Watercooling help
  • 244 views
Hello,
I'm a bit old, have very bad eyesight and I'm not an expert in watercooling. I'm wondering if anyone is willing to help me build a custom water cooling setup for my new home Threadripper 1950X rig, because I've made a mess.
It doesn't have to be fancy.
Currently I'm using a closed loop system and it doesn't fit the case (the case is too big) because the tubes aren't long enough, and the waterblock doesn't cover the entire TR4 socket at all, even though it was supposed to do.
The radiator is hanging loose inside the case, but the that's the least of the problems.
It does work, but under high load the CPU powers down some of the cores because it can't stand the heat. I'm not even daring to overclock it.
Really need to fix my awful build :-)
I've never done a custom watercooling setup before and I'm likely to screw it up.
Anyone around in Amsterdam who can help me out getting the right parts from alternate or wherever and help me install it?
I dont mind paying for the assistance at all, and would love to have someone help who knows what the hell they are doing.
I've already wasted 170 euros on this closed cooling system that doesnt fit in the case and really don't want to f*ck it up again.
Would really appreciate it.
Cheers
SMS: Please don't post phone numbers in public forums
[ Voor 33% gewijzigd door Rone op 25-10-2017 21:12 ]
  • Rone
Rone
Moderator Tweaking
This is a Dutch forum and all posts should be in Dutch. As such, this thread will be closed.
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
