CAP2702I-E-K9 autonomous configure problem
  • 224 views
  • elisa9180
  • Laatst online: 30-03-2023
Best,
I have a problem to make my config complete. I still miss 2 things
1 WPA2 on the SSID
2 BVI mapt to management vlan 10
Can someone help me to realize the 2 things thx. if you still see wrong config I am free to learn
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname WIFI-AP
logging buffered informational
logging rate-limit console 9
no logging console
clock timezone GMT 1
clock summer-time cet-summertime recurring last Sun Mar 2:00 last Sun Oct 3:00
ip domain name S-Networks.org
dot11 mbssid
dot11 syslog
dot11 vlan-name SN-Home-00020000-24 vlan 15
dot11 vlan-name SN-Office-00025000-24 vlan 25
dot11 vlan-name SN-IOT-00030000-24 vlan 30
mbssid
dot11 ssid S-Guest
vlan 15
authentication open
WPA2 Password
mbssid guest-mode dtim-period 90
information-element ssidl advertisement
dot11 ssid S-OFFICE
vlan 25
authentication open
WPA2 Password
mbssid guest-mode dtim-period 80
dot11 ssid S-IOT
vlan 30
authentication open
WPA2 Password
ip tcp synwait-time 10
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 15 mode ciphers aes-ccm
encryption vlan 25 mode ciphers aes-ccm
encryption vlan 30 mode ciphers aes-ccm
encryption mode ciphers aes-ccm
ssid S-Networks-Guest
ssid S-Networks-OFFICE
ssid S-Networks-IOT
interface Dot11Radio1
no ip address
no ip route-cache
ssid S-Networks-IOT
interface Dot11Radio0.15
encapsulation dot1Q 15
no ip route-cache
bridge-group 15
bridge-group 15 subscriber-loop-control
bridge-group 15 block-unknown-source
no bridge-group 15 source-learning
no bridge-group 15 unicast-flooding
bridge-group 15 spanning-disabled
interface Dot11Radio0.25
encapsulation dot1Q 25
no ip route-cache
bridge-group 25
bridge-group 25 subscriber-loop-control
bridge-group 25 block-unknown-source
no bridge-group 25 source-learning
no bridge-group 25 unicast-flooding
bridge-group 25 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface GigabitEthernet0.15
no ip route-cache
bridge-group 15
interface GigabitEthernet0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
no bridge-group 20 source-learning
bridge-group 20 spanning-disabled
interface GigabitEthernet0.30
no ip route-cache
bridge-group 30
interface Dot11Radio1.15
no ip route-cache
bridge-group 15
interface Dot11Radio1.25
no ip route-cache
bridge-group 25
interface Dot11Radio1.30
no ip route-cache
bridge-group 30
interface GigabitEthernet1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet1.15
no ip route-cache
bridge-group 15
interface GigabitEthernet1.20
no ip route-cache
bridge-group 20
interface GigabitEthernet1.30
no ip route-cache
bridge-group 30
! BVI 1 to VLAN 10 MGM
interface BVI1
ip address 10.0.10.20 255.255.255.0
no ip route-cache
ip default-gateway 10.0.10.10
no ip http server
ip http help-path http://www.cisco.com/warp...smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
session-timeout 5
exec-timeout 5 0
line vty 0 4
session-timeout 5
access-class vty-acl in
exec-timeout 5 0
transport preferred ssh
transport input ssh
transport output none
[ Voor 0% gewijzigd door Equator op 06-12-2017 07:25 . Reden: Config tussen [quote] gezet ]
  • MAX3400
  • Laatst online: 14:47
MAX3400
XBL: OctagonQontrol
Ok, maar zoals je andere topics: Nederlands is hier de voertaal en random een config neerplempen (zonder code-tags) en zonder aanwijzen waar je precies niet uitkomt, vind ik wat kort door de bocht. Moet ik raden of deze config van een Forti komt, een Toon of uit een Aygo?
Zonder verder oordeel; wil je aanwijzen waar je VLAN10 gedefinieerd hebt?
/edit: volgens mij ben je ook verplicht te melden dat je het ook het gepost op https://networkengineerin...onomous-configure-problem 2 uur geleden.
[ Voor 33% gewijzigd door MAX3400 op 05-12-2017 22:40 ]
  • elisa9180
CAP2702I-E-K9 Is een Cisco ap
Hier een ssid van de config waar ik graag WPA2 wil geconfigureerd hebben.
dot11 ssid S-Guest
vlan 15
authentication open
WPA2 Password
interface BVI1
no ip route-cache
Ps MAX zoals ik zie heb je meer wintel ervaring. plus ik vermeld duidelijk het model in mijn topic.
Waarom ben in VERPLICHT om te melden dat ik mijn vraag aan meerdere mensen/website heb gevraagd Internet is vrij medium.
[ Voor 22% gewijzigd door elisa9180 op 05-12-2017 22:58 ]
  • Equator
  • Laatst online: 12-10 15:57
Equator
Crew Council
🦺#Rodekruis #whisky #barista
@elisa9180 Ten eerste: Dit is een Nederlandstalig forum. Prima dat jij je probleem ook ergens anders post, maar neem dan wel even de moeite om de post te vertalen.
Ten tweede: Een hoop config zonder het e.e.a. tussen code of quote tags plaatsen wordt een onleesbare brei. Ik heb de config even voor je in quote tags gezet.
Ten derde: Wat heb je zelf al geprobeerd? Ik zie nergens in je post dat je al zaken hebt geprobeerd, of bijvoorbeeld configuratie voorbeelden hebt gebruikt. Je zal toch niet de eerste zijn die een WPA2 wachtwoord op een dergelijk AP plaatst?
Heb je überhaupt gezocht?
Als ik even snel zoek op [google=cisco ap wpa2 config] dan loop ik al heel snel tegen deze link aan: https://www.cisco.com/c/e...99-config-wpa-psk-00.html
Volgens mij zou deze config je wel eens met beide vragen kunnen helpen.
Omdat het topic niet aan de regels voldoet gaat het op slot. Wil je het nog eens proberen, prima, maar houdt je dan aan de regels!
