How can I adjust active pen sensitivity in Mixoo stylus ?
  • 304 views
dear all,
I have a mid 2017 ipad pro which has some sort of Mixoo active stylus support (though I can't find any references to it in the device manager or anywhere). I've bought a Mixoo Active Stylus by Asin: B01N9C9AT6 on Amazon.
About this stylus:
touchstift afmetingen:
Lengte: 5,5 " (140 mm);
Gewicht: 24 G
Baanbrekende eigenschap: vervangbaar
Materiaal: gemaakt van roestvrij staal en aluminium zonder kunststofonderdelen.
Biedt een gladde ervaring met pen soortgelijke schrijven voor uw tabletten en smartphones met aanraakscherm.
Praktisch in stiftvorm (clip stiften), perfect voor de uitvoering rond.
I can't find a way to adjust the pen's sensitivity. Right now I have to make a lot of pressure for the pen to register. There must be a registry setting somewhere... Or some hidden old scroll control panel UI for it.
Afbeeldingslocatie: https://images-na.ssl-images-amazon.com/images/I/61KGkHHLBgL._SL1500_.jpg
Does anyone know how to do it?
Thanks!!
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Een topic is wel genoeg :)
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
