I won a GFX card so now i need a computer
  • 506 views
Hi im a australian in belgium (oostende) and i do all my gaming on a laptop and xboxone but i just won a rog 1080 so i figure i might start playing pc again, i will need a monitor +case+mobo+hdd+cpu+psu
and im only in belgium for 6 more months so should i look at a second hand system or a new system like super bare bones
any advice, im not sure the best place to look as i check on 2dehands.be and everyone mislist there items, just monitors in the complete systems area
any help would be awesome
  • Bolko
  • Registratie: Maart 2015
  • Laatst online: 13:11
You could check the https://tweakers.net/aanbod/ Section of tweakers.net
  • illean
  • Laatst online: 13-10 19:00
There is a shortlist you need to fill in before you can post your request in this forum. I'm aware it is in Dutch. The most important thing you have to answer is: where do you use your system for? Like: what resolution would you like to game on? Old or new games etc. And the other thing we expect is that you do some research yourself. You have to come up with your own list of products you think might be good for you.
  • Hackus
Hackus
Lifting Rusty Iron !
G'Day Mate !
Did you check here ;)
  • OPELOPA
  • Laatst online: 13:38
You could try: Vraag & Aanbod in the upper bar and select Laptops en systemen.
  • Soundstorm2010
  • Laatst online: 03-07-2025
If you already are doing everything on a laptop and you are only in belgium for 6 months, in my opinion, its a waste of time and money to get a NEW build PC.
You can try to buy some 2nd hand machine, but dont think the grafikcard will be usefull.. Best thing is just to sell the ROG 1080 card, and put you're money to use somewhere else :)
But still if you are looking for something, https://tweakers.net/aanbod/
Good luck
Build To PLay /\ Kicking Ass, and Taking Names // My New Specs 2024 // Orgin: PitBullNL2010 // Steam: PitBullNL2010 //
  • br00ky
  • Laatst online: 17:00
br00ky
English is no problem, however we expect you to read and oblige to the rules and regulations of the forum. See DAA beleid and Het algemeen beleid #quickstart.
As sufficient research is missing, I have to close your topic.
