Best online shop to configure and by a PC?
  • 274 views
  • PeterNik
  • Laatst online: 19-11-2025
Dear All,
Could you please recommend me an online computer store with a wide choice of components and handy PC-builder option?
Another important parameters:
- Very good reputation and long time in this business;
- Reasonable prices;
- Optionally: pick-up and return location (in case of a warranty issues) is not too far away from Eindhoven.
What I plan to buy and why?
The use case:
I use Photoshop CS5 to edit heavy photos, I also do some video editing and sometimes I play 3D games - space simulators like Star Conflict or Elite Dangerous.
I have 2 screens connected to the PC: with the 2560*1440 and 1680*1050 resolution.
I plan to buy a new desktop with the following guidelines:
- I plan to use its major components for at least 5 years (my current i7-920 works since 2010) with possibility of the RAM/video card upgrade;
- Good PC case, reliable motherboard with wide range of options and fast CDU like Intel i7-8700k;
- Video card: AMD RX 570 (it is enough now and it could be upgraded later if needed);
- RAM: 16Gb (will be upgraded later when needed).
My budget is around 1500-1700 Euro (that's why I decided to choose the Coffee Lake and not the Skylake-X CPU for instance).
My main preference is to buy a reliable PC with long lifetime of the major (and more difficult to upgrade) components like case, motherboard and CPU.
Advises regarding the components choice are very welcome too :).
Bedankt!
[ Voor 6% gewijzigd door PeterNik op 08-04-2018 17:17 ]
  • mitsumark
  • Laatst online: 12:39
#ProductPrijsSubtotaal
1Intel Core i7-8700 Boxed€ 289,-€ 289,-
1ASRock H370 Pro4€ 99,-€ 99,-
1MSI Radeon RX 570 ARMOR 8G OC€ 339,-€ 339,-
1WD Blue WD20EZRZ, 2TB€ 60,94€ 60,94
1Fractal Design Meshify C - Dark TG€ 84,91€ 84,91
1be quiet! Pure Rock€ 31,47€ 31,47
1Corsair Vengeance LPX CMK16GX4M2C3000C16€ 171,-€ 171,-
1Corsair RM550x Zwart€ 84,95€ 84,95
1Samsung 960 EVO 500GB€ 195,-€ 195,-
Bekijk collectie
Importeer producten
Totaal€ 1.355,27
Everything should be available at Azerty for less than 1400 euro (without operating system), they offer service to assemble as well.
I dont think they have a builder on the site, but just send them a mail with the list of components and/or place everything in the basket (even assembly you can place in the basket).
Assembly options: https://azerty.nl/over-assemblage
PS: if one of the screens only has VGA connection you need a different graphics card.
  • PeterNik
mitsumark, thank you very much for the link to the Azerty webshop, I'm looking into it now.
I also really appreciate your advice for the components. It matches very well with my plan - perhaps except the CPU (maybe 8700K will be a bit faster for a small price difference?) and the motherboard: does the price matters as I plan to use is for several years? So perhaps this beast - pricewatch: Gigabyte Z370 Aorus Gaming 7 - could do a better job together with the overclocked CPU?
This brings the price of the system to the upper range of my expectations but I can live with this :)
  • br00ky
  • Laatst online: 09:25
br00ky
English is okay, as long as you stick to our rules.
Je topicstart is nu al vrij compleet, maar we verwachten hier ook al een eigen opzetje. Zie ook de volgende passage uit het DAA beleid.
3. Eigen onderzoek is nog steeds vereist (dit is en blijft GoT!) en we verwachten dat je zelf al een idee hebt opgedaan. Als je zelf al een configuratie hebt bedacht, post deze dan met behulp van de wenslijst in de pricewatch hier. Dat geeft je mede-Tweakers inzicht in waar je zelf aan hebt gedacht en hoe er binnen je budget betere of andere keuzes te maken zijn.
Het is dus verplicht eerst zelf met een voorstel te komen en dit voorstel te onderbouwen. Een simpele opsomming van eisen/wensen is niet wenselijk; je topic wordt in dat geval dan ook gesloten. Je kan in dat geval contact opnemen met de moderator die je topic gesloten heeft om te vragen of hij weer open mag, mits je natuurlijk wijzigingen hebt aangebracht zodat het geheel wel aan de eisen voldoet.
Een simpel antwoord als 'Ik heb heb er niet veel verstand van!' óf 'Ik ben veel sneller klaar als jullie het doen!' is uit den boze.
Aangezien dit ontbreekt sluit ik voorlopig je topic. Dit lijkt flauw, maar enerzijds doen we dit om ervoor te zorgen dat je zélf inzicht krijgt in wat er mogelijk is en anderzijds om de kwaliteit van de topicstarts hier te bewaken. Anders vervalt dit subforum in een "ik wil een pc voor x euro, mkay dank je doei" niveau, en dat is iets dat niemand wil :). Je eerste opzet hoeft niet top te zijn, we willen alleen graag dat je er eerst over nadenkt.
Om inspiratie op te doen kun je de verschillende topics in dit subforum en de best buy guides doorzoeken.
Met de Handleiding Pricewatch dien je vervolgens een mooi lijstje te maken (dus géén copy-paste lijsten van andere sites bijv.). Met die informatie kan vervolgens gericht advies gegeven worden om het helemaal aan jouw wensen aan te passen.
Neem even contact op met me (pijltje naast mijn username, vervolgens "stuur bericht") als je een lijstje hebt, dan gooi ik je topic weer open, zodat je die erbij kan plaatsen.
Succes!
