[Ervaringen] VLC 3.0 Vetinari
  • Balance
  • Laatst online: 17-11 09:16
VLC 3.0 Vetinari
3.0 Highlights
  • VLC 3.0 "Vetinari" is a new major update of VLC.
  • VLC 3.0 activates hardware decoding by default, to get 4K and 8K playback!
  • It supports 10bits and HDR
  • VLC supports 360 video and 3D audio, up to Ambisoncics 3rd order
  • Allows audio passthrough for HD audio codecs
  • Can stream to Chromecast devices, even in formats not supported natively
  • Can play Blu-Ray Java menus: BD-J
  • VLC supports browsing of local network drives and NAS
Links
Core
  • Network browsing for distant filesystems (SMB, FTP, SFTP, NFS...)
  • HDMI passthrough for Audio HD codecs, like E-AC3, TrueHD or DTS-HD
  • 12bits codec and extended colorspaces (HDR)
  • Stream to distant renderers, like Chromecast
  • 360 video and 3D audio playback with viewpoint change
  • Support for Ambisonics audio and more than 8 audio channels
  • Subtitles size modification live
Acceleration
  • Hardware decoding and display on all platforms
  • HEVC hardware decoding on Windows, using DxVA2 and D3D11
  • HEVC hardware decoding using OMX and MediaCodec (Android)
  • MPEG-2, VC1/WMV3 hardware decoding on Android
  • Important improvements for the MMAL decoder and output for rPI and rPI2
  • HEVC and H.264 hardware decoding for macOS and and iOS based on VideoToolbox
  • New VA-API decoder and rendering for Linux
Codecs
  • BD-Java menus and overlay in Blu-Ray
  • Experimental AV1 video and Daala video decoders
  • OggSpots video decoder
  • New MPEG-1 & 2 audio layer I, II, III + MPEG 2.5 decoder based on libmpg123
  • New BPG decoder based on libbpg
  • TDSC, Canopus HQX, Cineform, SpeedHQ, Pixlet, QDMC and FMVC decoders
  • TTML subtitles support
  • Rewrite of webVTT subtitles support, including CSS style support
  • BluRay text subtitles (HDMV) deocoder
Containers
  • Rework of the MP4 demuxer
  • Rework of the TS demuxer
  • HD-DVD .evo support
  • Rework of the PS demuxer
  • Improvements on MKV
Video outputs and filters
  • OpenGL as Linux/BSD default video output
  • Improvements in OpenGL output: direct displaying and HDR tonemapping
  • Rework of the Android video outputs
  • New Direct3D11 video output supporting both Windows desktop and WinRT modes
  • HDR10 support in Direct3D11 with Windows 10 Fall Creator Update
  • Hardware deinterlacing on the rPI, using MMAL
  • Video filter to convert between fps rates
  • Hardware accelerated deinterlacing/adjust/sharpen/chroma with VA-API
  • Hardware accelerated adjust/invert/posterize/sepia/sharpen with CoreImage
  • Hardware accelerated deinterlacing/adjust/chroma with D3D9 and D3D11
Audio outputs and filters
  • Complete rewrite of the AudioTrack Android output
  • New Tizen audio output
  • HDMI/SPDIF pass-through support for WASAPI (AC3/DTS/DTSHD/EAC3/TRUEHD)
  • Support EAC3 and TRUEHD pass-through for PulseAudio
  • Rework of the AudioUnit modules to share more code between iOS and macOS
  • SoX Resampler library audio filter module (converter and resampler)
  • Ambisonics audio renderer, supporting up to 3rd order
  • Binauralizer audio filter, working with Ambisonics or 5.1/7.1 streams
  • Pitch shifting module
OS versions
  • Windows XP ➔ 10 RS3
  • macOS 10.7 ➔ 10.13
  • iOS 7 ➔ 11
  • Android 2.3 ➔ 8.1
  • Android TV, Chromebooks with Play Store
  • Windows RT 8.1, Windows Phone 8.1
  • Windows 10 Mobile, Xbox 1, Windows Store
  • GNU/Linux, Ubuntu, *BSD
Android Specific
  • Chromecast support from your phone
  • HEVC hardware decoding using MediaCodec
  • Android Auto with voice actions
  • Available on all Android TV, Chromebooks & DeX
  • Support for Picture-in-Picture
  • Playlist files detection
[ Voor 63% gewijzigd door Balance op 12-02-2018 10:21 ]
  • Balance
Holy shit wat een release is dit. Ik betaal niet vaak voor software, maar deze mensen hebben het zeker verdient. Echt alles wat je kan bedenken zit erin!
  • minimaLL
  • Laatst online: 23:13
Chromecast krijg ik nog niet aan de praat. Blijft hangen bij het laden op mijn tv-scherm... :(
  • Kaalus
Volgens mij een bugje in de aansturing van positie d.m.v. scrollwiel, die doet nu altijd het volume, ongeacht waar de instelling op staat.
Verder wel content met de nieuwe iconen, oogt net dat beetje slicker. Chromecasts hier in het netwerk werden gelijk gevonden, alleen nog geen media naar gecast. Morgen eens proberen, ben er wel benieuwd naar!
  • Jeroentjuh82
  • Laatst online: 20-11 14:09
Zou wel aan mn cpu liggen, AMD A8-3850, dat 4k niet vloeiend wordt afgespeeld want in MPC gaat het hetzelfde en in Kodi.
  • Nyarlathotep
  • Laatst online: 00:37
Nyarlathotep
Crawling Chaos
Het lijkt er op dat VLC eindelijk mijn MPC-HC + MadVr installatie kan vervangen :)
Het afspelen van 1080P bestanden met DTS-Master spoor gaat prima tot nu toe.
Één vraag echter: MPC-HC laat mijn tv 'terug' schakelen naar 24Hz (beeld wordt even zwart).
VLC doet dit niet, en ik zie in de advanced settings ook geen optie hiervoor. Waarschijnlijk omdat mijn tv op 120Hz staat (een vijfvoud van 24Hz) zie ik niet direct verschil.
Maar toch... Heeft VLC ergens de optie om je scherm op 24Hz te zetten bij 24P materiaal?
Edit: Het duurt soms wel tot een seconde of 20 voordat een videobestand wordt afgespeeld. Met MPC-HC heb ik dit issue niet... Waar kan dit aan liggen?
[ Voor 12% gewijzigd door Nyarlathotep op 27-02-2018 21:44 ]
Mijn muziekcollectie op Discogs
