[Debian] Krijg KVM niet werkend (failed to initialize netcf)
  • Simkin
  • Laatst online: 11-09 11:15
Ik probeer KVM werkend te krijgen maar de Virtualization daemon will maar niet starten, ik zie niet in wat ik fout doe. Kan iemand mij een zetje in de juiste richting geven? Ligt het mogelijk aan AppArmor?
Ik heb deze instructies gevolgd
root@vault13:/# uname -a
Linux vault13.eu 4.13.13-6-pve #1 SMP PVE 4.13.13-41 (Wed, 21 Feb 2018 10:07:54 +0100) x86_64 GNU/Linux
root@vault13:/# apt install qemu-kvm libvirt-clients libvirt-daemon-system
Reading package lists... Done
Building dependency tree
Reading state information... Done
libvirt-clients is already the newest version (3.0.0-4+deb9u2).
libvirt-daemon-system is already the newest version (3.0.0-4+deb9u2).
qemu-kvm is already the newest version (1:2.8+dfsg-6+deb9u3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@vault13:/# virsh list --all
error: failed to connect to the hypervisor
error: Failed to connect socket to '/var/run/libvirt/libvirt-sock': No such file or directory
root@vault13:/# systemctl status libvirtd
● libvirtd.service - Virtualization daemon
   Loaded: loaded (/lib/systemd/system/libvirtd.service; enabled; vendor preset: enabled)
   Active: inactive (dead) since Thu 2018-03-15 10:21:10 CET; 1s ago
     Docs: man:libvirtd(8)
           http://libvirt.org
  Process: 6874 ExecStart=/usr/sbin/libvirtd $libvirtd_opts (code=exited, status=0/SUCCESS)
 Main PID: 6874 (code=exited, status=0/SUCCESS)
      CPU: 95ms
Mar 15 10:21:10 vault13.eu systemd[1]: Starting Virtualization daemon...
Mar 15 10:21:10 vault13.eu systemd[1]: Started Virtualization daemon.
Mar 15 10:21:10 vault13.eu libvirtd[6874]: 2018-03-15 09:21:10.915+0000: 6899: info : libvirt version: 3.0.0, package: 4+deb9u2 (Guido Günther <agx@sigxcpu.org> Sat, 20 Jan 2018 17:51:39 +0100)
Mar 15 10:21:10 vault13.eu libvirtd[6874]: 2018-03-15 09:21:10.915+0000: 6899: info : hostname: vault13.eu
Mar 15 10:21:10 vault13.eu libvirtd[6874]: 2018-03-15 09:21:10.915+0000: 6899: error : netcfStateInitialize:93 : internal error: failed to initialize netcf
Mar 15 10:21:10 vault13.eu libvirtd[6874]: 2018-03-15 09:21:10.915+0000: 6899: error : virStateInitialize:775 : Initialization of netcf state driver failed: internal error: failed to initialize netcf
Mar 15 10:21:10 vault13.eu libvirtd[6874]: 2018-03-15 09:21:10.915+0000: 6899: error : daemonRunStateInit:892 : Driver state initialization failed
root@vault13:/# ifconfig
29
30
31
32
33
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.240  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::d250:99ff:fe09:98ae  prefixlen 64  scopeid 0x20<link>
        ether d0:50:99:09:98:ae  txqueuelen 1000  (Ethernet)
        RX packets 1810533  bytes 992632742 (946.6 MiB)
        RX errors 0  dropped 2  overruns 0  frame 0
        TX packets 1026583  bytes 2586426243 (2.4 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 0.0.0.0
        ether 02:42:89:d8:1c:69  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        RX packets 1900628  bytes 1030615918 (982.8 MiB)
        RX errors 0  dropped 25  overruns 0  frame 0
        TX packets 2515621  bytes 2698165288 (2.5 GiB)
        device interrupt 20  memory 0xf0700000-f0720000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 1185402  bytes 301884581 (287.8 MiB)
        TX packets 1185402  bytes 301884581 (287.8 MiB)
Na wat onderzoek zag ik dit:
root@vault13:/# dmesg
[74712.167657] audit: type=1400 audit(1521105670.915:30): apparmor="DENIED" operation="create" profile="/usr/sbin/libvirtd" pid=6874 comm="libvirtd" family="inet" sock_type="stream" protocol=0 requested_mask="create" denied_mask="create"
root@vault13:/# aa-audit /usr/sbin/libvirtd
root@vault13:/# systemctl restart libvirtd
[77762.665141] audit: type=1400 audit(1521108721.414:33): apparmor="AUDIT" operation="open" profile="/usr/sbin/libvirtd" name="/etc/ld.so.cache" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665145] audit: type=1400 audit(1521108721.414:34): apparmor="AUDIT" operation="getattr" profile="/usr/sbin/libvirtd" name="/etc/ld.so.cache" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665258] audit: type=1400 audit(1521108721.414:35): apparmor="AUDIT" operation="open" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt-admin.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665283] audit: type=1400 audit(1521108721.414:36): apparmor="AUDIT" operation="getattr" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt-admin.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665300] audit: type=1400 audit(1521108721.414:37): apparmor="AUDIT" operation="file_mmap" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt-admin.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665416] audit: type=1400 audit(1521108721.414:38): apparmor="AUDIT" operation="open" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665441] audit: type=1400 audit(1521108721.414:39): apparmor="AUDIT" operation="getattr" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665458] audit: type=1400 audit(1521108721.414:40): apparmor="AUDIT" operation="file_mmap" profile="/usr/sbin/libvirtd" name="/usr/lib/libvirt.so.0.3000.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665651] audit: type=1400 audit(1521108721.414:41): apparmor="AUDIT" operation="open" profile="/usr/sbin/libvirtd" name="/usr/lib/x86_64-linux-gnu/libnl-route-3.so.200.22.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
[77762.665674] audit: type=1400 audit(1521108721.414:42): apparmor="AUDIT" operation="getattr" profile="/usr/sbin/libvirtd" name="/usr/lib/x86_64-linux-gnu/libnl-route-3.so.200.22.0" pid=30225 comm="libvirtd" requested_mask="r" fsuid=0 ouid=0
root@vault13:/# cat /etc/apparmor.d/usr.sbin.libvirtd
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
# Last Modified: Mon Apr  5 15:03:58 2010
#include <tunables/global>
@{LIBVIRT}="libvirt"
/usr/sbin/libvirtd flags=(attach_disconnected,audit) {
  #include <abstractions/base>
  #include <abstractions/dbus>
  capability kill,
  capability net_admin,
  capability net_raw,
  capability setgid,
  capability sys_admin,
  capability sys_module,
  capability sys_ptrace,
  capability sys_pacct,
  capability sys_nice,
  capability sys_chroot,
  capability setuid,
  capability dac_override,
  capability dac_read_search,
  capability fowner,
  capability chown,
  capability setpcap,
  capability mknod,
  capability fsetid,
  capability audit_write,
  capability ipc_lock,
  # Needed for vfio
  capability sys_resource,
  network inet stream,
  network inet dgram,
  network inet6 stream,
  network inet6 dgram,
  network packet dgram,
  network packet raw,
  # Very lenient profile for libvirtd since we want to first focus on confining
  # the guests. Guests will have a very restricted profile.
  / r,
  /** rwmkl,
  /bin/* PUx,
  /sbin/* PUx,
  /usr/bin/* PUx,
  /usr/sbin/virtlogd pix,
  /usr/sbin/* PUx,
  /{usr/,}lib/udev/scsi_id PUx,
  /usr/{lib,lib64}/xen-common/bin/xen-toolstack PUx,
  /usr/{lib,lib64}/xen/bin/* Ux,
  # force the use of virt-aa-helper
  audit deny /{usr/,}sbin/apparmor_parser rwxl,
  audit deny /etc/apparmor.d/libvirt/** wxl,
  audit deny /sys/kernel/security/apparmor/features rwxl,
  audit deny /sys/kernel/security/apparmor/matching rwxl,
  audit deny /sys/kernel/security/apparmor/.* rwxl,
  /sys/kernel/security/apparmor/profiles r,
  /usr/{lib,lib64}/libvirt/* PUxr,
  /usr/{lib,lib64}/libvirt/libvirt_parthelper ix,
  /usr/{lib,lib64}/libvirt/libvirt_iohelper ix,
  /etc/libvirt/hooks/** rmix,
  /etc/xen/scripts/** rmix,
  # allow changing to our UUID-based named profiles
  change_profile -> @{LIBVIRT}-[0-9a-f]*-[0-9a-f]*-[0-9a-f]*-[0-9a-f]*-[0-9a-f]*,
  /usr/{lib,lib64,lib/qemu,libexec}/qemu-bridge-helper Cx -> qemu_bridge_helper,
  # child profile for bridge helper process
  profile qemu_bridge_helper {
   capability setuid,
   capability setgid,
   capability setpcap,
   /dev/net/tun rw,
   /etc/qemu/** r,
   owner @{PROC}/*/status r,
   /usr/{lib,lib64,lib/qemu,libexec}/qemu-bridge-helper rmix,
  # Site-specific additions and overrides. See local/README for details.
  #include <local/usr.sbin.libvirtd>
[ Voor 38% gewijzigd door Simkin op 15-03-2018 11:52 . Reden: AppArmor ]
  • Simkin
Verwijderen AppArmor hielp, geen tijd/zin om het correct op te lossen
  • Hero of Time
  • Laatst online: 22:00
Hero of Time
Moderator LNX
There is only one Legend
Dat is wel heel grof. Misschien was het genoeg om AA te herstarten om de nieuwe config te laten laden? Of had je al een paar keer een reboot gegeven?
Commandline FTW
  • Simkin
Disable/enable en reboot werkte allemaal niet helaas.
  • Hero of Time
Hero of Time
Moderator LNX
Zelfs uitschakelen niet? :o
Commandline FTW
