Xfree86 4.10 configure werkt nie, maar
  • 212 views sinds 30-01-2008
Ik heb gister XFree86 4.1.0 Geinstalleerd met het sh script. Maar als ik daarna Xfree86 -configure doe dan krijg ik het volgende:
XFree86 Version 4.1.0 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 2 June 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.5 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Sun Jul 15 14:20:56 2001
(--) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0305 card 0000,0000 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0686 card 1106,0000 rev 22 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:07:4: chip 1106,3057 card 0000,0000 rev 30 class 06,80,00 hdr 00
(II) PCI: 00:0e:0: chip 5333,8811 card 0000,0000 rev 54 class 03,00,00 hdr 00
(II) PCI: 00:0f:0: chip 9004,5078 card 9004,7850 rev 03 class 01,00,00 hdr 00
(II) PCI: 00:10:0: chip 1113,1211 card 1113,9211 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:11:0: chip 1102,0002 card 1102,8040 rev 07 class 04,01,00 hdr 80
(II) PCI: 00:11:1: chip 1102,7002 card 1102,0020 rev 07 class 09,80,00 hdr 80
(II) PCI: 00:12:0: chip 109e,036e card bd11,1200 rev 11 class 04,00,00 hdr 80
(II) PCI: 00:12:1: chip 109e,0878 card bd11,1200 rev 11 class 04,80,00 hdr 80
(II) PCI: 01:00:0: chip 121a,0009 card 121a,0002 rev 01 class 03,00,00 hdr 00
(II) PCI: 01:00:1: chip 121a,0009 card 121a,0002 rev 01 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0xe0000000 - 0xe7ffffff (0x8000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0xd8000000 - 0xdfffffff (0x8000000) MX[B]
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI: (0:14:0) S3 Trio32/64 rev 84, Mem @ 0xe8000000/26
(--) PCI: (0:18:0) BrookTree unknown chipset (0x036e) rev 17, Mem @ 0xed002000/12
(--) PCI:*(1:0:0) 3dfx Interactive Voodoo5 rev 1, Mem @ 0xe0000000/26, 0xd8000000/27, I/O @ 0xc000/8
(--) PCI: (1:0:1) 3dfx Interactive Voodoo5 rev 1, I/O @ 0xfffffe00/8
List of video drivers:
tdfx
glide
v4l
(II) LoadModule: "tdfx"
(II) Loading /usr/X11R6/lib/modules/drivers/tdfx_drv.o
(II) Module tdfx: vendor="The XFree86 Project"
Module class: XFree86 Video Driver
(II) LoadModule: "glide"
(II) Loading /usr/X11R6/lib/modules/drivers/glide_drv.o
(II) Module glide: vendor="The XFree86 Project"
(II) LoadModule: "v4l"
(II) Loading /usr/X11R6/lib/modules/drivers/linux/v4l_drv.o
(II) Module v4l: vendor="The XFree86 Project"
compiled for 4.1.0, module version = 0.0.1
(II) Addressable bus resource ranges are
[1] -1 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0xed003000 - 0xed003fff (0x1000) MX[B]
[1] -1 0xed001000 - 0xed0010ff (0x100) MX[B]
[2] -1 0xed000000 - 0xed000fff (0x1000) MX[B]
[3] -1 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
[4] -1 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
[5] -1 0xe0000000 - 0xe3ffffff (0x4000000) MX[B](B)
[6] -1 0xed002000 - 0xed002fff (0x1000) MX[B](B)
[7] -1 0x0000e800 - 0x0000e807 (0x8) IX[B]
[8] -1 0x0000e400 - 0x0000e41f (0x20) IX[B]
[9] -1 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[10] -1 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[11] -1 0x0000d800 - 0x0000d81f (0x20) IX[B]
[12] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
[13] -1 0x0000d000 - 0x0000d00f (0x10) IX[B]
[14] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B](B)
(II) Inactive PCI resource ranges:
[0] -1 0xe8000000 - 0xebffffff (0x4000000) MX[B](B)
[1] -1 0xfffffe00 - 0xfffffeff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0xed003000 - 0xed003fff (0x1000) MX[B]
[6] -1 0xed001000 - 0xed0010ff (0x100) MX[B]
[7] -1 0xed000000 - 0xed000fff (0x1000) MX[B]
[8] -1 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
[9] -1 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
[10] -1 0xe0000000 - 0xe3ffffff (0x4000000) MX[B](B)
[11] -1 0xed002000 - 0xed002fff (0x1000) MX[B](B)
[12] -1 0xe8000000 - 0xebffffff (0x4000000) MX[B](B)
[13] -1 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0x0000e800 - 0x0000e807 (0x8) IX[B]
[16] -1 0x0000e400 - 0x0000e41f (0x20) IX[B]
[17] -1 0x0000e000 - 0x0000e0ff (0x100) IX[B]
[18] -1 0x0000dc00 - 0x0000dcff (0x100) IX[B]
[19] -1 0x0000d800 - 0x0000d81f (0x20) IX[B]
[20] -1 0x0000d400 - 0x0000d41f (0x20) IX[B]
[21] -1 0x0000d000 - 0x0000d00f (0x10) IX[B]
[22] -1 0x0000c000 - 0x0000c0ff (0x100) IX[B](B)
[23] -1 0xfffffe00 - 0xfffffeff (0x100) IX[B](B)
(II) Primary Device is: PCI 01:00:0
(II) TDFX: Driver for 3dfx Banshee/Voodoo3 chipsets: 3dfx Banshee,
3dfx Voodoo3, 3dfx Voodoo5
Symbol DRIMoveBuffersHelper from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol vgaHWGetIndex from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol vgaHWUnmapMem from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol xf86SetDDCproperties from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol xf86PrintEDID from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol vbeFree from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol xf86FreeInt10 from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol xf86InitInt10 from module /usr/X11R6/lib/modules/drivers/tdfx_drv.o is unresolved!
Symbol ShadowFBInit from module /usr/X11R6/lib/modules/drivers/glide_drv.o is unresolved!
Fatal server error:
Caught signal 11. Server aborting
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to xfree86@xfree86.org.
Kde en Gnome werken ook niet, als ik startx doe krijg ik alleen safe modues..
Weet er iemand een oplossing, of heeft iemand hetzelfde probleem. Het gaat om de volgende hardware:
Chaintech 7aja (sA kt133+686a), Duron 600@900, Voodoo 5 5500 AGP, Sblive1024, Adaptec 2904 scsi, Accton 1027D Nic, Pinnacle Studio PCTV.
Ik quote mezelf even :P
Op zondag 18 februari 2001 23:42 schreef nelske het volgende:
[knip]
Signal 9 (/tm 11) wordt in de meeste gevallen door hardware veroorzaakt. Liever gezegd wordt het vaak veroorzaakt door defecte hardware :(
Controleer in eerste instantie je geheugen.
Grote veroorzaker van deze fout is slecht geheugen of het mixen van geheugen met verschillende timings (waarbij de BIOS-instellingen niet goed aangepast zijn)
Mocht dit het probleem niet zijn probeer dan eerst de systeem-cache uit te zetten en opnieuw proberen. Nog steeds geen geluk?
Zet dan nu ook de interne-cache uit en probeer opnieuw.
Als het nu nog steeds niet werkt ga dan alle onnodige kaarten uit je computer halen en probeer het opnieuw.
Controleer ook iig de moederbord instellingen en zorg ervoor dat de processor goed gekoeld wordt.
  • deadinspace
  • Laatst online: 10:14
deadinspace
The what goes where now?
Signal 9 is SIGKILL, of deze door brakke hw veroorzaakt kan worden weet ik niet.
Signal 10 is SIGUSR1 - lijkt me sterk dat je die krijgt vanwege brakke hw.
Signal 11 is SIGSEGV, dat houdt in dat het desbetreffende programma een ongeldig stuk geheugen of een stuk geheugen waar het niet aan mag zitten probeert te accessen.
SIGSEGV kan idd door brakke hw (met name brak ram) veroorzaakt worden, maar SEGVs worden ook (niet zelden) veroorzaakt door fouten in het programma zelf. Ik had ook eens dat mijn XFree SEGVde vanwege foute instellingen (ivm dual head).
  • deadinspace
deadinspace
Deze regels geven overigens het probleem aan:
Hij kan referenties vanuit je tdfx_drv.o (en 1 keer je glide_drv.o) niet vinden.
Waar heb je je zelfgecompilede XFree neergezet? Op dezelfde plaats als de oude? Heb je drivers van 3dfx gedownload en erbij gezet of niet?
Op zondag 15 juli 2001 21:39 schreef deadinspace het volgende:
Sig9 kan zeer zeker door kapotte hardware veroorzaakt worden. Zelfs heel veel voorkomend.
Evenals sig11; die foute instellingen van je in XFree86 hadden vast ook met verkeerde geheugenallocatie te maken?!
Er had inderdaad signal 9 en 11 moeten staan en niet "t/m". Het was een quote van mezelf, waarin ik alleen sig9 had staan en diezelfde quote kan dus ook van toepassing zijn op sig11 ;)
  • deadinspace
deadinspace
Op zondag 15 juli 2001 22:28 schreef nelske het volgende:
ah
Mnee... ik herinner het me nu weer. Volgensmij probeerde ik toen dual head aan de gang te krijgen met de stndaard XFree 4.1.0 module mga_drv.o en de binary-only mga_hal_drv.o van matrox, en dat werkte niet bijzonder goed.
Maar SEGVs zijn iig lang niet altijd wegens brak mem. Ik heb LILO bijvoorbeeld eens laten SEGVen door hem een DOS/WIN style config file te voeren.
Als ik het goed heb was voodoo support gebroken in XFree 4.1.0.
Of was het alleen 3D support hiervoor?
Ik kan me vergissen...
ik heb gewoon de benodigde bestanden gedownload en toen sh Xinstall gedaan. Ik had al xfree 3.3x van Redhat 6.2. Ik heb verders geen drivers gedownload. Het lijkt me stug dat er hardware brak is, het werkt allemaal wel goed, geheugen in van Compaq (siemens) pc100 Cas2
De kans lijkt me dan groot dat er nog bestanden staan van XFree 3.3, waar XFree 4 mee overhoop ligt.
Jew zou kunnen proberen eerst de 3.3 rpm's te verwijderen, en dan Xinstall opnieuw te draaien.
