Mijn vraag
Is there any Dutch online shop which provides PSU cable modding? Basically, I am trying to have micro ITX chassis built but all PSU cables of Corsair PSU (type 4 cable) are way too long for a mITX chassis.
An alternative is that if there is any Dutch shop selling pin connecting tools but also selling things like Corsair type 4 gen-3 connector?
Corsair RM650 (so basically a problem with type 4 to 24-pin cable and type 4 to PCI-e cable being too long). The chassis is filled up with cable and no space for ventilation at all.
CableMod Configurator is a US-based online cable modding option, but too much trouble with EU customs control. Also difficult to find branded connector such as Corsair type 4 (Gen-3) to some other connector type.
Thanks in advance
  • The Eagle
  • Laatst online: 00:11
The Eagle
I wear my sunglasses at night
Dit is een NL forum, vandaar ook de reactie in het Nederlands, wat hier de voertaal is.
Kennelijk snap je Nederlands wel, want je hebt de template gebruikt. Aangenomen dat, snap ik niet helemaal waarom je je post in het Engels doet ;)
Dat gezegd hebbend: wat had je zelf al gezocht en gevonden? Er zijn zeker webshops die spullen leveren. Volgens mij moet jij met een connector tool al een heel eind komen. Check ff bij Conrad.nl ofzo.
Hi @The Eagle,
My dutch is only enough to understand the user interface. I don't think it is sufficient to ask the question like that. My colleague told me about this site as the main hardware modding and tweaking site so this is like the last resort for me. Also the categories are given nearly in English. It is merely easy enough to find the right place.
I am expat living in the Netherlands so I must say my Dutch level is merely enough for doing shopping at supermarket.
Sorry for the language confusing. Is there a rule to limited language to Dutch only? If so, then I will ask my colleague to ask future question in Dutch instead. Will that be better?
But thanks for the linkage to conrad.nl. I will take a look first
[ Voor 4% gewijzigd door Verwijderd op 26-03-2018 17:30 ]
  • WEBGAMING
  • Registratie: Oktober 2017
  • Laatst online: 28-10 12:53
https://www.highflow.nl/modding/stroomkabels/?features_hash=
Do you want a custom job? I think they can make it happen, send them a message.
Or do it yourself, they have the tools too. Having this stuff custom made is pretty expensive, it takes a lot of time. Its not difficult, but it just takes a lot of time.
[ Voor 41% gewijzigd door WEBGAMING op 26-03-2018 21:10 ]
  • SA007
  • Laatst online: 28-08 20:17
SA007
Moderator Tweaking
Dit is typisch iets voor V&A, dit is vragen om een dienst.
Daarnaast is dit een nederlands forum, niet engels.
