PC upgrade, enige tips of verbeteringen?
  • Harmen1
  • Registratie: April 2016
  • Laatst online: 28-02-2025
Het bericht staat in het engels, belet jezelf niet om met Nederlands te reageren. Ik hoop dat jullie leuke andere ideeën hebben.
So my current build is 2 years old and I am upgrading again. I am looking for optimization options. And is there a good reason for me to go for a ryzen CPU instead of the I7 8700k?
The games i play are OW (main game) and RPGs (mainly open world)
Current build:
CPU: I5-6600K 3.5ghz
GPU: MSI GTX 970 4gb
CPU Cooler: Hyper TX3 (fan bracket version)
MB: H170A gaming pro
Ram: Vengeance LPX DDR4 4x4gb 2133mhz
PSU: Corsair VS650
SSD's: 1 Samsung 850 evo 128GB. 1 Samsung 850 evo 250gb
HDD: Seagate 2TB
Case: Coolmaster Strom Scout 2 case
Monitor: BenQ RL2455HM (60hz)
I am gonna sell this whole build except the monitor, 250gb SSD and the HDD
Upgrade build:
CPU: I7-8700K 3.7ghz
GPU: MSI GTX 1080 gaming X+
CPU Cooler: Cooler master master airmaker 8 (160,5mm height, case can have one op to 170mm)
MB: MSI Z370M gaming pro AC
Ram: Hyper x FURY DDR4 2x16gb 2400mhz
PSU: Corsair RMx Series RM750x
SSD's:1 Samsung 960 EVO m.2 500gb. 1 Samsung 850 evo 250gb
HDD: Seagate 2TB
Case: Corsair Crystal Series 570x RGB (+3 additional case fans for the back/ upper part)
Monitor: Asus rog Swift PG258Q
So main questions are.
Should I go for a ryzen CPU or maybe even the 7700k?
Ram is expensive should I upgrade it? As of linus MHZ doesn’t really matter?
Mobo, any better suggestions?
And if you have any other things you’d like to add I would gladly hear them. My budget is up to 2700 euros (2700 minus my current build ill sell is approximately 2000 euros)
Thank you
  • VosStijn
  • Registratie: Maart 2017
  • Laatst online: 17-05-2023
Mag ik vragen waarom je wilt upgraden? Lijkt me niet dat je nu echt tegen dingen aanloopt.
Eerste, succes om je I5 systeem te verkopen voor €2000.
Ten tweede, ik zou niet upgrade.
Ten derde, zou ik eerder voor de AMD 1700x gaan, goedkoper, leverbaar, goedkoper MB, kan gewoon gekoeld worden met een luchtkoeler dit in tegenstelling van de 8700k, en sneller, 8/16 core/thread....
  • Nat-Water
  • Laatst online: 20-09 14:55
GPU upgrade, okee. Maar waarom de rest?
Wat wil je bereiken?
Balls have got to be one of the oldest toys. They've been round for a long time.
Gloria patri furnituribus In nomine IKEA!
  • Bennnie
  • Laatst online: 16-09 15:50
Je huidige 6600k heeft zelfs zonder overclock nog altijd een betere single core speed dan de ryzen 1800x, dus naar mijn mening is ryzen niet echt een upgrade als je alleen gamed met die pc.
Waarom wil je precies die monitor? Vind je >144 hz heel belangrijk? Zo ja, dan is het een goed idee om je hele pc te upgraden. Je huidige processor is waarschijnlijk niet krachtig genoeg om zoveel fps te genereren.
Een 120hz 1440p scherm ga je denk ik meer plezier van hebben. Je huidige pc is nog redelijk krachtig. Je zou dus alleen de videokaart en de monitor kunnen upgraden.
  • Harmen1
1. VosStijn: Ik wil upgraden voor mijn 4k tv die aan mijn PC vast zit en voor een 240hz monitor. Aangezien ik 3 schermen aan mijn PC heb hangen heeft deze nu moeite om een stream op mijn tv + bijv OW af te spelen. Daarnaast had ik zelf een soort van irrationele drang om gelijk alles te doen, maar uit de comments blijkt dat dit misschien helemaal niet nodig is.
2. gbklasser: Sorry dat het niet duidelijk is. Het moet natuurlijk zijn 2700 (bedrag pc) - 700(bedrag oude pc) = 2000 (uit eigen zak). Waarom zou de 8700k niet gekoeld kunnen worden met een lucht koeler?
3. Nat-water: sorry dat dit niet duidelijk was, zie 1.
4. Bennie: Klopt ik wil graag een 240hz monitor, zoals bovenstaand. Ook zou ik willen zeggen is voor spellen zoals OW een hogere FPS niet fijner ipv 1440p, ivm reactie snelheid? Wat zou jou dus motiveren om voor 1440p te gaan?
Bedankt voor de reacties!:D
  • freaky35
  • Laatst online: 23:42
240hz, om eerlijk te zijn zie ik het verschil al bijna niet meer als ik van 144 naar 165 of hoger ga. Ik game zelf op 1440p144, die extra pixels doet het ehm wel voor mij, ik wil niet meer terug naar 1080p. Maa goed dat is persoonlijk.
En die 8700k lucht, maar verwacht geen overclock, ja alle cores op 4.7 zal wel gaan. Maar als je hoger wilt, zal je echt naar water moeten
  • Harmen1
YouTube: [Slow motion] 240Hz vs 144Hz vs 120Hz vs 60Hz - Monitor refresh rates
Aan de hand van dit filmpje maakt het wel degelijk verschil. Het oog zal het niet waarnemen, maar het schieten en raken zal een stuk soepeler verlopen. Daarnaast heb ik naar 1440p gekeken en het is idd een serieuze optie dus dank hiervoor.
Wat betreft het lucht koelen, daar zal ik rekening mee houden, ik was van plan om ooit ergens in de toekomst over te stappen naar waterkoeling, dus wanneer ik naar de 5ghz wil zal ik dat doen.
[ Voor 71% gewijzigd door Harmen1 op 07-11-2017 12:43 ]
  • Thomg
  • Laatst online: 21-09 11:10
Thomg
Aww yiss
Als je serieus op 240Hz wilt gaan gamen is een 8700K (overklok deze) + 1080Ti allesbehalve een luxe.
Maar, toch, ik zou kijken naar 1440P 120/144Hz met iets als lightboost (nu ULMB) en/of GSYNC.
https://www.blurbusters.com/faq/120hz-monitors/
[ Voor 42% gewijzigd door Thomg op 07-11-2017 17:06 ]
Ik zou alleen je GPU upgraden. De GPU die je wilt is prima (en stukke beter dan die je nu hebt).
  • Harmen1
Bedankt voor al jullie reacties! Gezien de noodzaak voor een 1080ti bij 240hz lijkt me de opmerking voor 165hz 1440p een prima idee!
