MikroTik RB3011 PPPoE + xs4all FritzBox 5490 [ENG]
Hi everyone!
I apologize for my English and that I'm writing on Dutch forum in English but you are my only hope. For sure some of you already resolved problem I got and I can't find answeare on English forum's so that's why I'm here. _/-\o_
I'm using internet from xs4all (Fiber 160/160) and what I'm trying to find out is it possible to replace FritzBox or connect thru PPPoE client from MikroTik RB3011UiAS+RM? I know some of you did it with KPN ISP but from what Google translator told me there was problems with xs4all. So I want to ask you here does it work before I will start implementing it to my network - just to avoid unnecessary problems and waste of time.
For you who knows already topic below you can find what I found during my deep dive in this forum (it's hard just with google translator 8)7
First just WAN and gateway with VLAN id 6 because from what I found that xs4all uses Internet data thru VLAN6
/interface vlan add interface=ether1-gateway name=ether1-vlan6 vlan-id=6
Then normal client PPPoE configuration
/interface pppoe-client
add add-default-route=yes allow=pap default-route-distance=1 disabled=no \
interface=ether1-vlan6 keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=\
pppoe-xs4all password=kpn use-peer-dns=yes user=FB7490@xs4all.nl
As I assume just need to replace password and user with the one I got. But my question is are you doing it connecting FritzBox 5490 to MikroTik router and on FritzBox you activating this option
Connected network devices are also allowed to establish their own Internet connections
or you buying SFP+ and connecting fiber to MikroTik?
Thank you for all help and suggestions
Last option is the best. I doubt that you should use the VLAN in combination with PPPoE.
You can also leave the Fritzbox in place, and use the RB3011 as the main router. I had it working here (when I had xs4all) and now I use it in combination with Ziggo. (without double NAT!!!).
