  • tieppie
  • Laatst online: 19-10-2017
Hi Guys!
I have a problem with my system, it won’t power up at all, I do hope you can help me.
The components are:
- Motherboard: Gigabyte ga-ab350-Gaming 3 ATX (BIOS version Unknown)
- RAM: Ballistix Sport LT DDR4 2666 UDIMM (2x 8gb) Modelnumber: BLS2C8G4D26BFSEK
- CPU: Ryzen 5 1600x
- CPU Cooler: MSI Core Frozr l
- GPU: Zotac GeForce GTX 1060 1506 zt-p10600 a-10L 6 GB (mini)
- HDD: Samsung MZ-N5E500BW 850 EVO Internal SSD, 500 GB, SATA III, 6 GB/s, M.2
- PSU: Seasonic Prime Focus modular (80 + Gold) 550 watt
- Case: Phanteks Eclipse p400S MIDI-Tower, tempered Glass
Things I’ve tried:
- I have checked the PSU, it works 100%.
- Connected the ‘blue USB3 front panel cable’ and it actually charges my phone via the Front USB slot. So there seems to be power.
- Tried using only 1 RAM module , and tried different slots.
- Tried without HDD
- Tried without GPU
Whenever I push the Power Button on the case. The PC will not start at all. No beeps, no spinning of fans, No LED , nothing.
Could it be a compatibility issue? I found on the Gigabyte support website the Motherboard needs at least F6 version of the BIOS to use the Ryzen 1600X processor. But to be honest, as I can't boot. I can not check the version. So I'm not sure this is the issue.
Maybe you guys have an idea?
Any help is appreciated.
  • TheUninvited
Check the front panel connectors? If your motherboard is powered and it doesn't spin up the fans you could still try to connect a speaker and/or see if it gives error codes if your motherboard has a display for that.
  • Foodie88
  • Laatst online: 11-08 20:42
It sounds like the on/off switch might not be (correctly) connected to the motherboard. Cross reference it with the manual of your motherboard.
BF1 Stats
  • Microkid
  • Laatst online: 21:38
Microkid
Smile
move --> PMG
  • eSCe
  • Laatst online: 01-11 23:33
Foodie88 schreef op dinsdag 17 oktober 2017 @ 16:57:
^This
I think your power button might just be plugged onto the wrong pins.
  • Speedy-J
  • Laatst online: 02-11 13:56
Speedy-J
AMD Enthusiast
Check your front pannel connectors first ,I also think this is the problem.
Ryzen 9 5950@4.7GHz|Asus prime X570 pro|32GB Corsair pro rgb ,2x XFX rx470rs black wolf ,Custom WC van EK|chietech dragon|Corsair 1000w rm x
  • Bolletje
  • Laatst online: 07-11 18:13
Bolletje
Dutch is the only supported language on this forum. Therefore I've closed this topic.
Either start another topic - in Dutch - or ask for help on one of the English/international fora.
Thanks for your understanding.
[ Voor 8% gewijzigd door Bolletje op 17-10-2017 17:55 ]
