  • smily01
  • Laatst online: 24-09 12:54
Mijn vraag
Ik gebruik Debian 9.0 Stretch en de laatste verse van Virtualbox 5.2 die hik heb gedownload van de website van Virtualbox. Als ik Virtualbox wil gaan gebruiken krijg ik de volgende melding:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
'/sbin/vboxconfig'
as root.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
Nu probeer ik om /sbin/vboxconfig te draaien, maar dat help niet. Dan krijg ik de volgende melding in de terminal:
Created symlink /etc/systemd/system/multi-user.target.wants/vboxdrv.service → /lib/systemd/system/vboxdrv.service.
Created symlink /etc/systemd/system/multi-user.target.wants/vboxballoonctrl-service.service → /lib/systemd/system/vboxballoonctrl-service.service.
Created symlink /etc/systemd/system/multi-user.target.wants/vboxautostart-service.service → /lib/systemd/system/vboxautostart-service.service.
Created symlink /etc/systemd/system/multi-user.target.wants/vboxweb-service.service → /lib/systemd/system/vboxweb-service.service.
vboxdrv.sh: Stopping VirtualBox services.
vboxdrv.sh: Building VirtualBox kernel modules.
This system is currently not set up to build kernel modules.
Please install the gcc make perl packages from your distribution.
Please install the Linux kernel "header" files matching the current kernel
for adding new hardware support to the system.
The distribution packages containing the headers are probably:
linux-headers-amd64 linux-headers-4.9.0-4-amd64
There were problems setting up VirtualBox. To re-start the set-up process, run
/sbin/vboxconfig
as root.
Mijn vraag aan jullie is: Hoe kan ik dit probleem oplossen?
  • Hero of Time
  • Laatst online: 22:08
Hero of Time
Moderator LNX
There is only one Legend
Het forum van VB staat bomvol met deze melding. Het antwoord staat zelfs in de foutmelding! Heb je dat überhaupt al uitgevoerd?
Commandline FTW
  • smily01
Dat staat ook in mijn bericht
  • Bor
  • Laatst online: 23:32
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Heb je de rest van het bericht ook gelezen?
"Please install the gcc make perl packages from your distribution."
en
"Please install the Linux kernel "header" files matching the current kernel for adding new hardware support to the system. The distribution packages containing the headers are probably: linux-headers-amd64 linux-headers-4.9.0-4-amd64"
De foutmelding lijkt mij aardig duidelijk. Zoals Hero of Time al aangeeft staat het VB forum vol met deze melding incl hints om het op te lossen.
[ Voor 30% gewijzigd door Bor op 04-11-2017 17:03 ]
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • Hero of Time
Hero of Time
Moderator LNX
Je zegt het volgende:
smily01 schreef op zaterdag 4 november 2017 @ 16:23:
Waar staat hier wat je hebt geprobeert? De foutmelding zegt precies wat je moet doen, lees dit nog eens door:
'/sbin/vboxconfig'
as root.
/sbin/vboxconfig
as root.
Commandline FTW
  • firebird_1979
Dit zou het moeten fixen:
sudo apt-get install linux-headers-generic build-essential dkms
sudo apt-get remove --purge virtualbox-dkms
sudo apt-get install virtualbox-dkms
  • smily01
Mijn excuses voor mijn bericht. Ik ben nog net zo lang met Linux bezig. Ook had het probleem had gegoogeld, maar dat leverde niets op. Uw suggesties hebben het probleem opgelost! Mijn dan daarvoor.
  • Hero of Time
Hero of Time
Moderator LNX
Ik zet dit topic trouwens ook even op de goede plek. SWS is niet gelijk aan NOS.
Commandline FTW
