FPS drop in sommige games
  • 245 views
Ik heb dit bericht van mijn post op een andere website gekopieeerd.
First I want to say that I am not to sure if this is the right forum to post this. I'm having a bit of a problem with my pc at the moment. I have:
- Gigabyte gtx 1060 6GB Windforce
- Ryzen 5 1600 (not overclocked)
- Asrock AB350 Pro4
- 1Tb Harddrive
- Cooler Master Masterwatt Lite 500W
- 8gb of ddr4 2666 ram
In some games I'm having big fps drops. For example gta 5, On highest settings an average of 75 fps having frame drops after riding a bit, On lowest settings an average of 95 fps having frame drops after riding a bit. Because of this I don't think it has anything to do with my gpu at all. CPU(Shouldn't be any issue), HDD, and PSU can stil be the problem, so I ran a osd on gta v. Having a little video here: https://s.amsu.ng/tcLu6cY3J3PN (Downloading might make the quality better) I didn't went with shadowplay just to be sure nothing is influencing it even though shadowplay is known for almost not having effect on your fps. According to this video I assume it's not my cpu, so It can be my psu, ram or hdd. 500W should be enough to power my system. Some side information: I shouldn't have any virusses on my computer and my drivers should be up to date, The programs I am ussually running in the background while gaming are Razer synapse, discord, Gigabyte Extreme Gaming Engine and steam. Does anyone think what can be the issue/bottleneck? Any help is appreciated! Sorry if my english isn't that good at some points.
  • Bart ®
  • Laatst online: 12-10 17:34
Bart ®
Moderator Spielerij/AI
I have the cape.
Je mag ook de moeite nemen om het te vertalen.
Cunning linguist.
  • MAX3400
  • Laatst online: 08-10 13:31
MAX3400
XBL: OctagonQontrol
Nederlands is inderdaad de voertaal; neem aan dat je ook onze suggesties vertaalt en op de andere site zet en andrsom?
Heb je met correcte tools als eens de temps & load bijgehouden van zowel de CPU & GPU? Daarnaast, je zegt een aantal andere programma's op de achtergrond te draaien; heb je die al eens uitgezet?
  • Nemesizz
  • Laatst online: 21:52
Nemesizz
Untouchable
- 1Tb Harddrive
Dat de enige drive in je PC? Want als je je OS, achtergrond programma's, én de game van die ene schijf draait dan is het niet verwonderlijk dat je framedrops krijgt. De rest van je componenten is dan gewoon aan het wachten tot je HDD weer data toestuurt, en vooral in een game als GTA (waar constant veel geladen moet worden) merk je dat.
Zelf gebruik ik ook nog een HDD only systeem, maar draai het OS (en achtergrondprogramma's) op een aparte schijf, en games vanaf een ander. Dat werkt aanzienlijk beter dan alles van 1 schijf draaien (nog steeds kun je uiteraard framedrops krijgen, maar minder vaak).
Meest handige optie is, om een SSD te halen, daar in elk geval je OS opzetten, en dan games en dergelijke starten van de HDD (of als er ruimte vrij is op de SSD, veeleisende game, zoals GTA ook op de SSD).
Oh ja, welke harddisk is het? want je hebt ook van die 'eco' harddisks, die zijn puur bedoeld voor massa opslag en niet echt om programma's van te draaien (te traag, vaak 5900 of 5400RPM schijven).
  • Geronimous
Geronimous
Moderator Spielerij
Welkom op Tweakers, Ray.
We verwachten inderdaad dat je in het Nederlands post hier. Bovendien zou het je sieren als je een vraag stelt, dat je ook antwoord geeft op de vragen die de andere bezoekers je stellen.
topic krijgt daarom slotje...
⚛︎ 1-2-2022 poor Leno
