05-08 17:25:43 - Disabling all hyperthreads
2018-05-08 17:25:43 - Disabling hyperthread processor 1
2018-05-08 17:25:43 - Disabling hyperthread processor 3
2018-05-08 17:25:43 - Disabling hyperthread processor 5
2018-05-08 17:25:43 - Disabling hyperthread processor 7
2018-05-08 17:25:43 - This platform has 8 logical processors of which 8 are enabled.
2018-05-08 17:25:43 - Testing MP support
2018-05-08 17:25:43 - MPSupportTestMPServices - AP dispatch test
2018-05-08 17:25:43 - MPSupportTestMPServices - Starting AP#2
2018-05-08 17:25:43 - MPSupportTestMPServices - Starting AP#4
2018-05-08 17:25:43 - MPSupportTestMPServices - Starting AP#6
2018-05-08 17:25:43 - MPSupportTestMPServices - Waiting for AP's to complete execution
2018-05-08 17:25:44 - MPSupportTestMPServices - CPU #2 finished execution
2018-05-08 17:25:44 - MPSupportTestMPServices - CPU #4 finished execution
2018-05-08 17:25:44 - MPSupportTestMPServices - CPU #6 finished execution
2018-05-08 17:25:44 - MPSupportTestMPServices - AP dispatch test complete
2018-05-08 17:25:44 - MP test passed. Setting default CPU mode to PARALLEL
2018-05-08 17:25:45 - Applying configurations
2018-05-08 17:25:45 - [CONFIG] This platform has 8 logical processors of which 4 are enabled.
2018-05-08 17:25:45 - Console size = 80 x 25
2018-05-08 17:25:45 - Screen resolution is too high (3840 x 2160). Setting screen size to the minimum 1024 x 768
2018-05-08 17:25:45 - New screen size = 1024 x 768
2018-05-08 17:25:45 - Screen size = 1024 x 768
2018-05-08 17:25:45 - Char width=8 height=19
2018-05-08 17:25:45 - Loading images
2018-05-08 17:25:51 - Screen resolution is too high (3840 x 2160). Setting screen size to the minimum 1024 x 768
2018-05-08 17:25:51 - New screen size = 1024 x 768
2018-05-08 17:25:51 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88340800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:25:51 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 17:26:28 - *** TEST SESSION - 2018-05-08 17:26:28 ***
2018-05-08 17:26:29 - CPU selection mode = 1
2018-05-08 17:26:29 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88370800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:26:29 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 17:26:29 - Starting pass #1 (of 4)
2018-05-08 17:26:29 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88350800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:26:29 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
2018-05-08 17:26:29 - MtSupportRunAllTests - Setting random seed to 0x50415353
2018-05-08 17:26:29 - MtSupportRunAllTests - Start time: 475 ms
2018-05-08 17:26:29 - ReadMemoryRanges - Available Pages = 4088658
2018-05-08 17:26:29 - MtSupportRunAllTests - Enabling memory cache for test
2018-05-08 17:26:29 - MtSupportRunAllTests - Enabling memory cache complete
2018-05-08 17:26:29 - Start memory range test (0x0 - 0x476C00000)
2018-05-08 17:26:29 - Pre-allocating memory ranges >=16MB first...
2018-05-08 17:26:29 - All memory ranges successfully locked
2018-05-08 17:26:30 - Cleanup - Releasing all memory ranges...
2018-05-08 17:26:30 - MtSupportRunAllTests - Test execution time: 0.615 (Test 0 cumulative error count: 0)
2018-05-08 17:26:30 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88350800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:26:30 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 17:26:30 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
2018-05-08 17:26:30 - MtSupportRunAllTests - Setting random seed to 0x50415353
2018-05-08 17:26:30 - MtSupportRunAllTests - Start time: 1663 ms
2018-05-08 17:26:30 - ReadMemoryRanges - Available Pages = 4088658
2018-05-08 17:26:30 - MtSupportRunAllTests - Enabling memory cache for test
2018-05-08 17:26:30 - MtSupportRunAllTests - Enabling memory cache complete
2018-05-08 17:26:30 - Start memory range test (0x0 - 0x476C00000)
2018-05-08 17:26:30 - Pre-allocating memory ranges >=16MB first...
2018-05-08 17:26:30 - All memory ranges successfully locked
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173B23780, Expected: 0000000173B23780, Actual: 0000200173B23780
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173B24B50, Expected: 0000000173B24B50, Actual: 0000200173B24B50
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173B25508, Expected: 0000000173B25508, Actual: 0000200173B25508
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173B27348, Expected: 0000000173B27348, Actual: 0000200173B27348
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D215D8, Expected: 0000000173D215D8, Actual: 0000200173D215D8
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D21AC8, Expected: 0000000173D21AC8, Actual: 0000200173D21AC8
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D23380, Expected: 0000000173D23380, Actual: 0000200173D23380
2018-05-08 17:26:31 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D23780, Expected: 0000000173D23780, Actual: 0000200173D23780
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D24008, Expected: 0000000173D24008, Actual: 0000200173D24008
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D25508, Expected: 0000000173D25508, Actual: 0000200173D25508
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D26200, Expected: 0000000173D26200, Actual: 0000200173D26200
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173D27348, Expected: 0000000173D27348, Actual: 0000200173D27348
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F23780, Expected: 0000000173F23780, Actual: 0000200173F23780
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F24008, Expected: 0000000173F24008, Actual: 0000200173F24008
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F24B50, Expected: 0000000173F24B50, Actual: 0000200173F24B50
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F25508, Expected: 0000000173F25508, Actual: 0000200173F25508
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F26200, Expected: 0000000173F26200, Actual: 0000200173F26200
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 173F27348, Expected: 0000000173F27348, Actual: 0000200173F27348
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175727348, Expected: 0000000175727348, Actual: 0000200175727348
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175923780, Expected: 0000000175923780, Actual: 0000200175923780
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175925508, Expected: 0000000175925508, Actual: 0000200175925508
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175927348, Expected: 0000000175927348, Actual: 0000200175927348
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175B23780, Expected: 0000000175B23780, Actual: 0000200175B23780
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175B25508, Expected: 0000000175B25508, Actual: 0000200175B25508
2018-05-08 17:26:32 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175B27348, Expected: 0000000175B27348, Actual: 0000200175B27348
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175B27F40, Expected: 0000000175B27F40, Actual: 0000200175B27F40
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175D23780, Expected: 0000000175D23780, Actual: 0000200175D23780
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175D25508, Expected: 0000000175D25508, Actual: 0000200175D25508
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175F23780, Expected: 0000000175F23780, Actual: 0000200175F23780
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175F25508, Expected: 0000000175F25508, Actual: 0000200175F25508
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 175F27F40, Expected: 0000000175F27F40, Actual: 0000200175F27F40
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176123780, Expected: 0000000176123780, Actual: 0000200176123780
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176125508, Expected: 0000000176125508, Actual: 0000200176125508
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176127F40, Expected: 0000000176127F40, Actual: 0000200176127F40
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176323780, Expected: 0000000176323780, Actual: 0000200176323780
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176325508, Expected: 0000000176325508, Actual: 0000200176325508
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176327348, Expected: 0000000176327348, Actual: 0000200176327348
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176327F40, Expected: 0000000176327F40, Actual: 0000200176327F40
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176523780, Expected: 0000000176523780, Actual: 0000200176523780
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176525508, Expected: 0000000176525508, Actual: 0000200176525508
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176527348, Expected: 0000000176527348, Actual: 0000200176527348
2018-05-08 17:26:33 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176527F40, Expected: 0000000176527F40, Actual: 0000200176527F40
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176723780, Expected: 0000000176723780, Actual: 0000200176723780
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176725508, Expected: 0000000176725508, Actual: 0000200176725508
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176727F40, Expected: 0000000176727F40, Actual: 0000200176727F40
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176923780, Expected: 0000000176923780, Actual: 0000200176923780
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176924B50, Expected: 0000000176924B50, Actual: 0000200176924B50
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176925508, Expected: 0000000176925508, Actual: 0000200176925508
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176927348, Expected: 0000000176927348, Actual: 0000200176927348
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176927F40, Expected: 0000000176927F40, Actual: 0000200176927F40
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176B23780, Expected: 0000000176B23780, Actual: 0000200176B23780
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176B25508, Expected: 0000000176B25508, Actual: 0000200176B25508
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176B27348, Expected: 0000000176B27348, Actual: 0000200176B27348
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176B27F40, Expected: 0000000176B27F40, Actual: 0000200176B27F40
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176D23780, Expected: 0000000176D23780, Actual: 0000200176D23780
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176D25508, Expected: 0000000176D25508, Actual: 0000200176D25508
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176D27348, Expected: 0000000176D27348, Actual: 0000200176D27348
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176D27F40, Expected: 0000000176D27F40, Actual: 0000200176D27F40
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176F23780, Expected: 0000000176F23780, Actual: 0000200176F23780
2018-05-08 17:26:34 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176F25508, Expected: 0000000176F25508, Actual: 0000200176F25508
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176F26200, Expected: 0000000176F26200, Actual: 0000200176F26200
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176F27348, Expected: 0000000176F27348, Actual: 0000200176F27348
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 176F27F40, Expected: 0000000176F27F40, Actual: 0000200176F27F40
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177123780, Expected: 0000000177123780, Actual: 0000200177123780
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177125508, Expected: 0000000177125508, Actual: 0000200177125508
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177126200, Expected: 0000000177126200, Actual: 0000200177126200
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177127348, Expected: 0000000177127348, Actual: 0000200177127348
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177127F40, Expected: 0000000177127F40, Actual: 0000200177127F40
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177323780, Expected: 0000000177323780, Actual: 0000200177323780
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177325508, Expected: 0000000177325508, Actual: 0000200177325508
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177326200, Expected: 0000000177326200, Actual: 0000200177326200
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177327348, Expected: 0000000177327348, Actual: 0000200177327348
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177327F40, Expected: 0000000177327F40, Actual: 0000200177327F40
2018-05-08 17:26:35 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177523780, Expected: 0000000177523780, Actual: 0000200177523780
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177525508, Expected: 0000000177525508, Actual: 0000200177525508
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177526200, Expected: 0000000177526200, Actual: 0000200177526200
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177527348, Expected: 0000000177527348, Actual: 0000200177527348
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177527F40, Expected: 0000000177527F40, Actual: 0000200177527F40
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177723380, Expected: 0000000177723380, Actual: 0000200177723380
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177723780, Expected: 0000000177723780, Actual: 0000200177723780
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177724B50, Expected: 0000000177724B50, Actual: 0000200177724B50
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177725508, Expected: 0000000177725508, Actual: 0000200177725508
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177726200, Expected: 0000000177726200, Actual: 0000200177726200
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177727050, Expected: 0000000177727050, Actual: 0000200177727050
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177727348, Expected: 0000000177727348, Actual: 0000200177727348
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177727F40, Expected: 0000000177727F40, Actual: 0000200177727F40
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177923380, Expected: 0000000177923380, Actual: 0000200177923380
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177923780, Expected: 0000000177923780, Actual: 0000200177923780
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177925508, Expected: 0000000177925508, Actual: 0000200177925508
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177926200, Expected: 0000000177926200, Actual: 0000200177926200
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177927348, Expected: 0000000177927348, Actual: 0000200177927348
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177927F40, Expected: 0000000177927F40, Actual: 0000200177927F40
2018-05-08 17:26:36 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B23380, Expected: 0000000177B23380, Actual: 0000200177B23380
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B23780, Expected: 0000000177B23780, Actual: 0000200177B23780
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B24B50, Expected: 0000000177B24B50, Actual: 0000200177B24B50
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B25508, Expected: 0000000177B25508, Actual: 0000200177B25508
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B26200, Expected: 0000000177B26200, Actual: 0000200177B26200
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B27348, Expected: 0000000177B27348, Actual: 0000200177B27348
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177B27F40, Expected: 0000000177B27F40, Actual: 0000200177B27F40
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D23380, Expected: 0000000177D23380, Actual: 0000200177D23380
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D23780, Expected: 0000000177D23780, Actual: 0000200177D23780
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D25508, Expected: 0000000177D25508, Actual: 0000200177D25508
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D26200, Expected: 0000000177D26200, Actual: 0000200177D26200
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D27348, Expected: 0000000177D27348, Actual: 0000200177D27348
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177D27F40, Expected: 0000000177D27F40, Actual: 0000200177D27F40
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F23380, Expected: 0000000177F23380, Actual: 0000200177F23380
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F23780, Expected: 0000000177F23780, Actual: 0000200177F23780
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F25508, Expected: 0000000177F25508, Actual: 0000200177F25508
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F26200, Expected: 0000000177F26200, Actual: 0000200177F26200
2018-05-08 17:26:37 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F27348, Expected: 0000000177F27348, Actual: 0000200177F27348
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 177F27F40, Expected: 0000000177F27F40, Actual: 0000200177F27F40
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178523380, Expected: 0000000178523380, Actual: 0000200178523380
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178523780, Expected: 0000000178523780, Actual: 0000200178523780
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178525508, Expected: 0000000178525508, Actual: 0000200178525508
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178526200, Expected: 0000000178526200, Actual: 0000200178526200
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178527348, Expected: 0000000178527348, Actual: 0000200178527348
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178527F40, Expected: 0000000178527F40, Actual: 0000200178527F40
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178723380, Expected: 0000000178723380, Actual: 0000200178723380
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178723780, Expected: 0000000178723780, Actual: 0000200178723780
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178725508, Expected: 0000000178725508, Actual: 0000200178725508
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178726200, Expected: 0000000178726200, Actual: 0000200178726200
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178727348, Expected: 0000000178727348, Actual: 0000200178727348
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178727F40, Expected: 0000000178727F40, Actual: 0000200178727F40
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178923380, Expected: 0000000178923380, Actual: 0000200178923380
2018-05-08 17:26:38 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178923780, Expected: 0000000178923780, Actual: 0000200178923780
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178924400, Expected: 0000000178924400, Actual: 0000200178924400
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178925508, Expected: 0000000178925508, Actual: 0000200178925508
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178926200, Expected: 0000000178926200, Actual: 0000200178926200
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178927348, Expected: 0000000178927348, Actual: 0000200178927348
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178927F40, Expected: 0000000178927F40, Actual: 0000200178927F40
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B23380, Expected: 0000000178B23380, Actual: 0000200178B23380
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B23780, Expected: 0000000178B23780, Actual: 0000200178B23780
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B24400, Expected: 0000000178B24400, Actual: 0000200178B24400
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B25508, Expected: 0000000178B25508, Actual: 0000200178B25508
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B26200, Expected: 0000000178B26200, Actual: 0000200178B26200
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B27348, Expected: 0000000178B27348, Actual: 0000200178B27348
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178B27F40, Expected: 0000000178B27F40, Actual: 0000200178B27F40
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D23380, Expected: 0000000178D23380, Actual: 0000200178D23380
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D23780, Expected: 0000000178D23780, Actual: 0000200178D23780
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D24400, Expected: 0000000178D24400, Actual: 0000200178D24400
2018-05-08 17:26:39 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D24B50, Expected: 0000000178D24B50, Actual: 0000200178D24B50
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D24B58, Expected: 0000000178D24B58, Actual: 0000200178D24B58
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D25508, Expected: 0000000178D25508, Actual: 0000200178D25508
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D26200, Expected: 0000000178D26200, Actual: 0000200178D26200
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D26E40, Expected: 0000000178D26E40, Actual: 0000200178D26E40
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D27348, Expected: 0000000178D27348, Actual: 0000200178D27348
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178D27F40, Expected: 0000000178D27F40, Actual: 0000200178D27F40
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F23380, Expected: 0000000178F23380, Actual: 0000200178F23380
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F23780, Expected: 0000000178F23780, Actual: 0000200178F23780
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F24400, Expected: 0000000178F24400, Actual: 0000200178F24400
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F24B50, Expected: 0000000178F24B50, Actual: 0000200178F24B50
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F24B58, Expected: 0000000178F24B58, Actual: 0000200178F24B58
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F25508, Expected: 0000000178F25508, Actual: 0000200178F25508
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F26200, Expected: 0000000178F26200, Actual: 0000200178F26200
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F27348, Expected: 0000000178F27348, Actual: 0000200178F27348
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 178F27F40, Expected: 0000000178F27F40, Actual: 0000200178F27F40
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179123380, Expected: 0000000179123380, Actual: 0000200179123380
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179123780, Expected: 0000000179123780, Actual: 0000200179123780
2018-05-08 17:26:40 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179124400, Expected: 0000000179124400, Actual: 0000200179124400
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179124B58, Expected: 0000000179124B58, Actual: 0000200179124B58
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179125508, Expected: 0000000179125508, Actual: 0000200179125508
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179126200, Expected: 0000000179126200, Actual: 0000200179126200
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179127348, Expected: 0000000179127348, Actual: 0000200179127348
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179127F40, Expected: 0000000179127F40, Actual: 0000200179127F40
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179323380, Expected: 0000000179323380, Actual: 0000200179323380
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179323780, Expected: 0000000179323780, Actual: 0000200179323780
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179324008, Expected: 0000000179324008, Actual: 0000200179324008
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179324400, Expected: 0000000179324400, Actual: 0000200179324400
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179324B50, Expected: 0000000179324B50, Actual: 0000200179324B50
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179324B58, Expected: 0000000179324B58, Actual: 0000200179324B58
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179325508, Expected: 0000000179325508, Actual: 0000200179325508
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179326200, Expected: 0000000179326200, Actual: 0000200179326200
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179327348, Expected: 0000000179327348, Actual: 0000200179327348
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179327F40, Expected: 0000000179327F40, Actual: 0000200179327F40
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179523380, Expected: 0000000179523380, Actual: 0000200179523380
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179523780, Expected: 0000000179523780, Actual: 0000200179523780
2018-05-08 17:26:41 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179524400, Expected: 0000000179524400, Actual: 0000200179524400
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179524B50, Expected: 0000000179524B50, Actual: 0000200179524B50
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179524B58, Expected: 0000000179524B58, Actual: 0000200179524B58
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179525508, Expected: 0000000179525508, Actual: 0000200179525508
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179526200, Expected: 0000000179526200, Actual: 0000200179526200
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179527348, Expected: 0000000179527348, Actual: 0000200179527348
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179527F40, Expected: 0000000179527F40, Actual: 0000200179527F40
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179723380, Expected: 0000000179723380, Actual: 0000200179723380
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179723780, Expected: 0000000179723780, Actual: 0000200179723780
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179724400, Expected: 0000000179724400, Actual: 0000200179724400
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179724B50, Expected: 0000000179724B50, Actual: 0000200179724B50
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179724B58, Expected: 0000000179724B58, Actual: 0000200179724B58
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179725508, Expected: 0000000179725508, Actual: 0000200179725508
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179726200, Expected: 0000000179726200, Actual: 0000200179726200
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179727348, Expected: 0000000179727348, Actual: 0000200179727348
2018-05-08 17:26:42 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179727F40, Expected: 0000000179727F40, Actual: 0000200179727F40
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179923380, Expected: 0000000179923380, Actual: 0000200179923380
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179923780, Expected: 0000000179923780, Actual: 0000200179923780
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179924008, Expected: 0000000179924008, Actual: 0000200179924008
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179924400, Expected: 0000000179924400, Actual: 0000200179924400
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179924B50, Expected: 0000000179924B50, Actual: 0000200179924B50
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179924B58, Expected: 0000000179924B58, Actual: 0000200179924B58
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179925508, Expected: 0000000179925508, Actual: 0000200179925508
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179926200, Expected: 0000000179926200, Actual: 0000200179926200
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179927348, Expected: 0000000179927348, Actual: 0000200179927348
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179927F40, Expected: 0000000179927F40, Actual: 0000200179927F40
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B23380, Expected: 0000000179B23380, Actual: 0000200179B23380
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B23780, Expected: 0000000179B23780, Actual: 0000200179B23780
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B24008, Expected: 0000000179B24008, Actual: 0000200179B24008
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B24400, Expected: 0000000179B24400, Actual: 0000200179B24400
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B24B50, Expected: 0000000179B24B50, Actual: 0000200179B24B50
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B24B58, Expected: 0000000179B24B58, Actual: 0000200179B24B58
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B25508, Expected: 0000000179B25508, Actual: 0000200179B25508
2018-05-08 17:26:43 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B26200, Expected: 0000000179B26200, Actual: 0000200179B26200
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B26E40, Expected: 0000000179B26E40, Actual: 0000200179B26E40
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B27348, Expected: 0000000179B27348, Actual: 0000200179B27348
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179B27F40, Expected: 0000000179B27F40, Actual: 0000200179B27F40
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D23380, Expected: 0000000179D23380, Actual: 0000200179D23380
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D23780, Expected: 0000000179D23780, Actual: 0000200179D23780
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D24400, Expected: 0000000179D24400, Actual: 0000200179D24400
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D24B50, Expected: 0000000179D24B50, Actual: 0000200179D24B50
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D24B58, Expected: 0000000179D24B58, Actual: 0000200179D24B58
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D25508, Expected: 0000000179D25508, Actual: 0000200179D25508
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D26200, Expected: 0000000179D26200, Actual: 0000200179D26200
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D27348, Expected: 0000000179D27348, Actual: 0000200179D27348
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179D27F40, Expected: 0000000179D27F40, Actual: 0000200179D27F40
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F23380, Expected: 0000000179F23380, Actual: 0000200179F23380
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F23780, Expected: 0000000179F23780, Actual: 0000200179F23780
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F24400, Expected: 0000000179F24400, Actual: 0000200179F24400
2018-05-08 17:26:44 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F24B50, Expected: 0000000179F24B50, Actual: 0000200179F24B50
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F25508, Expected: 0000000179F25508, Actual: 0000200179F25508
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F26200, Expected: 0000000179F26200, Actual: 0000200179F26200
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F27348, Expected: 0000000179F27348, Actual: 0000200179F27348
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 179F27F40, Expected: 0000000179F27F40, Actual: 0000200179F27F40
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A123380, Expected: 000000017A123380, Actual: 000020017A123380
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A123780, Expected: 000000017A123780, Actual: 000020017A123780
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A124400, Expected: 000000017A124400, Actual: 000020017A124400
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A124B50, Expected: 000000017A124B50, Actual: 000020017A124B50
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A124B58, Expected: 000000017A124B58, Actual: 000020017A124B58
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A125508, Expected: 000000017A125508, Actual: 000020017A125508
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A126200, Expected: 000000017A126200, Actual: 000020017A126200
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A127348, Expected: 000000017A127348, Actual: 000020017A127348
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A127F40, Expected: 000000017A127F40, Actual: 000020017A127F40
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A323380, Expected: 000000017A323380, Actual: 000020017A323380
2018-05-08 17:26:45 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A323780, Expected: 000000017A323780, Actual: 000020017A323780
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A324400, Expected: 000000017A324400, Actual: 000020017A324400
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A324B50, Expected: 000000017A324B50, Actual: 000020017A324B50
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A324B58, Expected: 000000017A324B58, Actual: 000020017A324B58
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A325508, Expected: 000000017A325508, Actual: 000020017A325508
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A326200, Expected: 000000017A326200, Actual: 000020017A326200
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A327348, Expected: 000000017A327348, Actual: 000020017A327348
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A327F40, Expected: 000000017A327F40, Actual: 000020017A327F40
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A520BC0, Expected: 000000017A520BC0, Actual: 000020017A520BC0
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A5222C8, Expected: 000000017A5222C8, Actual: 000020017A5222C8
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A523380, Expected: 000000017A523380, Actual: 000020017A523380
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A523780, Expected: 000000017A523780, Actual: 000020017A523780
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A524008, Expected: 000000017A524008, Actual: 000020017A524008
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A524400, Expected: 000000017A524400, Actual: 000020017A524400
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A524B50, Expected: 000000017A524B50, Actual: 000020017A524B50
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A524B58, Expected: 000000017A524B58, Actual: 000020017A524B58
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A525508, Expected: 000000017A525508, Actual: 000020017A525508
2018-05-08 17:26:46 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A526200, Expected: 000000017A526200, Actual: 000020017A526200
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A527348, Expected: 000000017A527348, Actual: 000020017A527348
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A527F40, Expected: 000000017A527F40, Actual: 000020017A527F40
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A720BC0, Expected: 000000017A720BC0, Actual: 000020017A720BC0
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A7222C8, Expected: 000000017A7222C8, Actual: 000020017A7222C8
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A7229D8, Expected: 000000017A7229D8, Actual: 000020017A7229D8
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A723380, Expected: 000000017A723380, Actual: 000020017A723380
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A723780, Expected: 000000017A723780, Actual: 000020017A723780
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A724008, Expected: 000000017A724008, Actual: 000020017A724008
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A724400, Expected: 000000017A724400, Actual: 000020017A724400
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A724B50, Expected: 000000017A724B50, Actual: 000020017A724B50
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A724B58, Expected: 000000017A724B58, Actual: 000020017A724B58
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A725508, Expected: 000000017A725508, Actual: 000020017A725508
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A726200, Expected: 000000017A726200, Actual: 000020017A726200
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A727300, Expected: 000000017A727300, Actual: 000020017A727300
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A727348, Expected: 000000017A727348, Actual: 000020017A727348
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A727F40, Expected: 000000017A727F40, Actual: 000020017A727F40
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A920BC0, Expected: 000000017A920BC0, Actual: 000020017A920BC0
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A923380, Expected: 000000017A923380, Actual: 000020017A923380
2018-05-08 17:26:47 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A923780, Expected: 000000017A923780, Actual: 000020017A923780
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A924400, Expected: 000000017A924400, Actual: 000020017A924400
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A924B58, Expected: 000000017A924B58, Actual: 000020017A924B58
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A925508, Expected: 000000017A925508, Actual: 000020017A925508
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A926200, Expected: 000000017A926200, Actual: 000020017A926200
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A927300, Expected: 000000017A927300, Actual: 000020017A927300
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A927348, Expected: 000000017A927348, Actual: 000020017A927348
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17A927F40, Expected: 000000017A927F40, Actual: 000020017A927F40
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB23380, Expected: 000000017AB23380, Actual: 000020017AB23380
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB23780, Expected: 000000017AB23780, Actual: 000020017AB23780
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB24400, Expected: 000000017AB24400, Actual: 000020017AB24400
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB25508, Expected: 000000017AB25508, Actual: 000020017AB25508
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB26200, Expected: 000000017AB26200, Actual: 000020017AB26200
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB27300, Expected: 000000017AB27300, Actual: 000020017AB27300
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB27348, Expected: 000000017AB27348, Actual: 000020017AB27348
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AB27F40, Expected: 000000017AB27F40, Actual: 000020017AB27F40
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD20BC0, Expected: 000000017AD20BC0, Actual: 000020017AD20BC0
2018-05-08 17:26:48 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD23380, Expected: 000000017AD23380, Actual: 000020017AD23380
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD23780, Expected: 000000017AD23780, Actual: 000020017AD23780
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD24400, Expected: 000000017AD24400, Actual: 000020017AD24400
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD24B50, Expected: 000000017AD24B50, Actual: 000020017AD24B50
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD24B58, Expected: 000000017AD24B58, Actual: 000020017AD24B58
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD25508, Expected: 000000017AD25508, Actual: 000020017AD25508
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD26200, Expected: 000000017AD26200, Actual: 000020017AD26200
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD27300, Expected: 000000017AD27300, Actual: 000020017AD27300
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD27348, Expected: 000000017AD27348, Actual: 000020017AD27348
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AD27F40, Expected: 000000017AD27F40, Actual: 000020017AD27F40
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF23380, Expected: 000000017AF23380, Actual: 000020017AF23380
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF23780, Expected: 000000017AF23780, Actual: 000020017AF23780
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF24400, Expected: 000000017AF24400, Actual: 000020017AF24400
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF25508, Expected: 000000017AF25508, Actual: 000020017AF25508
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF26200, Expected: 000000017AF26200, Actual: 000020017AF26200
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF27348, Expected: 000000017AF27348, Actual: 000020017AF27348
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17AF27F40, Expected: 000000017AF27F40, Actual: 000020017AF27F40
2018-05-08 17:26:49 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B120B90, Expected: 000000017B120B90, Actual: 000020017B120B90
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B123380, Expected: 000000017B123380, Actual: 000020017B123380
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B123780, Expected: 000000017B123780, Actual: 000020017B123780
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B124400, Expected: 000000017B124400, Actual: 000020017B124400
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B124B50, Expected: 000000017B124B50, Actual: 000020017B124B50
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B124B58, Expected: 000000017B124B58, Actual: 000020017B124B58
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B125508, Expected: 000000017B125508, Actual: 000020017B125508
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B126200, Expected: 000000017B126200, Actual: 000020017B126200
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B127348, Expected: 000000017B127348, Actual: 000020017B127348
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B127F40, Expected: 000000017B127F40, Actual: 000020017B127F40
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B320B90, Expected: 000000017B320B90, Actual: 000020017B320B90
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B320BC0, Expected: 000000017B320BC0, Actual: 000020017B320BC0
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B3222C8, Expected: 000000017B3222C8, Actual: 000020017B3222C8
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B323380, Expected: 000000017B323380, Actual: 000020017B323380
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B323780, Expected: 000000017B323780, Actual: 000020017B323780
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B324008, Expected: 000000017B324008, Actual: 000020017B324008
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B324400, Expected: 000000017B324400, Actual: 000020017B324400
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B324B50, Expected: 000000017B324B50, Actual: 000020017B324B50
2018-05-08 17:26:50 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B324B58, Expected: 000000017B324B58, Actual: 000020017B324B58
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B325508, Expected: 000000017B325508, Actual: 000020017B325508
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B326200, Expected: 000000017B326200, Actual: 000020017B326200
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B327348, Expected: 000000017B327348, Actual: 000020017B327348
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B327F40, Expected: 000000017B327F40, Actual: 000020017B327F40
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B520BC0, Expected: 000000017B520BC0, Actual: 000020017B520BC0
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B5222C8, Expected: 000000017B5222C8, Actual: 000020017B5222C8
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B523380, Expected: 000000017B523380, Actual: 000020017B523380
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B523780, Expected: 000000017B523780, Actual: 000020017B523780
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B524008, Expected: 000000017B524008, Actual: 000020017B524008
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B524400, Expected: 000000017B524400, Actual: 000020017B524400
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B524B50, Expected: 000000017B524B50, Actual: 000020017B524B50
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B524B58, Expected: 000000017B524B58, Actual: 000020017B524B58
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B525508, Expected: 000000017B525508, Actual: 000020017B525508
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B526200, Expected: 000000017B526200, Actual: 000020017B526200
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B527348, Expected: 000000017B527348, Actual: 000020017B527348
2018-05-08 17:26:51 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B527F40, Expected: 000000017B527F40, Actual: 000020017B527F40
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B720BC0, Expected: 000000017B720BC0, Actual: 000020017B720BC0
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B7222C8, Expected: 000000017B7222C8, Actual: 000020017B7222C8
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B723380, Expected: 000000017B723380, Actual: 000020017B723380
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B723780, Expected: 000000017B723780, Actual: 000020017B723780
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B724008, Expected: 000000017B724008, Actual: 000020017B724008
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B724400, Expected: 000000017B724400, Actual: 000020017B724400
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B724B50, Expected: 000000017B724B50, Actual: 000020017B724B50
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B724B58, Expected: 000000017B724B58, Actual: 000020017B724B58
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B725508, Expected: 000000017B725508, Actual: 000020017B725508
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B726200, Expected: 000000017B726200, Actual: 000020017B726200
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B727348, Expected: 000000017B727348, Actual: 000020017B727348
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B727F40, Expected: 000000017B727F40, Actual: 000020017B727F40
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B923380, Expected: 000000017B923380, Actual: 000020017B923380
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B923780, Expected: 000000017B923780, Actual: 000020017B923780
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B924400, Expected: 000000017B924400, Actual: 000020017B924400
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B924B50, Expected: 000000017B924B50, Actual: 000020017B924B50
2018-05-08 17:26:52 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B924B58, Expected: 000000017B924B58, Actual: 000020017B924B58
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B925508, Expected: 000000017B925508, Actual: 000020017B925508
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B926200, Expected: 000000017B926200, Actual: 000020017B926200
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B927348, Expected: 000000017B927348, Actual: 000020017B927348
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17B927F40, Expected: 000000017B927F40, Actual: 000020017B927F40
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB23380, Expected: 000000017BB23380, Actual: 000020017BB23380
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB23780, Expected: 000000017BB23780, Actual: 000020017BB23780
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB24008, Expected: 000000017BB24008, Actual: 000020017BB24008
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB24400, Expected: 000000017BB24400, Actual: 000020017BB24400
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB24B50, Expected: 000000017BB24B50, Actual: 000020017BB24B50
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB24B58, Expected: 000000017BB24B58, Actual: 000020017BB24B58
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB25508, Expected: 000000017BB25508, Actual: 000020017BB25508
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB26200, Expected: 000000017BB26200, Actual: 000020017BB26200
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB27348, Expected: 000000017BB27348, Actual: 000020017BB27348
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BB27F40, Expected: 000000017BB27F40, Actual: 000020017BB27F40
2018-05-08 17:26:53 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD23380, Expected: 000000017BD23380, Actual: 000020017BD23380
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD23780, Expected: 000000017BD23780, Actual: 000020017BD23780
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD24400, Expected: 000000017BD24400, Actual: 000020017BD24400
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD24B50, Expected: 000000017BD24B50, Actual: 000020017BD24B50
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD25508, Expected: 000000017BD25508, Actual: 000020017BD25508
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD26200, Expected: 000000017BD26200, Actual: 000020017BD26200
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD27348, Expected: 000000017BD27348, Actual: 000020017BD27348
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BD27F40, Expected: 000000017BD27F40, Actual: 000020017BD27F40
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF20B88, Expected: 000000017BF20B88, Actual: 000020017BF20B88
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF20B90, Expected: 000000017BF20B90, Actual: 000020017BF20B90
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF20BC0, Expected: 000000017BF20BC0, Actual: 000020017BF20BC0
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF215D8, Expected: 000000017BF215D8, Actual: 000020017BF215D8
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF21AC8, Expected: 000000017BF21AC8, Actual: 000020017BF21AC8
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF222C0, Expected: 000000017BF222C0, Actual: 000020017BF222C0
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF222C8, Expected: 000000017BF222C8, Actual: 000020017BF222C8
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF229D8, Expected: 000000017BF229D8, Actual: 000020017BF229D8
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF23380, Expected: 000000017BF23380, Actual: 000020017BF23380
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF23780, Expected: 000000017BF23780, Actual: 000020017BF23780
2018-05-08 17:26:54 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF23FC8, Expected: 000000017BF23FC8, Actual: 000020017BF23FC8
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF24008, Expected: 000000017BF24008, Actual: 000020017BF24008
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF24400, Expected: 000000017BF24400, Actual: 000020017BF24400
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF24B50, Expected: 000000017BF24B50, Actual: 000020017BF24B50
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF24B58, Expected: 000000017BF24B58, Actual: 000020017BF24B58
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF24F40, Expected: 000000017BF24F40, Actual: 000020017BF24F40
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF25508, Expected: 000000017BF25508, Actual: 000020017BF25508
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26148, Expected: 000000017BF26148, Actual: 000020017BF26148
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26158, Expected: 000000017BF26158, Actual: 000020017BF26158
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26200, Expected: 000000017BF26200, Actual: 000020017BF26200
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26940, Expected: 000000017BF26940, Actual: 000020017BF26940
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26A10, Expected: 000000017BF26A10, Actual: 000020017BF26A10
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF26E40, Expected: 000000017BF26E40, Actual: 000020017BF26E40
2018-05-08 17:26:55 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF27050, Expected: 000000017BF27050, Actual: 000020017BF27050
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF27348, Expected: 000000017BF27348, Actual: 000020017BF27348
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF27840, Expected: 000000017BF27840, Actual: 000020017BF27840
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF27F18, Expected: 000000017BF27F18, Actual: 000020017BF27F18
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17BF27F40, Expected: 000000017BF27F40, Actual: 000020017BF27F40
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E5215D8, Expected: 000000017E5215D8, Actual: 000020017E5215D8
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E521AC8, Expected: 000000017E521AC8, Actual: 000020017E521AC8
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E523380, Expected: 000000017E523380, Actual: 000020017E523380
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E523780, Expected: 000000017E523780, Actual: 000020017E523780
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E524400, Expected: 000000017E524400, Actual: 000020017E524400
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E524B50, Expected: 000000017E524B50, Actual: 000020017E524B50
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E525508, Expected: 000000017E525508, Actual: 000020017E525508
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E526200, Expected: 000000017E526200, Actual: 000020017E526200
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E527300, Expected: 000000017E527300, Actual: 000020017E527300
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E527348, Expected: 000000017E527348, Actual: 000020017E527348
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E527F40, Expected: 000000017E527F40, Actual: 000020017E527F40
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E723380, Expected: 000000017E723380, Actual: 000020017E723380
2018-05-08 17:26:56 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E723780, Expected: 000000017E723780, Actual: 000020017E723780
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E724400, Expected: 000000017E724400, Actual: 000020017E724400
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E725508, Expected: 000000017E725508, Actual: 000020017E725508
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E726200, Expected: 000000017E726200, Actual: 000020017E726200
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E727348, Expected: 000000017E727348, Actual: 000020017E727348
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E727F40, Expected: 000000017E727F40, Actual: 000020017E727F40
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E920B88, Expected: 000000017E920B88, Actual: 000020017E920B88
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E920BC0, Expected: 000000017E920BC0, Actual: 000020017E920BC0
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E9215D8, Expected: 000000017E9215D8, Actual: 000020017E9215D8
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E921AC8, Expected: 000000017E921AC8, Actual: 000020017E921AC8
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E9222C0, Expected: 000000017E9222C0, Actual: 000020017E9222C0
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E9222C8, Expected: 000000017E9222C8, Actual: 000020017E9222C8
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E9229D8, Expected: 000000017E9229D8, Actual: 000020017E9229D8
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E923380, Expected: 000000017E923380, Actual: 000020017E923380
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E923780, Expected: 000000017E923780, Actual: 000020017E923780
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E924008, Expected: 000000017E924008, Actual: 000020017E924008
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E924400, Expected: 000000017E924400, Actual: 000020017E924400
2018-05-08 17:26:57 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E924B50, Expected: 000000017E924B50, Actual: 000020017E924B50
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E924B58, Expected: 000000017E924B58, Actual: 000020017E924B58
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E924F40, Expected: 000000017E924F40, Actual: 000020017E924F40
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E925508, Expected: 000000017E925508, Actual: 000020017E925508
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E925A00, Expected: 000000017E925A00, Actual: 000020017E925A00
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E925A08, Expected: 000000017E925A08, Actual: 000020017E925A08
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926148, Expected: 000000017E926148, Actual: 000020017E926148
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926158, Expected: 000000017E926158, Actual: 000020017E926158
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926200, Expected: 000000017E926200, Actual: 000020017E926200
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926208, Expected: 000000017E926208, Actual: 000020017E926208
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926940, Expected: 000000017E926940, Actual: 000020017E926940
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926950, Expected: 000000017E926950, Actual: 000020017E926950
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926A10, Expected: 000000017E926A10, Actual: 000020017E926A10
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926A48, Expected: 000000017E926A48, Actual: 000020017E926A48
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E926E40, Expected: 000000017E926E40, Actual: 000020017E926E40
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927050, Expected: 000000017E927050, Actual: 000020017E927050
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927300, Expected: 000000017E927300, Actual: 000020017E927300
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927348, Expected: 000000017E927348, Actual: 000020017E927348
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927358, Expected: 000000017E927358, Actual: 000020017E927358
2018-05-08 17:26:58 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927808, Expected: 000000017E927808, Actual: 000020017E927808
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927840, Expected: 000000017E927840, Actual: 000020017E927840
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927848, Expected: 000000017E927848, Actual: 000020017E927848
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927850, Expected: 000000017E927850, Actual: 000020017E927850
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17E927F40, Expected: 000000017E927F40, Actual: 000020017E927F40
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB23380, Expected: 000000017EB23380, Actual: 000020017EB23380
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB23780, Expected: 000000017EB23780, Actual: 000020017EB23780
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB24400, Expected: 000000017EB24400, Actual: 000020017EB24400
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB25508, Expected: 000000017EB25508, Actual: 000020017EB25508
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB26200, Expected: 000000017EB26200, Actual: 000020017EB26200
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB27348, Expected: 000000017EB27348, Actual: 000020017EB27348
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EB27F40, Expected: 000000017EB27F40, Actual: 000020017EB27F40
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED23380, Expected: 000000017ED23380, Actual: 000020017ED23380
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED23780, Expected: 000000017ED23780, Actual: 000020017ED23780
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED24400, Expected: 000000017ED24400, Actual: 000020017ED24400
2018-05-08 17:26:59 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED24B50, Expected: 000000017ED24B50, Actual: 000020017ED24B50
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED25508, Expected: 000000017ED25508, Actual: 000020017ED25508
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED26200, Expected: 000000017ED26200, Actual: 000020017ED26200
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED27348, Expected: 000000017ED27348, Actual: 000020017ED27348
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17ED27F40, Expected: 000000017ED27F40, Actual: 000020017ED27F40
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF23380, Expected: 000000017EF23380, Actual: 000020017EF23380
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF23780, Expected: 000000017EF23780, Actual: 000020017EF23780
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF24008, Expected: 000000017EF24008, Actual: 000020017EF24008
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF24400, Expected: 000000017EF24400, Actual: 000020017EF24400
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF24B50, Expected: 000000017EF24B50, Actual: 000020017EF24B50
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF25508, Expected: 000000017EF25508, Actual: 000020017EF25508
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF26200, Expected: 000000017EF26200, Actual: 000020017EF26200
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF27348, Expected: 000000017EF27348, Actual: 000020017EF27348
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17EF27F40, Expected: 000000017EF27F40, Actual: 000020017EF27F40
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F123380, Expected: 000000017F123380, Actual: 000020017F123380
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F123780, Expected: 000000017F123780, Actual: 000020017F123780
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F124400, Expected: 000000017F124400, Actual: 000020017F124400
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F124B50, Expected: 000000017F124B50, Actual: 000020017F124B50
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F125508, Expected: 000000017F125508, Actual: 000020017F125508
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F126200, Expected: 000000017F126200, Actual: 000020017F126200
2018-05-08 17:27:00 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F127348, Expected: 000000017F127348, Actual: 000020017F127348
2018-05-08 17:27:01 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F127F40, Expected: 000000017F127F40, Actual: 000020017F127F40
2018-05-08 17:27:01 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F323380, Expected: 000000017F323380, Actual: 000020017F323380
2018-05-08 17:27:01 - [MEM ERROR - Data] Test: 1, CPU: 0, Address: 17F323780, Expected: 000000017F323780, Actual: 000020017F323780
2018-05-08 17:27:01 - [MEM ERROR] Truncating due to too many errors
2018-05-08 17:27:03 - Cleanup - Releasing all memory ranges...
2018-05-08 17:27:03 - MtSupportRunAllTests - Test execution time: 32.133 (Test 1 cumulative error count: 533)
2018-05-08 17:27:03 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88350800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:27:03 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 17:27:03 - Running test #2 (Test 2 [Address test, own address])
2018-05-08 17:27:03 - MtSupportRunAllTests - Setting random seed to 0x50415353
2018-05-08 17:27:03 - MtSupportRunAllTests - Start time: 34283 ms
2018-05-08 17:27:03 - ReadMemoryRanges - Available Pages = 4088658
2018-05-08 17:27:03 - MtSupportRunAllTests - Enabling memory cache for test
2018-05-08 17:27:03 - MtSupportRunAllTests - Enabling memory cache complete
2018-05-08 17:27:03 - Start memory range test (0x0 - 0x476C00000)
2018-05-08 17:27:03 - Pre-allocating memory ranges >=16MB first...
2018-05-08 17:27:03 - All memory ranges successfully locked
2018-05-08 17:27:06 - Cleanup - Releasing all memory ranges...
2018-05-08 17:27:06 - MtSupportRunAllTests - Test execution time: 2.837 (Test 2 cumulative error count: 141)
2018-05-08 17:27:06 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88340800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 17:27:06 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 17:27:06 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
2018-05-08 17:27:06 - MtSupportRunAllTests - Setting random seed to 0x50415353
2018-05-08 17:27:06 - MtSupportRunAllTests - Start time: 37582 ms
2018-05-08 17:27:07 - ReadMemoryRanges - Available Pages = 4088658
2018-05-08 17:27:07 - MtSupportRunAllTests - Enabling memory cache for test
2018-05-08 17:27:07 - MtSupportRunAllTests - Enabling memory cache complete
2018-05-08 17:27:07 - Start memory range test (0x0 - 0x476C00000)
2018-05-08 17:27:07 - Pre-allocating memory ranges >=16MB first...
2018-05-08 17:27:07 - All memory ranges successfully locked
2018-05-08 17:27:20 - Cleanup - Releasing all memory ranges...
2018-05-08 17:27:20 - MtSupportRunAllTests - Test execution time: 13.561 (Test 3 cumulative error count: 9867)
2018-05-08 17:27:20 - Number of errors exceed maximum error count of 10000
2018-05-08 20:38:42 - Screen resolution is too high (3840 x 2160). Setting screen size to the minimum 1024 x 768
2018-05-08 20:38:42 - New screen size = 1024 x 768
2018-05-08 20:38:42 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88310800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 20:38:42 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 20:39:18 - GetIA32ArchitecturalTemp - MSR(0x19C) = 88320800 (Vendor ID: GenuineIntel 6 5E 3)
2018-05-08 20:39:18 - MapTempIntel - MSR(0x1A2) = 641400
2018-05-08 20:39:57 - Attempting to retrieve the root directory of the data partition.
2018-05-08 20:39:57 - Found 5 handles that supported SimpleFileSystem
2018-05-08 20:39:57 - Checking handle 0 (7AC8CB18)
2018-05-08 20:39:57 - Handle is own partition
2018-05-08 20:39:57 - Checking handle 1 (7AC8CA58)
2018-05-08 20:39:57 - HD node found: MBR type(2), Signature type(2), Part #(2), Start LBA(104448), Num Sectors(202719)
2018-05-08 20:39:57 - Self node: MBR type(2), Signature type(2), Part #(1), Start LBA(2048), Num Sectors(100353)
Modbreak:Wat een - onnodige - lap text :o
Ik heb voor nu alles in een quote gezet zodat het alleen getoond wordt als je erop klikt. Daarmee wordt het topic weer normaal leesbaar. Verzoek om voortaan - en nu alsnog voor deze lap - zelf de moeite nemen om kaf van koren te scheiden en die delen van de log te plaatsen die relevant zijn. Hier heb je meer regels over language support van meitest en exceptions voor specifieke moederborden (die jij niet hebt) dan daadwerkelijke error messages, en alle error messages zijn van identieke aard. Kortom een enkele regel had volstaan. De rest leidt alleen maar af. Een beetje inzet om de boel te redigeren mag niet teveel gevraagd zijn.
Je kunt altijd nog de volledige log achter een link of zoals ik hier doe in een quote toevoegen voor de volledigheid.
[ Voor 0% gewijzigd door dion_b op 09-05-2018 00:44 ]
  • M2M
  • Laatst online: 26-10 17:42
M2M
medicijnman
Lijkt me wel... Number of errors exceed maximum error count of 10000...Je bent niet toevallig je geheugen aan het overklokken? "auto" settings van sommige moederbord fabrikanten gooien soms te veel voltage richting het geheugen, met soms ook te veel snelheid. Check dat even voordat je de reepjes terugstuurt.
-_-
  • WingGraph
  • Laatst online: 21-10-2023
@M2M Normaal, overklok ik niet, maar had alles, voor de zekerheid, terug op default settings gezet voor ik de test heb gelopen
  • M2M
M2M
medicijnman
In dat geval lijkt het inderdaad op defect geheugen. Het kan echter ook een defecte memory controller zijn. Als je dat zeker wil weten, test je de reepjes los. De kans dat ze allemaal stuk zijn is nihil, indien de test dat wel aangeeft, hebben nieuwe reepjes ook geen zin en zit de fout in moederbord / processor.
-_-
  • nelizmastr
  • Laatst online: 26-10 21:40
nelizmastr
Goed wies kapot
Godsammekrake wat een post, volgende keer ff in een spoiler oid verstoppen :+
Maar idd de stickies afzonderlijk testen. Als de hele kit dood lijkt ook even de sticks bij iemand anders testen of die van een ander bij jou. Dan weet je zeker of het bord of de CPU de dader is i.p.v geheugen.
  • WingGraph
@M2M @nelizmastr
ik heb maar 2 modules en bij het testen van de eerste modules kwam er terug de ene error na de andere.
op dit moment is de 2de lat aan het lopen, in hetzelfde slot als de eerste lat en daar heb ik tot nu toe nog geen errors.
Dus ik ga vrijdag terug naar de winkel om deze te laten wisselen.
Andere gelateerde vraag:
Ik heb een moederbord met 4 memory slots.
Wat is volgens jullie de betere optie van de 2?
2 latten van 8gb
of
4 latten van 2gb
[ Voor 3% gewijzigd door WingGraph op 08-05-2018 22:16 ]
  • heuveltje
  • Laatst online: 11:49
heuveltje
KoelkastFilosoof
De een is 16gb, de ander 8 ?
Maar minder latjes geeft je later nog uitbreidingsmogelijkheden, en voor snelheid maakt het niks uit.
Heuveltjes CPU geschiedenis door de jaren heen : AMD 486dx4 100, Cyrix PR166+, Intel P233MMX, Intel Celeron 366Mhz, AMD K6-450, AMD duron 600, AMD Thunderbird 1200mhz, AMD Athlon 64 x2 5600, AMD Phenom X3 720, Intel i5 4460, AMD Ryzen 5 3600 5800x3d
  • WingGraph
@heuveltje sry, heb mij vergist het moest 4 latten van 4gb zijn :)
  • TommyboyNL
Maakt niet uit. Beiden zullen in dual-channel gaan draaien. Ik zou dus voor 2x8 gaan, zodat je altijd kan upgraden naar 4x8 mocht dat ooit nodig zijn.
  • M2M
M2M
medicijnman
En 4x8 geeft iets meer load op de memory controller, maar dat is enkel interessant als je gaat overklokken. En als het een intel processor betreft zonder interne GPU (die gebruikt wordt teminste), dan heeft een hogere memory snelheid nauwelijks effect.
-_-
