Nightly of experimental?
  • salvw
  • Laatst online: 18-09 16:18
nieuws: LineageOS 15.1 op basis van Android 8.1 verschijnt
@Olaf
Je schrijft:
De versie van LineageOS 15.1 die maandag verschijnt is nog een nightly build, geen stabiele release.
Echter, in het gelinkte artikel staat:
Nightly builds will roll out this Monday
We’ll be testing the infrastructure this weekend (24th and 25th Feb.), you will see some 15.1 builds appear on our download portal marked as EXPERIMENTAL.
The first batch of nightlies builds will roll out on Monday 26th February, while the other days of the week will remain dedicated to 14.1 devices. Keep in mind that if you install an EXPERIMENTAL build you will not receive OTA updates, but you’ll have to manually flash a NIGHTLY build instead.
Eerst zijn er dus (onstabiele) EXPERIMENTAL builds maar deze maandag komen er dus (stabiele) NIGHLTY builds.
zie ook deze reddit post van een r/linageos mod
LineageOS is a "rolling release" software. It means that new builds are continuosly produced (every week for each device since it takes a long time to get through all the devices builds without abusing the hardware) and there's no "stable" / "recommend" release.
All our official builds are meant to guarantee you the hardware will be working (from 15.1 onwards this is enforced, but most 14.1 builds should be fine too).[
https://www.reddit.com/r/..._of_type_nightly/dunijne/
  • Olaf
  • Laatst online: 23-07-2024
