• amsterdamned
  • Laatst online: 02-11 18:27
Afbeeldingslocatie: https://store.storeimages.cdn-apple.com/4662/as-images.apple.com/is/image/AppleInc/aos/published/images/i/ma/imacpro/27/imacpro-27-retina-selection-hero?wid=452&hei=420&fmt=jpeg&qlt=95&op_sharpen=0&resMode=bicub&op_usm=0.5,0.5,0,0&iccEmbed=0&layer=comp&.v=1511982294002
Display
5K Retina display
27-inch (diagonal) Retina 5K display
5120‑by‑2880 resolution with support for one billion colors
500 nits brightness
Wide color (P3)
Processor
8-Core
3.2GHz Intel Xeon W
Turbo Boost up to 4.2GHz
19MB cache
Graphics
Vega 56
Radeon Pro Vega 56 graphics processor
with 8GB of HBM2 memory
56 compute units
3584 stream processors
9 teraflops single precision
18 teraflops half precision
Memory
32GB
32GB of 2666MHz DDR4 ECC memory
Quad-channel memory controller
Storage
1TB SSD
Video Support and Camera
1080p FaceTime HD camera
Simultaneously supports full native resolution on the built-in display at 1 billion colors and:
Two 5120‑by‑2880 (5K) external displays at 60Hz with support for 1 billion colors, or
Four 3840-by-2160 (4K UHD) external displays at 60Hz with support for 1 billion colors, or
Four 4096‑by‑2304 (4K) external displays at 60Hz with support for millions of colors
Support for extended desktop and video mirroring modes
Thunderbolt 3 digital video output
Native DisplayPort output over USB-C
Thunderbolt 2, HDMI, DVI, and VGA output supported using adapters (sold separately)
Audio
Stereo speakers
Four microphones
3.5 mm headphone jack
Connections and Expansion
3.5 mm
headphone
SDXC card slot
USB 3
Thunderbolt 3
(USB-C)
Ethernet
10Gb Ethernet
Nbase-T Ethernet with support for 1Gb, 2.5Gb, 5Gb, and 10Gb Ethernet using RJ‑45 connector
SDXC card slot with support for UHS‑II
Four USB 3 ports
Four Thunderbolt 3 (USB-C) ports with support for:
DisplayPort 1.2
Thunderbolt (up to 40 Gbps)
USB 3.1 Gen 2 (up to 10 Gbps)
Thunderbolt 2, HDMI, DVI, and VGA supported using adapters (sold separately)
Input
Space Gray Magic Keyboard with Numeric Keypad
Space Gray Magic Mouse 2
Optional Space Gray Magic Trackpad 2
Wireless
Wi-Fi
802.11ac Wi-Fi wireless networking
IEEE 802.11a/b/g/n compatible
Bluetooth
Bluetooth 4.2 wireless technology
Size and Weight
25.6 inches
(65.0 cm) 20.3 inches
(51.6 cm)
Height: 20.3 inches (51.6 cm)
Width: 25.6 inches (65.0 cm)
Stand depth: 8 inches (20.3 cm)
Weight: 21.5 pounds (9.7 kg)3
Electrical and Operating Requirements
Line voltage: 100–240V AC
Frequency: 50Hz to 60Hz, single phase
Operating temperature: 50° to 95° F (10° to 35° C)
Relative humidity: 5% to 95% noncondensing
Operating altitude: tested up to 16,400 feet (5000 meters)
In the Box
iMac Pro
Lightning to USB Cable
Power cord
Operating System
macOS High Sierra
macOS is the operating system that powers everything you do on a Mac. macOS High Sierra brings new forward-looking technologies and enhanced features to your Mac. It’s macOS at its highest level yet.
Bron: https://www.apple.com/lae/imac-pro/specs/
  • amsterdamned
Er was nog geen topic over de iMac Pro en ik ben erg benieuwd naar ervaringen met deze krachtpatser bij verschillend gebruik. Ikzelf overweeg de iMac Pro aan te schaffen als beginnend programmeur (niet grafisch). Daarnaast wil ik mij verdiepen in videoverwerking en Final Cut X gaan gebruiken en dan ook 4k 60fps video gaan editen. Het lijkt mij dat het basis model meer dan voldoende is voor mij. Aangezien ik toch eigenlijk alleen maar thuis programmeer en dat graag op een groot 5k scherm wil doen is dit ongeveer even duur als een Macbook 15" in combinatie met een LG 5k scherm. Daarnaast is het een stuk sneller en zit ik absoluut niet te wachten op een touchbar. Ik hoor graag hoe jullie er over denken!
  • henri8096
  • Laatst online: 10-11 19:23
henri8096
BIM is not a software!
Tsja, dit model valt kwa prijs naar mijn mening in de categorie: "Aanschaf alleen te verantwoorden als je je geld er mee verdiend".
Of als je het voor een redelijk uit de hand gelopen hobby gebruikt en toch het geld hebt liggen.
Oftewel gebruik je FCPX , ontwikkel je (VR) toepassingen, games etc. voor professionele doeleinden.
Alles waarbij je redelijke rekenkracht (al dan niet grafisch) voor nodig hebt.
Ga je het gebruiken voor de hobby, bespaar je dan de centen en ga voor de gewone iMac die is voor niet kritische doeleinden op dit moment snel genoeg
(ook voor FCPX).
En besef je dat er nog een nieuwe Mac Pro aan zit te komen (vervanging van het prullenbak-model) en dat deze waarschijnlijk een stuk beter uitbreidbaar zal zijn. De iMac Pro is redelijk beperkt in dat opzicht.
Neemt niet weg dat ik dit apparaat wel eens aan de tand zou willen voelen. :9~
Ik ben erg benieuwd naar de prestaties in FCPX _/-\o_
--Stuck in the Apple Ecosystem (and happy about it).--
  • Yzord
  • Laatst online: 21:45
Yzord
Ubi fumus, ibi ignis
Ik heb deze besteld
Configuration
3.0GHZ 10-CORE INTEL XEON
64GB 2666MHZ DDR4 ECC MEMORY
1TB SSD
RADEON PRO VEGA 64 16GB
MAGIC MOUSE 2
MAGIC KYBD+USER'S GUIDE-N
COUNTRY KIT-Z
Hoop hem ergens volgende week binnen te krijgen en meer te delen. Hier komen 2 x LG 27UD88 monitoren naast te staan (helaas 4k).
[ Voor 10% gewijzigd door Yzord op 23-01-2018 21:56 ]
  • Balance
  • Laatst online: 28-10 06:59
Te koop voor het zeer specifieke bedrag van € 8.377,91 in de Apple Store (€ 7.874,68 in de Apple Edu Store).
Verder moet je even bedenken dat deze guy gewoon drie verschillende iMac Pro's heeft om te benchmarken :P.
[ Voor 13% gewijzigd door Balance op 01-02-2018 21:22 ]
  • Yzord
Yzord
Valt me vies tegen die 18 core qua performance... idd de 10 core best buy dus
