radio.tweakers.net
  • 106 views sinds 30-01-2008
Waarom draaien jullie op versie 1.6.0rc2? Versie 1.8.0 is al uit FYI.
Deze goodies lopen jullie mis: *D
v1.8.0 (January 4, 2001)
* new features
- internal buffer size now 1 meg -- better resiliency for bad connections
- initial buffer fill size now larger -- no waits for fast connects
- far better international language support
- new web logs now approved for Arbitron ratings
- buffer position now tracked in admin page (entries that are always at zero
are recording or relaying your stream. should nominally sit around 128,000)
- Solaris build now even more optimized, we've pushed 500Mbps on one box with
this build.
- Title updates should now be much more closely synchronized with the change
in the audio stream.
* new config items (none)
* bugfixes
- Windows sleep granularity fixed. No more skipping on high bitrate streams.
Sorry.
- XML and HTML pages now correctly encode high-byte characters. You need to
upgrade to DSP 1.8.0 for international titling to work correctly.
- Good tweaks in good places, smarter net delivery, smarter buffering.
v1.7.1 (August 29, 2000)
* new features (none)
* new config items
- Unique -- Allows variable substitution in mass configuration setups
- Include -- Reads additional configuration file
* bugfixes
- Average Listener Time now calculated only for listeners connected longer
than one minute, and includes current listeners in calculated value
- Average Listener Time no longer returns negative values on very short
connects
- Windows version no longer experiences heavy skipping (1.7.0 bug)
- Fixed rare condition where "zombie" listeners took up listener slots
v1.7.0 (August 14, 2000)
* new features
- New XML pages for subsets of shoutcast statistics data. See XML section.
- Average Listener Time now listed on status page
- New logging system tracks individual listener events, and assigns
unique ID for every connected socket for easier tracking.
- DNAS should now be MUCH more optimized for high-bandwidth
delivery (listener impact on CPU is now linear instead of geometric)
* new config items
- WebLog (Yes/No, default No) - display http:// requests in log
- TchLog (Yes/No, default Yes) - display yp touches
- Sleep (value) - tweakable parameter for high-traffic SHOUTcast
servers -- adjusts sleep granularity.
- CpuCount (value) - tweakable parameter for high-traffic SHOUTcast
servers -- adjusts client threads.
* bugfixes
- All non-ASCII characters are now properly encoded for XML
- YP now receives average listener time data (for ratings)
v1.666.1 (June 12 2000)
* bug fixes
- Occasional CPU full load issue at idle, and during client connections
(a thread-safe sleep() would sure be nice. way to track it down, tag.)
v1.666.0 (June 6 2000)
* new features
- ListenerTimer config item will force-disconnect listeners active for
the number of minutes specified
- AllowRelay config item will permit or deny other servers from relaying
- AllowPublicRelay config item allows relaying, but forces relays to treat
server as non-public
- Ban / Reserve IP lists now available to add on-the-fly
- Initial stream backpositioning set at 32k (faster sync-up for listeners
with faster connections)
- Taillog via HTML admin now available regardless of disk logging setting
* bugfixes
- XML now displays appropriately URL-encoded data for all wacky characters
- Linux SIGSEGV errors fixed. No, really, I mean it.
- Taillog now handled internally via circular buffer because Linux pukes
when more than one thread is accessing a file a lot
- Relay lock fixed
- On-demand content delivery fixed for Linux
  • Kees
  • Laatst online: 10:46
Kees
Serveradmin / BOFH / DoC
wij draaien icecast (http://www.icecast.org)
de server draait op de nieuwste versie..
Ik zag toch echt Shoutcast v1.6.0rc2 staan toen ik de eigenschappen van de stream bekeek.
