Ik heb een asus6800Deluxe videokaart en bij de info van die kaart staat Side Band On/Off
Wat betekend dat????
Hehe, dat is inderdaad een mooie naamOp woensdag 11 juli 2001 09:35 schreef hjs het volgende:
Koel, nog een Vtec
Leuke voornaam ook
Go Through Your Heart Shakra Into Your Cave, And Find Your Power Animal
How can I enable AGP Sidebanding?
Before you read this question: Don't worry too much if you can't get AGP sidebanding enabled. There's only about 1-2fps in it and it can cause instability.
If you have a Creative card, there is a utility called AGP Wizard that you can use to enable AGP sidebanding. You can read more about it in the following question: 'What is AGP Wizard?'.
In the 3.69 and later drivers you can use the athlonsbaon.reg registry file to enable sidebanding on Athlon motherboards only - available here:
http://www.geforcefaq.com/files/athlonsbaon.reg
If you have problems after enabling this, use the athlonsbaoff.reg registry file to disable it again - available here:
http://www.geforcefaq.com/files/athlonsbaoff.reg
WARNING: The registry file may not work if you have a 64MB Prophet II card. It seems that AGP sidebanding is disabled in the video BIOS for Athlons with that card. In addition you may not be able to use AGP Sidebanding if you have the Athlon AGP2X hack enabled as well in the 5.xx drivers.
If you have an ASUS card, you can download a special Flash BIOS file that will enable sidebanding from the ASUS website.
If you really like living dangerously, it is possible to use a program called BIOSMOD to change your BIOS file before you flash it so that sidebanding is enabled. However, this will invalidate your warranty, and could in theory mess up your card. Don't email me or your manufacturer's technical support for more information or if it messes up your card!
If that hasn't scared you off, take a look at this page:
http://www.m3dzone.com/zoiah/
under the BIOSMOD / Tutorials / How to disable/enable SBA (Sideband addressing) on a GeForce section.
Once again, this is for experienced users only.
The sidebanding registry hack (involving the DISABLEAGPSIDEBAND key) that is being spread around is fake and does not work.
Jezus, een beetje gefrustreerd ofzo ??? Zoals je ziet heb ik je daarna effe netjes proberen te helpen. Baal je nu dat je toch niet zo orgineel bent met je naam ?Op woensdag 11 juli 2001 09:37 schreef VTec het volgende:
Hehe, dat is inderdaad een mooie naamDe 1e x dat ik een VTec in Nederland tegenkom. Zeker ook een Honda-fan
En dan ook nog dezelfde voornaam.
En nog een leuke:Geregistreerd op: 05 juli 2001. Dat was dus op mijn verjaardag !!!
Het zit je allemaal wel mee he Vtec????
